Old 05-01-2007, 10:32 AM   #18586
carkillaii's Avatar
If you are running foam tires you will need a front diff, the stiffer 2.5mm lower chassis, springs in the 30-33lb range for the front and 17-25lb range in the rear and the appropriate foam tires use by the locals.[/QUOTE]
thanks for the info some of us do use oneways and run faster times than with a diff , but i plan to have all diff, spool, oneway
carkillaii is offline   Reply With Quote
Old 05-01-2007, 11:40 AM   #18587
for spare parts, i plan on ordering 3 sets of front arms, 2 sets of rear arms,( i suffer from that strange malady of can't keep my car off the boards ), 2 sets of 4 degree castor blockes, 2 sets or rear hub carriers, and 2 each 114 th, 116 th, and 118 th 64 pitch spur gears. i dont like tape, so i am going to order a battery brace. that should take care of me for a while, and also other schuey drivers in our area. i am also getting some tires, rp-30's, and rp-36's. i would rather have the spare parts and not need them, then need them and not have them. the biggest must have on the whole list tho is a P-DUB bumper. with that bumper, i hopefully won't need all the parts that i am getting.
gdcopbdcop is offline   Reply With Quote
Old 05-01-2007, 11:45 AM   #18588
Hey, PW...you're a Shuey Guy...why no PDub bumper in the kit?
DOTMAN is offline   Reply With Quote
Old 05-01-2007, 12:02 PM   #18589
dawgmeat's Avatar
how long before we the mie manual online?
dawgmeat is offline   Reply With Quote
Old 05-01-2007, 12:56 PM   #18590
PW
PW's Avatar
Send a message via AIM to PW
That's not my call They should be in stock next week
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 05-01-2007, 01:21 PM   #18591
hmm...I guess I'll have a bumper before I have the kit
Old 05-01-2007, 01:36 PM   #18592
rcshark's Avatar
Send a message via Yahoo to rcshark
have fun at the races MI3
rcshark is offline   Reply With Quote
Old 05-01-2007, 01:50 PM   #18593
Regional Moderator
Darkseid's Avatar
Will you give us all a heads up when their in stock?
TLR 22...Tamiya F104...
Old 05-01-2007, 02:08 PM   #18594
Regional Moderator
Darkseid's Avatar
Quick question for PW or Adrian
On the Schumacher site, there is a "C/F battery strap & Alloy post"-U2985 listed under the Mi3 chassis parts list. But the picture next to it appears to be of the old battery strap from the Mission and Mi2. Is that just an old picture, because the post holes on those cars were offset, the post holes on the Mi3(from the pics I've seen) are in line with each other, which would mean the strap in that picture wouldn't work.
Or am I thinking of something wrong?
Old 05-01-2007, 02:50 PM   #18595
PW
PW's Avatar
That must be a mistake on the Mi3 list. The correct part number is U3222
Paul Wynn
Old 05-01-2007, 03:06 PM   #18596
Regional Moderator
Darkseid's Avatar
Okay, just making sure before I jump on it!
And now that I have the part# for the correct one, I'll have my LHS add it to the list of stuff they've already backordered for me with you guys.
Old 05-01-2007, 03:18 PM   #18597
Skiddins's Avatar
Is it me or is the only difference between the Mi3 shocks and the Mi2 EC shocks the small hole in the side of the cap?
These Mi3 shocks were even easier to fill than the EC version, got them just right first time
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-01-2007, 03:26 PM   #18598
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
Skiddins
yes i believe so that the only difference is the bleed hole they were much easier to build i also got them right the first time
has anyone tried harder springs in the front to gain rear tracktion sice theres plenty of steering
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 05-01-2007, 03:33 PM   #18599
Static_racing's Avatar
The Mi3 shocks also have a rubber O-ring in the shock collar. No more loosey Goosey!!
[COLOR="Blue"]Mike Kling[/COLOR]
[COLOR="Red"]"BIG FEATURES INC."
RED [COLOR="Black"]Cup Racing[/COLOR][/COLOR]
Team Driver For:
[COLOR="DarkOrchid"]Schumacher USA[/COLOR]
e[COLOR="DarkOrange"]X[COLOR="Black"]press Motorsports[/COLOR][/COLOR] "You've Been Tagged!!"
John's [COLOR="Red"]BSR [COLOR="Black"]Racing Tires[/COLOR][/COLOR]
[COLOR="Red"][FONT="Comic Sans MS"]MW [/FONT][/COLOR]Designs
TXD Skin Graphix "Skin 2 Win!!"
[COLOR="SeaGreen"]Final Thoughts Racing[/COLOR]
Static_racing is offline   Reply With Quote
Old 05-01-2007, 04:43 PM   #18600
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Depending on track conditions and setup, stiffer front springs can actually give you more steering at times. If the front is too soft, the car will just roll over and "dump" onto the outside front tires. A stiffer front spring will actually push the outside front tire into the track harder under hard turn in and yield more traction.
Jon Kerr is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
