Old 05-21-2007, 01:52 PM   #19351
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Please don't go there. The amount of crap I'd get at our local races if they did that.
Jon Kerr is offline   Reply With Quote
Old 05-21-2007, 01:57 PM   #19352
AdrianM's Avatar
Originally Posted by yyhayyim
What type of aluminum is used on the Mi3 bulkheads, if we may know...I'm sure there are much lighter forms available...the swiss stuff is very light and strong...but the Mi3 bulkheads are beefeier and do feel a bit heavier than most...
6061-T6 alloy. Hudy uses 2024 alloy. Its not lighter or heavier but it is easier to machine. Them calling it Swiss aluminum is just marketing. There is no such term used to describe aluminum alloys. Duraluminum is also another meaningless marketing term.
Adrian Martinez
Old 05-21-2007, 02:03 PM   #19353
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
guys, i think we can just drill out the camber link mounts, and use the xray/tamiya style female threaded pivot balls. put a button head in from the top, and tighten it into the ball, and we're set. well, that is what I have planned for mine, anyway. If we use the losi style balls, we can probably still use the schumacher ball cups. they are both the common 4.3mm size.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-21-2007, 02:07 PM   #19354
seaball's Avatar
6061 is good general purpose aluminum. 7075 is quite a bit stronger (they are all about the same weight) but it is like 3x the price. you have to look at machinability and how well it will anodize as well. all things considered, schumacher made the right choice here.
Old 05-21-2007, 03:02 PM   #19355
AdrianM's Avatar
U3222 carbon battery straps are in stock.
Adrian Martinez
Old 05-21-2007, 03:17 PM   #19356
good luck to all the gang at the reedy. i only wish that i could hve gone.
gdcopbdcop is offline   Reply With Quote
Old 05-21-2007, 03:36 PM   #19357
Regional Moderator
Darkseid's Avatar
What??? You don't want "JK balls"...studs all over everbody's Mi3?
Okay, maybe not....but your idea was still great though!
TLR 22...Tamiya F104...
Old 05-21-2007, 03:41 PM   #19358
Regional Moderator
Darkseid's Avatar
Just got an early, unexpected, but VERY good email from Speedtech R/C.
Lets just say I feel...cough...cough........like I might have to leave work early tomorrow. Like right around the time my wife calls to say a brown truck just pulled up!
Old 05-21-2007, 04:17 PM   #19359
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Looking forward to receiving my car as well...I should have it on the track for some foam carpet testing soon!
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 05-21-2007, 04:27 PM   #19360
Jon Kerr's Avatar
Oh man. I'm gonna get so much crap from Randy about that.
Old 05-21-2007, 04:43 PM   #19361
Regional Moderator
Darkseid's Avatar
I'm always happy to help!
Old 05-21-2007, 04:46 PM   #19362
Moderator
Jon- What size are the OD's for the suspension pins for the arms and hubs?
SMC Racing
Old 05-21-2007, 04:52 PM   #19363
Regional Moderator
Darkseid's Avatar
Couple questions...
1. The website seems to be lagging behind stock levels a little, is it better to just have the LHS give you guys a call to see whats in stock?
2. How well does the battery strap work with the 'brick' style LiPo packs? The example shown in the manual seems like it wouldn't hold the pack in unless you tape the pack either to the strap or the chassis. In which case, why use the strap at all. Is it best to just go with the tape in your planning on using the 'brick' style?
Old 05-21-2007, 04:54 PM   #19364
Jon Kerr's Avatar
3mm I believe.
Old 05-21-2007, 05:06 PM   #19365
protc3's Avatar
i thought schumacher used 1/8th pins?
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
