Old 05-25-2007, 11:15 AM   #19516
Originally Posted by Marcos.J
yes it is but he made some changes to it to get more sterring ,he told me to lower the front diff and added a little more rear toe
Marcos - what effect does lowering the front diff have on the cars performance?
Schumacher | Novak | P-dub Racing | Orion | Airtronics | Team Stream
sf85 is offline   Reply With Quote
Old 05-25-2007, 11:18 AM   #19517
AdrianM's Avatar
All the Schuey team drivers at the Reedy Race are hooked up and hauling. Its going to be a good weekend
Adrian Martinez
Old 05-25-2007, 11:21 AM   #19518
Adrian - what changes have they made to the PW setup that you know of?
When does invite run today, so far it's only been 19T and open mod according to LiveRc.
Old 05-25-2007, 11:45 AM   #19519
KyLayfield's Avatar
Trader Rating: 86 (99%+)
4 heats of invite ran about an hour ago on liverc...
KyLayfield is offline   Reply With Quote
Old 05-25-2007, 12:44 PM   #19520
AdrianM's Avatar
PW is not releasing details to racers outside that team at the track for the moment. What we are figuring our out applies to other cars too so we want to keep it on the down low until monday.
Adrian Martinez
Old 05-25-2007, 02:37 PM   #19521
Charles Godwin's Avatar
Sounds like the car is really doing well then at Reedy. Can't wait to give it it's first run hopefully on Thursday
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 05-25-2007, 04:52 PM   #19522
Regional Moderator
Darkseid's Avatar
I just got done making the switch to RPM ball ends, and I can't believe theres even a debate as to which is better. The RPM ball ends are so much better than the Schumacher ball ends, its amazing.
Same smoothness, with almost unnoticeable play. The only ball ends I've seen that had this kind of smoothness with such little play, were the ones that came on my KX-1 back in the day.
Only downside I can see is that the RPM pieces are softer, so they snap off a little easier. And if you buy the long ones like I did (thats all the shop had in...I don't even know if they make shorter ones...) then you have to cut them down to be the same length as the Schumacher pieces.
Other than that, I can't see using the standard pieces over these.
Anyway, heres a look what I'll be running atop my Mi3.
TLR 22...Tamiya F104...
Old 05-25-2007, 04:56 PM   #19523
Regional Moderator
Darkseid's Avatar
Good to hear that the guys are doing so well at Reedy.
Old 05-25-2007, 07:08 PM   #19524
Randy Caster's Avatar
Trader Rating: 46 (100%+)
A car with some slop in the ball ends will be much easier to drive than one without.
Old 05-25-2007, 07:23 PM   #19525
Static_racing's Avatar
Hey Adrian, thanks for the assist today. I've got 4 packs throught the car and its very close for Fredrick. I went with a one-way up front and shaved 5 10ths. I also played with roll center and droop. Car is VERY close. I'm really looking forward to Jackson!
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 05-25-2007, 07:24 PM   #19526
Regional Moderator
Darkseid's Avatar
I'll take my chances.
Old 05-25-2007, 07:58 PM   #19527
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
What kind of lap times did you turn tonight at Frederick?
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-26-2007, 01:00 AM   #19528
JayBee's Avatar
Trader Rating: 31 (100%+)
Just about finished with the 1st one Shock buildin' tomorrow
I've had the pleasure of building most of the best kits (with the exception of X-Ray) available over the past 3yrs since I've started this whole R/C deal and this is my 1st Schuie. Basically in my view all the high-end cars are the same as far as the aluminum/ti/graphite/etc fitting on point (durability of some of these materials may be in question), but one of the things I look for is the fit and strength of the plastic pieces. The two problems I ran into so far has been 1pr. of the chubs & steering blocks fitting WAYY too snug even after repeated fiddling Next was that 3 out of 4 dogbone assemblies were stuck! Took them apart and there was a rust-colored film on everything. It's all good now though. Other than these issues I put the MI3 a tad behind the RDX, and the Masami BD as far as 'ease of buildability' but this car is WAYY ahead of all others when it comes to ingenuity, innovation, ease of adjustment & it seems hella durable. The car is stout. Steering rack and drivetrain....BUTTER
All in all, I'm enjoying the build and can't wait to see it's performance on the track
Here's my little slice of R/C heaven.......
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-26-2007, 01:55 AM   #19529
Send a message via ICQ to MattW
Totally agree with this one. Especially in the steering. Something i was told by a 12th scale guy that knows what he's about. I've given up telling people this over the years., as very few people will believe you!!
MattW is offline   Reply With Quote
Old 05-26-2007, 06:11 AM   #19530
Just sayin.. slop isn't always a bad thing. I havent had a single ball cup pop off yet with the stock stuff.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
