Old 04-28-2007, 09:07 PM   #18496
dawgmeat's Avatar
Originally Posted by mo
Got the first run on the Mi3 today. Only got 1 practice run due to some electrical problems so I was testing every run. By the end of the day the car was really good. Got off to a shakey start in the main so I had to fight through traffic. Was in 2nd, chasing down the leader when I hit a corner pretty hard and jarred my battery loose so I had to pull it off. At least I had the fastest lap of the race.
good huntin' keep up the good work
dawgmeat is offline   Reply With Quote
Old 04-28-2007, 09:12 PM   #18497
PW
PW's Avatar
Send a message via AIM to PW
I actually got to build a production kit today and found a few things that differ slightly from my preproduction. After talking with Mo he said my setup was a little on the lazy side for tight tracks.
If you need more steering from my setup try moving the ball-stud to the forward hole on the steering block. I didn't realize, but I've been running the optional steering track-rod (shorter one) and that allowed me to run the back hole on the steering block
Another change for tighter tracks is you can shorten the rear camberlink for quicker response. I used a longer rear link for my setup because of the open layout. You can also lower the front r/c or raise the rear for more steering.
It's nice to finally get some more drivers running the car as this will speed up the setup process
Less than 2 weeks
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-28-2007, 09:34 PM   #18498
dawgmeat's Avatar
does thos apply to rubber carpet on a tigth track camber and going 1 hole up on the steering block
Old 04-28-2007, 09:37 PM   #18499
PW
PW's Avatar
i would suggest using the setup in the manual for rubber/carpet and then go from there.
Paul Wynn
Old 04-28-2007, 10:55 PM   #18500
Customworksking's Avatar
Trader Rating: 69 (99%+)
Talking car
so how did u guy's get your car's from the UK?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 04-29-2007, 01:26 AM   #18501
JayBee's Avatar
Trader Rating: 31 (100%+)
Has anyone posted the bearings & turnbuckle sizes/count yet for the MI3? If not could someone please do? What about the complete diff part#? Is there a P-Dub bumper for the car yet?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-29-2007, 02:17 AM   #18502
mini-dub's Avatar
Trader Rating: 16 (100%+)
When I last talked to PW he said they will have P-dub bumpers coming soon.
I'm not sure about a complete diff assembly part number.
bearing sizes:
10x15x4mm - x4
5x10x4mm - x8
5x8x2.5mm - x3 (2 of these are for the steering bellcrank, 1 is for the layshaft pulley)
5x9x3mm - x1
turnbuckle sizes:
35mm - x4
39mm - x2
24mm - x1
Happy?
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 04-29-2007, 06:42 AM   #18503
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
One day on the car and lots of good info coming in. I'm already trying to take it all in and started to wrinte stuff down already so I'm even more preppared for my new ride when it arrives.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 04-29-2007, 07:05 AM   #18504
HarshGuy's Avatar
Your car definitely looked good on the track, nice piece of equipment as well, looks very well built, tons of adjustability and easy to work on!
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 04-29-2007, 07:58 AM   #18505
Sigearhead's Avatar
Trader Rating: 68 (100%+)
U3223 is the part number for the diff.
Sigearhead is offline   Reply With Quote
Old 04-29-2007, 10:16 AM   #18506
JayBee's Avatar
bearing sizes:
10x15x4mm - x4
5x10x4mm - x8
5x9x3mm - x1
turnbuckle sizes:
35mm - x4
39mm - x2
24mm - x1
Happy?
I'm very happy buddy thanks You headin' up to Peel-It today?
Old 04-29-2007, 10:34 AM   #18507
JayBee's Avatar
Saweet
Old 04-29-2007, 12:18 PM   #18508
Regional Moderator
Darkseid's Avatar
So what do you guys think of the kit bumper. Will a P-dub even be neccesary?
TLR 22...Tamiya F104...
Old 04-29-2007, 12:21 PM   #18509
mini-dub's Avatar
Cant , I have a ski team banquet to go to we always have at the end of the year. I will probably put my first day on it tuesday or wednesday depending on weather.
Old 04-29-2007, 12:45 PM   #18510
JayBee's Avatar
Neccesary or not, a P-Dub bumper WILL be going on my ride
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
