Old 05-22-2007, 05:34 AM   #19396
Registered User
James Khoo,
From the telecons with TP-RACING owner Mr Wong, I can get my MI3 next week...Crazy like hell waiting for this car..
AAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!! !!!!
huruharapro is offline   Reply With Quote
Old 05-22-2007, 05:35 AM   #19397
James khoo's Avatar
Trader Rating: 15 (100%+)
Send a message via Skype™ to James khoo
Looks like our moment is here!
Team Losi Malaysia
Upgrade Rc
James khoo is offline   Reply With Quote
Old 05-22-2007, 06:21 AM   #19398
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by heavy
Is anyone else having trouble keeping the pins in the front CVD's. They work loose every race and I've tried tightening them with locktite etc but nothing seems to work for me. When they come loose they jam inside the hub and cause the pins to shear off inside the spool end. At least with the new spool they don't damage the spool outdrive like they used to in the EC.
What's the fix for this I'm sick of pulling the front end apart after every race.
It's possible you could use a new barrel in the CVD. I once had a barrel that wasn't threaded far enough and the grub screw would get tight before it put enough pressure on the pin.
Try Darkseid's method first
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-22-2007, 07:34 AM   #19399
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by Marcos.J
yes its a tight squeeze
Yes but you squeezed it very well.
ST Racing Concepts (STRC)
Old 05-22-2007, 07:35 AM   #19400
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
i have enough room to fit a 51t pinion with the 114t spur
Old 05-22-2007, 07:38 AM   #19401
wyd
Tech Legend
wyd's Avatar
Can't wait to hear how practice goes. Freaking killing me man!!!!!!!!!!!
Old 05-22-2007, 07:38 AM   #19402
Super Moderator
Marcos.J's Avatar
me too im just waiting till my boss gets home
Old 05-22-2007, 07:45 AM   #19403
wyd
Tech Legend
wyd's Avatar
Old 05-22-2007, 07:46 AM   #19404
Super Moderator
Marcos.J's Avatar
and "yyhayyim" i still have the type R and keeping both!!!
Old 05-22-2007, 07:56 AM   #19405
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
Has anyone tried this? Set up all 4 of the rear suspension blocks (U3129 & U3130) just like the front ones. As known, the instructions have you set them up a bit differrent in the rear. The 2 rearmost blocks on the rear side, the ones by the shocks/bumber area, are actually kind of reversed, as apposed to the front side suspension blocks, which have all 4 the same way to creat 0 deg inboard toe. Well i set up the rear the same way, so that the rear also have 0 deg inboard toe. Now all 8 suspension blocks are set up the same way, and looks nicer and more assimetrical. Just add shims to the rearside's rearmost blocks to increase toe...
Advantages...well, it looks better, more assimetrical and even. Second, it's much easier to set up and have an idea of how to set up toe. Also, in the heat of a race, if for some reason you need to remove some shims or add, you dont to get confused and set it up the wrong way and screw your set up and waste time...maybe PW or Adrian can comment on this and see it seems Ok or not...
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 05-22-2007, 08:05 AM   #19406
yyhayyim's Avatar
Talking
I keept one Type R ,I still like how it handles
You said you have both, yet here you seem to indicate you have sold one and kept the other...I knew you couldn't resit...the MI3 is just to good lucking to pass up...although, I'll still be getting a Type R soon to compare...I just like the Type R...but how can anyone not ge an MI3?
Old 05-22-2007, 08:07 AM   #19407
Super Moderator
Marcos.J's Avatar
yeah i couldnt pass it up everybody was walkind by my table with theirs!! I sold one of my type R's but i still have the other one
Old 05-22-2007, 08:09 AM   #19408
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I think you're going to make the rear of your car way too wide doing it that way. The amount of shims you'll need to put in the back to get the right toe would make the back way too wide.
Jon Kerr is offline   Reply With Quote
Old 05-22-2007, 08:14 AM   #19409
Super Moderator
Marcos.J's Avatar
well, he is from south florida,he may be setting up the car to use a 235mm lola body on it!!!
Old 05-22-2007, 08:31 AM   #19410
yyhayyim's Avatar
Not really. What I mean is this: check out how the 4 front suspension blocks are set up, upper and lower. This give you 0 deg inboard toe. Just do the same for the rear and you'll have 0 deg rear toe, just like the front. All you need to do is adjust the rearmost blocks of the rear suspension. Then all 4 rear should be the same as the 4 front ones for 0 deg inboard toe in front and rear. Then add shims to the rearmost rear suspension blocks to get the toe you need. Its really the same thing. I have tried both ways and see do difference in toe. Its not wider at all, but it does give you that even look all around and much easier to set up and harder to get mixed up. The question is why does Schumacher instructions have us set them up as in the instructions--there must be some reason...anyways, you can try this and try and make your observations...seems to work fine and looks even better. That's how it is on Xray T2's also, and it works OK.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
