Old 05-24-2007, 02:28 PM   #19486
Sigearhead's Avatar
Trader Rating: 68 (100%+)
I've always thought the Schumacher ballcups are the best.
One tip for anyone buying the Mi3. Make sure you buy at least 2-3 of the U3131 Alloy shim kit. You need these and you need many of them depending on the setups you will be running. I am also hoping that at one point they'll make a .25 shim as well. I know there are other shims on the market you can use but the Schuie ones, nice and polished are just pimp!
Sigearhead is offline   Reply With Quote
Old 05-24-2007, 02:28 PM   #19487
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Originally Posted by Darkseid
On another note.
I've heard of some guys using the RPM ball cups. Do these have less play than the stock ball cups? I don't like how much play the steering has in it with the stock cups.
Some guys are just partial to color coding on there cars as rpm does offer purple. I don't see a real value vs. the Schumacher ones as far as slop goes.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 05-24-2007, 03:42 PM   #19488
Regional Moderator
Darkseid's Avatar
No, I don't think its about looks, because most of the people who use the RPM cups simply use the black ones.
Many people over on the Schumacher site board have said specifically that they use them to eliminate play compared to the stock ball cups.
I'm just wondering how much it helps. Cause the local hobby shop has some, and if they help, then I'll give them a try.
TLR 22...Tamiya F104...
Old 05-24-2007, 03:50 PM   #19489
JayBee's Avatar
Trader Rating: 31 (100%+)
Here's a trick if you want to use the Schuie cups but they are a little loose- just put a small drop a CA into the cup and quickly 'flick' it out. Complete coverage and no binding
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-24-2007, 03:53 PM   #19490
chris72983's Avatar
Is this the setup everyone is sarting with?
http://www.rctech.net/forum/attachme...hmentid=225779
chris72983 is offline   Reply With Quote
Old 05-24-2007, 03:59 PM   #19491
Originally Posted by SRW141
I put 1mm and one .5mm and the arm move back and forth slightly and put the in another .5mm and it worked great. So the .5mm clips must be thinner.
Okay so what I ended up doing is sanding down the 2mm qwik clip a little bit and it fits perfect now. If you sand it too much or if you eventually develop slop all you need to do is dab a little bit of CA super glue on the qwik clip and then slightly re-sand.
As far as having problems with the qwik clips falling off, which I saw someone write in a previous post, I never had one fall off when I ran my EC, and I run modified and unfortunately took some big time hits
Schumacher | Novak | P-dub Racing | Orion | Airtronics | Team Stream
sf85 is offline   Reply With Quote
Old 05-24-2007, 04:01 PM   #19492
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
Default MI3
Hello, This is my new ride. Test day this Saturday.
Schumacher Corner-resized_dscn0013.jpg   Schumacher Corner-resized_dscn0016.jpg
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 05-24-2007, 04:09 PM   #19493
protc3's Avatar
hey austin,what class are you guys racing this weekend?
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-24-2007, 04:16 PM   #19494
xrayaustin's Avatar
Default Sunday
Dosent matter to us. Just want to get some laps on the car.
Old 05-24-2007, 04:20 PM   #19495
protc3's Avatar
cool
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-24-2007, 05:38 PM   #19496
dawgmeat's Avatar
rear hub problem
I ordered an extra set of Mi3 rear hubs but recieved a set of Mi2 rear hubs anyway grab a new set of rear a-arm and a titanium pivot pin which is purple and guess what parts and finish was flawless Mi3 rear hubs are too damm tight
dawgmeat is offline   Reply With Quote
Old 05-24-2007, 06:48 PM   #19497
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
the rpm ends take away the slop quite well when used with the standard ball studs. a perfect fit, really.
the schumacher ball grippas are large by design. they fit well with the old titanium racing ball studs, or even the hot bodies ball studs with some pinching, but i don't like them on when used with the standard ball studs that the kit comes with. they snap on hard because they are of a super hard plastic and they neck down tight, but once on the ball, they float around too much for my liking.
the c/a trick works well too, but it can flake back out if you're always disassembling your ride.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-24-2007, 06:56 PM   #19498
AdrianM's Avatar
The Schumacher ball cups are really strong and you will never have a DNF for a ball cup popping off if you use them.
If you want to tighten them up put a plastic bag (like a zip loc bag) over the ball stud and snap the ball cup on. It will cookie cut a perfect plastic film disk and this will take up and play you have. You can experiment with different thickness bags to get the feel you want. If they end up a little tight squeeze the side with needle nose pliers and they will free up.
Adrian Martinez
Old 05-24-2007, 07:12 PM   #19499
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
Any news on Alex Lopez's runs?
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 05-24-2007, 07:30 PM   #19500
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Originally Posted by dawgmeat
wyd
are you racing at 301 i heard they change the layout for electric
I will be running next weekend at the FullThrottle race at 301.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
wyd is online now   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
