Old 04-14-2002, 07:45 PM   #1831
Regional Moderator
Darkseid's Avatar
King-G: dispite RC Car Action's BS about how only CA made specifically for RC will do the job correctly, I do just fine with off the Wal*Mart shelf "Loctite Quicktite Superglue". Its quality stuff, but its cheaper than the "hobbyshop" Loctite, but works just as well. My tires never come unglued, no matter what brand they are and I use very little of it. It comes in a bottle with a tip that never clogs and a top that never gets stuck on.
You should try it, and stop wasting your money on that "RC specific" crap. Its made by the exact same companies' with the exact same formula. They just relable it and raise the price. At least thats my feelings anyway.
TLR 22...Tamiya F104...
Old 04-15-2002, 07:10 AM   #1832
RC Raptor's Avatar
Send a message via AIM to RC Raptor Send a message via Yahoo to RC Raptor
I have the same problem with the pinion digging in to the Deans battery bars. I just order the trinity bars. I could not find the Orion Bones.
We got rained out Friday night I went over on sat & Sun and watch the off road championship not all the teams were there. Team Trinity pretty much cleaned up Between Kinwald and Francis. I was hopeing to see team Schumacher there I heard roomer that one of factory guys race off road.
I have been reading a couple articles about the “one ways” what kind of changes or characteristics they provide and do you do just the front?
RC
I
RC Raptor is offline   Reply With Quote
Old 04-15-2002, 11:10 AM   #1833
Racer X's Avatar
CA does come in different formulas, mostly the difference is the water content. Off the shelf stuff has a higher water content so it won't bond as hard (so fingers can be pryed apart). RC glue has less water in order to bond tighter (if you ever stuck your fingers with tire glue, you already know what I'm talking about).
When gluing tires (N/A on preglued tires, but I always still run a bead of CA around the tire just to be sure), always wipe the tire bead with alcohol to clean the mold release off or the CA won't bond as well. Hope that helps...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 04-15-2002, 11:27 AM   #1834
Regional Moderator
Darkseid's Avatar
Well I guess the water content hasn't matter with the Loctiite brand I use. Like I said, that stuff never comes off. But it is made by Loctite, so I expect it to be good. For performance to cost, I still think its better than the hobbyshop stuff.
Anyway, I noticed today that my pinion is still fully engaged with the spur even though I had to move it over a little. So I wont even bother swapping the batter bar at that point on the pack.
Old 04-15-2002, 03:47 PM   #1835
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
JonSki.....Yes there is a special Layshaft for the Axis serries that used the one-way with the O-ring. I dont remember the part number but if you call up Schumacher they can get one out to ya....or I might have one floating in my parts box next time I see you or Rob I will give it to ya if I have it.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-15-2002, 08:40 PM   #1836
AdrianM's Avatar
All-Most spur gears (Schu, Kimbrough) are way wider than the pinions most ouf us use (Robinson, TiR, Trinity, RW/Schumacher). I run the inside edge of my pinions on the inside edge of my spurs and I can run any battery bar. If you run your pinions on the outside of the gear you will run into your batt bars with big pinion/spur combos. The Dean's 2 bars are the worst fit. Reedy, Echo, Orion and Trinity Bars fit a lot better.
I'm going to post pics of some new spurs and pinions we are importing tomorrow. You will be seeing a lot of these spurs and pinions in the months to come.....
Adrian Martinez
Old 04-15-2002, 11:29 PM   #1837
Send a message via ICQ to JesseT
Jonski, if you're handy with tools, just drill the hole. Even the material of the hardened shaft is quite soft.
JesseT is offline   Reply With Quote
Old 04-16-2002, 01:50 AM   #1838
Send a message via ICQ to MattW
Jesse, hmm, not sure about that. I thried to get some hardened TDS layshafts drilled and they were rock hard it just snapped drills.
MattW is offline   Reply With Quote
Old 04-16-2002, 03:38 AM   #1839
It can be drilled. I've done it a couple of times. Just don't try if your not confident that you can do it. Don't even think about drilling it with a dremel or any hand drill. If you can get a new shaft easily then buy one.
Old 04-16-2002, 09:21 AM   #1840
Regional Moderator
Darkseid's Avatar
Yes, the Schumacher spur is a good bit wider than my pinion.(I'm not even sure who this one is made by )
The Corally spur gears that I use occasionally are the only spurs that I have seen recently, that are thinner than the pinion.
Old 04-16-2002, 10:44 AM   #1841
Regional Moderator
Darkseid's Avatar
I just noticed this undertray and dirt cover on the Speed Secrets list for the Mission, but theres no pics availible on Schumacher's website. Has anyone actually seen these items? If so, what do they look like and how do they work?
Thanks.
Old 04-16-2002, 12:43 PM   #1842
AdrianM's Avatar
Everyone-Check out this press release. Schumacher USA now distributes a full line of Titanium products for all Sedans, Off Road, 1/10th and 1/8th cars.
http://www.wildhobbies.com/news/defa...&articleid=569
AZ Ron and other Phoenix Racers-There is finally a Schumacher Dealer in Phoenix!!!
Madd Maxx Hobbies
2633 N 28th St
Phoenix, AZ 85008
PH: 602 841 1579
DarkSeid-The undertrays are for rally racing or racing in the rain(Which they do all the time in the UK).
Adrian Martinez
Old 04-16-2002, 12:49 PM   #1843
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
Default VERY GOOD NEWS!!
Hi Adrian...Very good news indeed!
Do you happen to know how well stocked they are?
Are they stocking more sedan parts or offroad parts?
Thanks!
Ron
AZ_Ron is offline   Reply With Quote
Old 04-16-2002, 01:07 PM   #1844
AdrianM's Avatar
Press Release 2-Schumacher USA is now the exculsive distributor of RW Racing Machined Aceytl Spur Gears. This is by far the best spur money can buy but it costs the same as molded spurs.
http://www.wildhobbies.com/news/defa...&articleid=570
AZ Ron-He is currently stocking Nitro 21 parts as that is what the initial demand was for but if I were you I'd get together with any other local Schuey drivers, give him a call and let him know what you'd like him to stock.
Adrian Martinez
Old 04-16-2002, 02:12 PM   #1845
Regional Moderator
Darkseid's Avatar
AdrianM: any word from the head people at Schumacher as to why they decided to switch to all Yellow springs in the carbon kit.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
