Old 05-15-2007, 02:43 PM   #19081
dawgmeat's Avatar
Originally Posted by Marcos.J
arent you the only one doing that??
Don't type too loud you may just break 1 of those losi a-arms
dawgmeat is offline   Reply With Quote
Old 05-15-2007, 02:43 PM   #19082
protc3's Avatar
that only happens when you set your ride height.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-15-2007, 02:47 PM   #19083
AdrianM's Avatar
Originally Posted by protc3
hey adrian,
you coming out to b and b this weekend for some 1/12th still?i think we may get a decent class
Yup, running my db12R and Mi3.
Adrian Martinez
Old 05-15-2007, 02:53 PM   #19084
AdrianM's Avatar
Originally Posted by stegger
In the manual all but one of the setup's uses a 3mm spacer on the rear uprights but the wheels rub what do you guy's do to prevent this, do you shave some material off the ballcup's or do you use a different ballcup ?
Thats 3mm on the inner camber link in the rear to bring the ball down. We do not space the ball on the rear hub carrier up.
Adrian Martinez
Old 05-15-2007, 02:53 PM   #19085
protc3's Avatar
call me
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-15-2007, 04:27 PM   #19086
Skiddins's Avatar
Is there anyone who can convert the attached PDF into an editable PDF file?
I scanned it and set it up so it fits better onto a sheet of A4 paper but I cannot make it editable.
The original setup sheet looks good but is too small, it only takes up about 2/3 of a sheet of A4.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 05-15-2007, 04:33 PM   #19087
PW
PW's Avatar
Send a message via AIM to PW
Skiddins
You will need a full version of Adobe and put in all the text boxes and buttons, etc...
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-15-2007, 05:45 PM   #19088
protc3's Avatar
hey adrian,
lets run mod touring this weekend also.we can call p dub and give him play by play info while he is at home with his apron on.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-15-2007, 05:49 PM   #19089
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
If anyone in here is going to stick with the EC for a little while, I've got a bunch of parts I don't need and you can have. I've got suspension arms, RW spur gears, hinge pins, lay shafts, pivot blocks (aluminum and plastic), riser plates, sway bars, a bunch of diff parts, shock towers, steering parts, (there's a Corally aluminum steering rack in there that we tested with a while back) bearings, etc... There's a lot of money in stuff here but I can't really use any of it on the new car. A lot of these parts are used. Some may not be perfect, but they're free. PM me if you're interested.
Jon Kerr is offline   Reply With Quote
Old 05-15-2007, 05:52 PM   #19090
Jon Kerr's Avatar
hey adrian,
How rude!
Old 05-15-2007, 05:54 PM   #19091
Mopar's Avatar
Hey Jon, Burt gave my nephew Sean his back-up car so if you want he could use'm, unless you find someone more needy.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 05-15-2007, 06:17 PM   #19092
Jon Kerr's Avatar
We'll see if anyone on here who doesn't have a hook up needs them. If not, I'll give them to you at Reedy.
Old 05-15-2007, 06:26 PM   #19093
AdrianM's Avatar
hey adrian,
lets run mod touring this weekend...
I like my Mi3 too much to subject it to the way I drive with a mod motor. How about 19T?
Adrian Martinez
Old 05-15-2007, 06:46 PM   #19094
protc3's Avatar
sounds good
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-15-2007, 06:49 PM   #19095
mo
mo's Avatar
Skiddins
http://www.gearchart.com/setup/setup...0Mi3_blank.pdf
I did this one a while back
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
