Old 09-21-2001, 12:27 PM   #181
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
November 1st is the suppose release date.
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 09-21-2001, 09:14 PM   #182
AdrianM's Avatar
Is the Tekin G-10 bigger than the 7,1? If so what's the word for that....LOL
The Tekin G-10 "Cinder Block" Speed control...
Speaking of Tekin I just got a hand me down Tekin G-412 ESC. It's like a G-12 but w/o the one touch setup. I remember my 1st couple of ESC's had 2 pots for setting it to the transmitter. However since every ESC i've had in the last few years have been one touch, the procedure for setting the 412 has gone in my mental land fill along with everything i ever knew about geometry, the world before spellcheck and Kensian Economic Theory.
Can someone help me setup this thing?
Adrian Martinez
Old 09-22-2001, 10:49 AM   #183
Racer X's Avatar
Adrian, I need to call you next week anyways. Just remind me and I'll help you set it up. In a nutshell, one pot sets the top speed endpoint, the other sets the brake endpoint...
got any 27s in stock?
Racer X is offline   Reply With Quote
Old 09-22-2001, 11:08 AM   #184
Regional Moderator
Darkseid's Avatar
The Tekin G-10 and LRPV7.1 might be big,(really big) but they work well.
TLR 22...Tamiya F104...
Old 09-22-2001, 11:52 AM   #185
dtm
dtm's Avatar
Send a message via ICQ to dtm
How do you set the neutral position then? I thought one pot set the neutral and the other sets the high speed endpoint!?!
dtm is offline   Reply With Quote
Old 09-22-2001, 03:34 PM   #186
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
hey all,
can someone tell me which way the flanged bearings go into the aluminum motor mount for the 99 pro? i want to put them in from the inside to keep the layshaft pully from rubbing the mount, but it's too wide then, the other way there's nothing to keep it centered or from rubbing. i dunno.
seaball is offline   Reply With Quote
Old 09-23-2001, 01:21 PM   #187
ttt
Old 09-24-2001, 02:16 PM   #188
Just curious if anyone has started running the A2 on carpet with foams yet? because I have the "killer" setup, that I will e-mail to you. It requires running the c/f A1 topdeck.
Old 09-24-2001, 04:59 PM   #189
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
I have been racing alot on foams lately. E-mail me your setup I would like to see what you are running.
Kane@nightingale.com
Kevin K is offline   Reply With Quote
Old 09-24-2001, 05:39 PM   #190
you have mail!
Old 09-24-2001, 06:00 PM   #191
Kevin K's Avatar
Hey Cory can you resend it in another format not WPS.
Old 09-24-2001, 07:15 PM   #192
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
Default Hi Guys
Well I finally made it here. Ive been lonely since rctouring went down
Good to see everyone on here and lots of good talk.
I am looking forward to the new car so much. Im not normally one to get that excited, but this is different. i have a feeling it is going to be awesome. Also I was told by Schumacher that the following item,s at least are the same from the Axis 2
Driveshafts
Shocks
Lower arms(I guess rears have been shaved to clear hubs)
Steering system
Oasis2001 is offline   Reply With Quote
Old 09-24-2001, 08:31 PM   #193
Hello All
Well Thanks to Che and the guys I will still be able to get Schuie parts.
Looking forward to the indoor season now. Does anyone have a picture of what the Echo Wheels look like? They sound like they would be kewl, but I would like to get a view before I order any.
Thanks again Che
PaulP
PaulP is offline   Reply With Quote
Old 09-25-2001, 01:46 PM   #194
Here it is Kevin! Since I cannot make it another format. lol
Front-
oil: 100(trinity)
springs: silver(schumacher)
lenght:67mm
piston:1 hole
tower position: 1st hole all the way in
arm position: outer
Hub holeuter(must file down inner,so their enough clearence)
akerman: stock setting
camber: -1 degrees
toe: 0 degrees
caster:wishbone spacer, placed in back....
Tires: TRC Plaids
Rear-
oil: 100(trinity)
springs: yellow(schumacher)
pistons: 1 hole
lenght: 67mm
tower position: 2nd hole from the bottom
arm position: outer hole
hub postion: outer hole.(do same as above, stated)
camber: -1.5 degrees
toe: 1.5 degrees in
anti-squat: 0 degrees(which is stock)
Tires: choosing between, Jaco Purples or TRC Magentas.
gearing with GM3 116/32
Note: If having problems with rear coming around in a skip motion, just switch the rear springs with the fronts.
Old 09-25-2001, 04:18 PM   #195
Kevin K's Avatar
Wow.....your car is way stiffer then mine. My car is working the best it ever has on foams right now. I will check it out and see ifin I like your setup better them mine. I will e-mail you my set up.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
