Old 05-03-2007, 04:52 AM   #18646
Skiddins's Avatar
Originally Posted by mini-dub
Did anyone else have any issues with the new RP30 rims rubbing the rear arms a tiny bit? I don't know why they were, but I ground down the front and rear bottom edges behind the wheel.
I have about 1.5mm clearance between the wheels and arms, about the same as the EC.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-03-2007, 04:55 AM   #18647
Skiddins's Avatar
Originally Posted by Darkseid
Hey Skiddins: I got a hot tip for you that I've been sharing for quite some time over on the TA05 thread in reguards to the kimbrough medium. The one you using is the predrill model. The top hole on that isn't very high when compared to most servo arms.
Here's what you do, get this Kimbrough medium w/o holes. Instead of predrilled holes, it has 'outlines'. And one of these outlines is in the middle, but its up above the hole that your currently using.
If it will clear the upper deck, this should get you pretty much back to the original throw the car was intended to have with the kit arm.
Take a look at the pic I've attached and see how much higher the mounting hole is.
What you can't tell from my pictures is that in it's current hole, the nut on the back clears the top deck by around 0.5mm when the arm swings forward
THe problem is that the original items have their actual 'arm' very close to the body of the servo, where as Kimbrough's have their arm spaced away from the servo.
With the top deck having it's 'Y' shape at that point makes all the difference between hitting and missing.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-03-2007, 06:32 AM   #18648
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Skiddins - a shorter arm isn't necessarily a bad thing, since you don't have to turn your steering EPA or DR down you will get more resolution out of the servo. With the stock arm, no servo saver, I had to turn the EPA down to about 55 on the M11. If I went shorter on the arm the steering might be a tad slower, but more precise. I may give it a shot though to see how it feels.
you're exactly right. the new steering system is alot faster than our old dual bellcrank system, even if you used the shorter servoside hole (which i always recommended). i think short servo horns will be very common on the mi3. the only problem here is the pitch of the link from front to rear. when i had the prototype car, i ended up flipping the ball to the bottom of the belcrank to get a better angle, but i also reversed the plates, and spaced the whole unit up a bit to get everything lined back up.
i am hoping that the carpet chassis will have the servo moved out some so that we can use a big (heavy duty) servo horn and still clear the top deck (which is probably also going to give even less clearance). maybe they'll even move the cutout under the servo to function as a relief for the big saver. we shall see...
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-03-2007, 07:38 AM   #18649
Mr. McGoo's Avatar
to those that have ran the Mi3 on asphalt already - what changes if any have you made regarding setup? i will be making my maiden voyage this Saturday at the Bass Pro Series race in Mississippi - leaving at 2 AM on Saturday!!!!
McGoo
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 05-03-2007, 07:57 AM   #18650
Mr. McGoo's Avatar
well here are some pics of my ride.....
Here is what I ended up doing for my servo saver - it was a smaller Kimbrough and I used the top right hole and aligned it up to center - the steering link is angled down just a hair and I had to use a 3mm shim to make it work - I am looking for something slightly taller....
Old 05-03-2007, 08:02 AM   #18651
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Mr. McGoo if you send me your car I can put a bigger servo saver on for you and return it after the weekend. Very nice looking. Sure you will have fun.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 05-03-2007, 08:05 AM   #18652
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
McGoo.....Nice looking car and VERY nice looking body!! Your getting some skills with an Airbrush! Wish I could be there this weekend....Have fun!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 05-03-2007, 08:22 AM   #18653
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Damn wyd, you'll try anything to get a hold of a car won't you?
Jon Kerr is offline   Reply With Quote
Old 05-03-2007, 08:30 AM   #18654
Send a message via AIM to Alex Lopez
Well after putting my MI3 together last week, I was able to go out last night to Village R/C and do some testing with it last night. This car was box stock on old RP30's was faster than my MI2 EC and I thought my car was really good at this track. The car seamed to have the traction of my EC but with a lot more steering. I also tested with 5 cell and brushless( yeah brushless) and i thought it was amazingly fast.
Alex Lopez is offline   Reply With Quote
Old 05-03-2007, 09:32 AM   #18655
Regional Moderator
Darkseid's Avatar
Yeah, apparently he will!
Too bad thats what its come down to for most of us USA guys. Begging for cars cause we don't have ours.
TLR 22...Tamiya F104...
Old 05-03-2007, 09:37 AM   #18656
Regional Moderator
Darkseid's Avatar
Mr. McGoo: If I might ask, why are you looking for a taller arm if that setup is working for you? Do you feel your losing steering throw or something?
Oh, and your car looks great!
Old 05-03-2007, 10:39 AM   #18657
wyd
Tech Legend
wyd's Avatar
Well you never know maybe someone will actually take me up on the offer. I still have my trusty EC that works great and is very reliable so no shame in running it for another week or two.
Old 05-03-2007, 10:41 AM   #18658
wyd
Tech Legend
wyd's Avatar
Could of had one early but not going to the Reedy race so why hog up a car when guys can get them to showcase at that race. I can wait to have the best.
Old 05-03-2007, 10:52 AM   #18659
Mr. McGoo's Avatar
thanks and I have yet to try it out - i am sure it will be fine, but i would prefer the steering link to be completely horizontal rather than have a slight angle downwards......
i just want to make sure i am not loosing anything - i will do some testing this weekend and I will let you know if changing the servo horn works better.....
marc
Old 05-03-2007, 11:04 AM   #18660
theisgroup's Avatar
McGoo
good luck this weekend. I was going to go with Tim if the car came in intime, but oh well. not a biggy.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
