Old 05-04-2007, 07:31 PM   #18736
Customworksking's Avatar
Trader Rating: 69 (99%+)
Lightbulb car
boy am I happy I dont have to wait for my mi3 till iic my in-door season is done and we only have dirt for out-door I wish the BEST to whoever has a car!!!
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 05-04-2007, 07:39 PM   #18737
AdrianM's Avatar
The diff height affects a few things and what you get from it depends on your roll center adjustment.
If your lower arm angle and dog bone angle are the same the end of the dof bone pretty much stays on one spot on the diff out put as the suspension moves. If you raise the diff from this position the drive shaft will plunge inot the diff output as the suspension is compressed. The plunge will cause an effect like antisquat where the suspension resists compression. This should give more forward traction in a straight line. In corner it will cause a reduction in side bite.
Since this setting depends on lower hinge pin height and lower arm angle what you get out of a diff height change varies with where your lower hinge pins are and what size tires you are running. On asphalt we liek the diffs high. On carpet with foam tires and low hinge pins we like the diffs lower.
This is a neat adjustment that we will be doing a lot of testing on in the future...stay tuned.
Adrian Martinez
Old 05-04-2007, 07:45 PM   #18738
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by PW
I think you made a mistake because Dallas is the only good team to get knocked off I think even the Magic would have knocked off the Heat
Detriot is the only team you guys should be watching.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-04-2007, 07:49 PM   #18739
protc3's Avatar
hey paul,how balanced is the Mi3 and what spurs can you run on it?can the Mi2 be converted to the Mi3?
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-04-2007, 07:53 PM   #18740
Regional Moderator
Darkseid's Avatar
Originally Posted by luke hobson
Has anybody tried puting a LiPo in thier mi3?
I've jst tried to test fit an orion 4800 in and if fitted either way around it fouls, both on the steering and the connectors are in the way of the bulkhead if you move the pack out to avoid fouling on the steering. Other than changing the ackerman i cant see a way to fit it.
Any ideas?
This is a post from over on the Schumacher forum. Has anybody tried fitting the Orion 4800 LiPo and experienced this problem?
For me, this is a serious issue! I only run LiPo, and while I own both the 3200 and 4800, I'd hate to think I need a special part just to use my 4800 pack. The obvious attention paid to the Orion LiPo was one of the first things I was excited about with the car. How can it end up not fitting when it seems the battery area was designed around it?
I know request for official statements are kinda frowned upon by some members, but I'm hoping Adrian or PW can shed some light on this issue since it isn't about the "it" topic.
Thanks in advance...
TLR 22...Tamiya F104...
Old 05-04-2007, 08:57 PM   #18741
Originally Posted by mini-dub
That shouldn't matter where the droop screws contact. There is never stress on that contact point when youre running so you're droop will not change. I guess there might be stress there if your car is setup poorly and the springs are super preloaded , but that's a different issue . The only stress there should be on the droop screw contact point is the weight of the arm.
The chassis is way lighter than most with all the cutouts, yet the car is still pretty stiff. I see a lot of potential for it being super stiff for foam tires with a carpet chassis and topdeck .
Thank's Weylin, I notice that efect when I was watching the suspention movements...and applying some pressure by hand on the tire we can see the chassi flex... In the EC there are no flex and I was some sort of concerned...
RFrancis is offline   Reply With Quote
Old 05-04-2007, 10:10 PM   #18742
Mopar's Avatar
My buddy Burt's ride is finnally finished, he hasn't seen it since mounting the rear suspension. Darkseid, I included a shot of the antenna post on the receiver that should be better than the previous one from my car.
Schumacher Corner-p5040012.jpg   Schumacher Corner-p5040011.jpg   Schumacher Corner-p5040010.jpg   Schumacher Corner-p5040009.jpg
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 05-04-2007, 10:12 PM   #18743
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
very nice ! maybe is time to get a micro receiver
Old 05-04-2007, 10:18 PM   #18744
Mopar's Avatar
That's the standard DSM receiver, if you look back a page at my car all you see is the wires tied above the micro DSM receiver.
Old 05-04-2007, 10:47 PM   #18745
Regional Moderator
Darkseid's Avatar
Thanks. Now I see what you were talking about.
Old 05-04-2007, 11:12 PM   #18746
PW
PW's Avatar
Send a message via AIM to PW
Just finished my 5-cell/brushless system and it came out pretty sweet. The 5-cell chassis is not ready yet, but you can see the stock chassis works great for 5-cell
I also made my own Ti-screw kit and turnbuckles and its spot on at 1452g and minimum is 1450g
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-04-2007, 11:18 PM   #18747
Jon Kerr's Avatar
Looking good PW.
I'm curious to see when the production kits hit the stores, who's going to be the first to strip all the purple and change the color of the car.
Jon Kerr is offline   Reply With Quote
Old 05-04-2007, 11:27 PM   #18748
Super Moderator
Marcos.J's Avatar
Hey Paul what ratio are you using with the 4.5 with 5 cells?? does 8.0 -8.8 sound about right??
also if you are going to superiors sunday can you bring my sphere??
Old 05-04-2007, 11:53 PM   #18749
AdrianM's Avatar
Mopar - Cut that rear wing down...its going to push with that thing back there. Protoform bodies are desigend to handle properly with a ROAR/IFMAR legal 40mm long by 20mm tall wing. Also, after cutting it down move it back about 8mm from where it is now.
Adrian Martinez
Old 05-04-2007, 11:57 PM   #18750
The Evicerator
Adrian, YGPM and email...
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
