Old 05-23-2007, 12:01 AM   #19426
JayBee's Avatar
Trader Rating: 31 (100%+)
Just finished sanding the chassis pieces, CA'ed the main chassis & mounted the bulkheads The car already feels like a brick $#!+house....I mean that in a good way
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-23-2007, 05:40 AM   #19427
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Originally Posted by AdrianM
Stratus 3.0 - Mellow handling, very smooth and stable.
Mazda 6 - Good blend of steering and stability.
Mazda Speed 6 - More steering than Mazda 6 by giving up some rear stability. Better for tight agressive tracks.
DNA Asphalt -Crazy twitchy steering, does not seem to be as consistant as the 6 and Speed 6.
+1 for the DNA Asphalt. I really like the steering it has and excellent rear traction. I really like this body and it pretty much all I run anymore.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-23-2007, 06:25 AM   #19428
Static_racing's Avatar
Brian,
You like the DNA? What about the PARMA "M"? I've been running the speed6.
What are you planning on running at Jackson? I'm going to try the "M" and speed6
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 05-23-2007, 07:05 AM   #19429
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Originally Posted by Static_racing
Brian,
the type M is pretty good , i ran it yesterday very similar to the Mazda Speed 6
Old 05-23-2007, 02:41 PM   #19430
Cesar's Avatar
Default Battery Strap or Tape??????
Just wondering if there is some theory to using tape over a battery strap with post???
Thanks in advance
Cesar is offline   Reply With Quote
Old 05-23-2007, 02:48 PM   #19431
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I noticed that when i put a battery cell in the chassis slots, the cells were almost flush. This is awesome as I just had to run a file over the edges to break the sharp edge so it will not cut the cells, awesome job Schuie!
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 05-23-2007, 02:49 PM   #19432
Moderator
Thanks in advance
Tape is lighter, more of a chance for the tape to break however. Weigh the car for yourself and you will see. Tape also costs more money over time as it is a dispensible product whereas the battery strap is a one time buy and use it forever kind of thing.
SMC Racing
Old 05-23-2007, 03:00 PM   #19433
Charles Godwin's Avatar
Thanks in advance
Less chance of tweak in a crash.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 05-23-2007, 03:42 PM   #19434
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Charles
Less chance of tweaking period. I have yet to see a battery strap that doesn't put stress on the chassis to hold the battery in place. You can see it bow the chassis. I wouldn't recommend a battery strap to anyone.
Jon Kerr is offline   Reply With Quote
Old 05-23-2007, 05:31 PM   #19435
wyd
Tech Legend
wyd's Avatar
Brian,
I'm only running the DNA. I would think the Mazda will be better for you since traction at Jackson won't have VHT on the track so traction might be a little low.
Did run my MI3 and I will need to work on it because at this time my EC runs rings around it. First I need to fix my radio issues. Otherwise I will be at Frederick this Sat practicing alot to get my MI3 up to speed with my EC. I have alot of work to do. Told you my EC is that good.
It will get better. I had a huge on power push like crazy. It gets into the corner fairly good but if your on the throttle at all it pushes like a dump truck. I don't expect the MI3 to be perfect after a few runs so no big deal. I didn't make alot of changes til the radio issue is fixed and I hope to have that done by this weekend.
Old 05-23-2007, 08:53 PM   #19436
Regional Moderator
Darkseid's Avatar
Okay, I have emerged from my kit building isolation.
My thoughts on the build...
Overall, not the worst build I've had, but far from the easiest
First the bad...
Dealing with the rear suspension arms is just plain ridiculous IMO. I believe I spent as much time reaming, filing, and fitting the rear arms, than I did on all the rest of the kit. The idea of making it tight and letting people get it 'perfect', just doesn't fly for me. After all that time working on those arms, they have no more/less play than my last car. And with that car, all I had to do was mount up the arms, and add shims till it was perfect. And 2 years of running hasn't left the suspension sloppy just because it didn't start off insanely tight. I guess I just like parts to fit right, right out of the box. Guess thats just the 'club racer' in me.
One hole on my spool was filled with aluminum shavings. These shavings left the hole nearly un passable by the screw. It took me working the screw in and out a couple times, spraying the hole out, and poking out the shavings with an allen wrench before the screw would finally pass.
On a similar note, both my Right Rear bulkhead and my Front Left bulkhead(when viewing the car from behind) had a hole for the shock tower that were very badly tapped. In both cases, the screw got about halfway through, then seized up. I had to VERY gently work them to get the in. I don't plan on taking those screws out.
Thats about it for the bad...so now for the good.
I have to admit, the shocks were quite impressive. I did have one renagade that built up with rebound for some reason. But other than have to redo that one shock, everything went smoothly. I've never seen anything like those shocks. Not to have to hold the shock shaft at just the right point while screwing the cap on was sweet!
The center pulley fence wasn't nearly as bad as my memory told me it used to be. Maybe I just had a better idea this time. Instead of breaking my little hobby vice try to put the fences on, I decided to put on part of a fence, clamp it in place with miny vice grip pliers, then I just snapped the rest of the fence on with another set of pliers. Rinse, wash, repeat for other fence. Simple.
Taking the diffs out is so easy its just ridiculous. I realized late that I had offset the spool out drives, and I was like "damn I gonna have to take this spool back out to change that". In the end, it took me about 2-3 minutes to make the change! Wow!
I guess the weight issues are just for the 5 cell users, because fully loaded with Lipo(weight added), my car still scaled in at 48.5 ounces with body. Not bad when your used to shaving weight off a TA05 just to get down to 52ounces.
Using battery tape isn't going to be as bad as I thought. I'll still pick up a battery strap just to see what I like best. I've never had a bad experience with battery straps. Never seemed to cause chassis problems as long as they were well designed.
I was shocked to see how flexable the main chassis was. While sanding it, I blew it off with my compressor, and it flexed! But once all the bulkheads and upper deck were on, it was amazing to see how stiff it was! Incredible design work by Schumacher.
I seriously hope Futaba comes out with a micro reciever similar to the Spektrum unit. Space is tight with a none micro reciever. The limited space did force me to do my best wiring job ever though.
Seeing all the posible adjustments on the car has me really excited. My last car responded exactly as it was supposed to, to every change I made on it, even minor ones. It taught me A LOT about setting up a car. And I'm REALLY looking forward to applying that to the Mi3!
Anyway...I've rattled on enough. I've attached a pic of my finished Mi3. Hopefully the weather will give me a chance to race it this weekend. But in the midwest, you just never know.
TLR 22...Tamiya F104...
Old 05-23-2007, 09:08 PM   #19437
AdrianM's Avatar
Darkseid - Looking good!
Wyd - What setup were you running exactly? Nobody seems to like the kit setup. Everyone seems to like PW's setup as a starting point. I had to turn my dual rate down becuase I had too much steering in 19T. I also added .5mm rear toe to get more rear stability on power exiting corners. This was with PW's setup.
Adrian Martinez
Old 05-23-2007, 09:22 PM   #19438
dawgmeat's Avatar
I glad you got your car Darkseid and it's wired real clean, rear suspension just flat out sucks as far as hand-fitting, I hope Schumacher address this issue because if you break a rear arm at a club race you won't have to deal with hand-fitting and taking care of other stuff between round
dawgmeat is offline   Reply With Quote
Old 05-23-2007, 09:27 PM   #19439
Regional Moderator
Darkseid's Avatar
I was telling my buddy about the build and he told me that I should get some extra arms preped and ready before hand just in case. That way, I'll just be able to slap it on and go.
Makes sense, so thats what I plan on doing.
Old 05-23-2007, 09:28 PM   #19440
Regional Moderator
Darkseid's Avatar
Just as a note to anyone who might be starting with NIP(new in package) grey belts like I did, I ended up going one notch looser on both the front and rear belts. With the manual settings, the belts were so tight I could barely spin the drivetrain. One notch looser, and everything was perfect.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
