Old 05-26-2007, 04:14 PM   #19546
dawgmeat's Avatar
Originally Posted by Darkseid
Here you go. This is the 2mm shim the manual calls for.
thanks
dawgmeat is offline   Reply With Quote
Old 05-26-2007, 04:15 PM   #19547
AdrianM's Avatar
We started hearing reports of dogbone pin failures last week in the UK. I talke to Schumacher UK and there will new dogbones on the way to the US as of next week.
If you have a problem give Shu USA a call and we will get new drive shafts out to you at no charge as soon as they come in.
Adrian Martinez
Old 05-26-2007, 04:17 PM   #19548
dawgmeat's Avatar
Originally Posted by Mike Schumacher
Can someone post a picture of the bottom view of Mi3?
Old 05-26-2007, 04:17 PM   #19549
Regional Moderator
Darkseid's Avatar
Originally Posted by dawgmeat
where the hell was that in manual????
Actually, I don't think it was in the manual itself. I think it was on a little sheet of paper that was inside one of the bags with the steering equipment.
If you look at your extra stuff from the build, you'll find the two black plastic washers your supposed to use.
TLR 22...Tamiya F104...
Old 05-26-2007, 04:18 PM   #19550
dawgmeat's Avatar
that my Dawg
Old 05-26-2007, 04:19 PM   #19551
Regional Moderator
Darkseid's Avatar
Damn you guys are good!
Old 05-26-2007, 04:23 PM   #19552
Regional Moderator
Darkseid's Avatar
dawg beat me to the pic, but I had taken the pic already, so here it is.
You'll notice an extra screw, thats for the alternate antenna position I used.
Also note the Schumacher colored battery tape.
Old 05-26-2007, 05:58 PM   #19553
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Finally got to run my new MI3 with my new radio (no more radio problems) and man it was awesome. 1st pack I ran at my local asphalt track I was a tenth slower than my EC and by the 2nd pack as was running the same times but was more consistant overall. Running a combination of the PW setup and my own settings from what I learned from my EC. Great 1st day on the car. Everything was flawlessly. I didn't have to push the car very hard to run the same times as my EC. The can fine tune the MI3 just a touch at a time when I get it really close. I'm very impressed with my car.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-26-2007, 05:58 PM   #19554
wyd
Tech Legend
wyd's Avatar
Originally Posted by Static_racing
I was hitting 12.6's and 12.7's
I only have 4 packs through the car, so I know I can get down to 11.8 - 11.9 with alittle time and tuning. The car has so many adjustmets to play with I has going to goto Jackson next Saturday, but I'm thinking fredrick..........
I was down to 11.9's on my 2nd pack. It is a fine line to go from 12.7's to even 12.3's and to get 12.0 and 119's and under is a really fine area of grip and not traction rolling. My car make almost no noise other than the belts. The tires barely make a sound when going around the corners.
Old 05-26-2007, 06:03 PM   #19555
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
cool!! Im racing mine tomorow for the 1st time (other than practice) Hopefully I can get some setup help from Jason (protc3) I ll let you guys know how the car does!
Old 05-26-2007, 06:06 PM   #19556
wyd
Tech Legend
wyd's Avatar
Great. The car was awesome and the new 3PK Super with the HRX/Synthesized setup was flawless. It was a great day. The car will just get better. I will say alot of stuff I did on my EC worked when I tried it on my MI3.
Old 05-26-2007, 06:07 PM   #19557
Super Moderator
Marcos.J's Avatar
how did your cvd's hold up??
Old 05-26-2007, 07:41 PM   #19558
is this only for the mi3? as i had two pins sheer of as shown a fortnight ago i think it was a mix of the pins and a spool?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 05-26-2007, 08:06 PM   #19559
AdrianM's Avatar
The Mi3 and the latest Mi2EC's use the same driveshafts. Talk to Schu UK and they will fix you up
Adrian Martinez
Old 05-26-2007, 08:33 PM   #19560
Mike Schumacher's Avatar
Trader Rating: 36 (100%+)
Wow! only 13 screws on the bottom. What an unlucky number!!!
Mike Schumacher is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
