Schumacher Corner
IMO, parts should not be perfectly free straight from the kit. I would prefer to need to message them a little to get them to move free than be too loose to begin with. Even if they fit perfectly out of the box, they're probably going to build up excess slop quickly. Also, on the rear hubs, you don't want the pin to be able to rotate in the hub. Only the arm. Some guys even use set screws instead of e clips to hold the pin in. The pin should be tight in the hub to reduce slop. If you've got the hub reamed out enough to where the pin spins free in it and it spins free in the arm, you'll have too much play. But at the same time, don't be worried if there's a little play in your suspension. If you have no play, even if there's no binding, your car will be very twitchy and hard to drive. It'll react to every little imperfection in the surface. But you don't want it sloppy loose all over the place either.
On the shocks, make sure you don't have a tear in one of your O-rings. When you put the shaft through, did you put shock oil on it? Also, when you work the shock up and down to ge the air out, how long are you letting them sit? If you don't have a vacuum pump, I let mine sit for a good 15 to 20 minutes, and move them up and down a few times every 5 minutes to make sure there's no air. And make sure they're filled to the top. Then when you put the bladder on, don't push too hard. Let the cap press it down when you screw it on. But if this is only happening on two of your shocks, I'd check for problems with the o-ring or the bladder first.
Today @ the Danish Nationals I saw one MI3 on the scales and it showed 1484 g, ouch! Remember this is with 5 cells...time to start a "How to shave off 100g on your MI3"-guide.
Looked good on the track though!
Thanks J. Kerr- about the rear hubs, I have ordered some extra ones to build as you suggest. This time I'll fit them tight and see what happens...
Will work on the shocks now to see if I have some luck...thanks for the advice...
Drivetrain: wow!!! Put my Mi3 and my Xray t2'007 next to each other- just the roller chassis and tires, and let them slide down my test ramp to see which is faster/more free & smooth...the Mi3 won 5 of 5...I couldnt believe it...very happy so far...the Schumacher help and support is really good, and every day I'm getting more confortable and pleased with my decision to drive Schumacher kits...best of all, they are 3 hrs away from me....local support is not a pblm and there are very good Schumacher drivers in Florida that could help me along the way.
[QUOTE=dawgmeat]
The pulley fences are VERY HARD to snap on but no reaming is required.
Originally Posted by yyhayyim
Had trouble with the center pulley assembly- on the manual it says put the caps on one way, with the indentation towards the outside...tried this but it doesnt fit- does this have to be reamed if needed, or can I just put them with the lip towards the outside and the indentation towards the pulley/inside?
I ran my Mi3 for the firwst time at B&B hobbies in Hudson FL. I used PW's FSEARA #3 setup and it was dialed. I added .5mm shims in the rear for a little more toe and it was perfect. It had loads of steering and corner speed. At the end of the day I was at 85% dual rate where I was normally at 95-100% eith my Mi2EC.
I also ran the new Core Racing 5000 LiPo pack. I was just as fast as anyone there and just kept repeaking the pack for every run. FYI, I used only 2200mah in a 5 min 19T run.
Adrian,YGPM!
Originally Posted by Alex Lopez
Adrian,YGPM!
Regional Moderator
Originally Posted by dawgmeat
thanks
Some consider it an 'eye for detail'...some consider it 'freaky'.
Does anyone know what springs come with the Pro-touring set?
Trader Rating: 32 (100%+)
Hey Guys I ran my Mi3 last night on carpet with rubber tires and it was great. I built the car with the kit setup and made a few changes and it was really good. This car is just plain awesome right out of the box.....good job everyone at Schumacher. Here are some pics of my car.....
Alex: did you practice any today by Coral Springs? How's the Novak GTB system comming along? We got to hook up one of these days to practice a bit after the Reedy Race. Back to building those rear shocks...
