Old 04-11-2007, 12:12 PM   #18091
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by minnesh
help here guys,
picked this car a few months ago with a losi xxxs
well up to date had no luck at all with the losi ,gearing is an issue
will i have the same problem with this car
or should i just not waste my time at all.
as i am running it in a 540 class
i also need a few parts to complete the car
advise will be greatly used here
thanks
minnesh .ps. does any one here run it in a 540 johnson classs
Minnesh.....Gearing I dont think will be an issue if you have the spur gear adapter. With the Adapter you should be able to run about any ratio you need. Im not sure how well Schumacher still stocks parts for that car they might have some you best bet is to check the Schumacher web site and see what they still have. The car was a good car back in its time I dont think you will be at any disadvantage running it in the 540 class. If you are running outside you might want to change the top plate to the Axis2 style top plate or lack there of and use the tie rods top plate system. You can also use them to set the belt tension a little as well and make the drive train more free and that would help in the 540 class. Also you can swap your rear bulk heads by using the tops on the bottom and the bottoms on the top that helps free the drive train up more. I hope this helps you out....if there is anything more just ask.
The 540 class isnt very big here in the US other then at the Tamiya Series races and only Tamiya cars race in that series.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-11-2007, 01:12 PM   #18092
PW
PW's Avatar
Send a message via AIM to PW
I did a quick screw count for the Mi3 for anyone that is looking to upgrade to Ti I posted every screw, but there will be places you don't want Ti.
Please send donations to my paypal account
Crap; forgot 2 M3x6 csk screws to hold the servo to the mounts
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-11-2007, 01:25 PM   #18093
PW
PW's Avatar
Updated list
Paul Wynn
Old 04-11-2007, 01:25 PM   #18094
Sam_Smith's Avatar
Send a message via MSN to Sam_Smith
Are you running TiR driveshafts PW? What does the car weigh with that setup plus shell on?
Sam
Sam_Smith is offline   Reply With Quote
Old 04-11-2007, 01:38 PM   #18095
PW
PW's Avatar
Sam
Those are the stock driveshafts
Kerr...That servo is the Futuba S9550
Paul Wynn
Old 04-11-2007, 01:40 PM   #18096
Regional Moderator
Darkseid's Avatar
Originally Posted by Jon Kerr
Dark- Get yourself a Spektrum Pro and you'll be completely crystal free and be able to use the smallest receiver out there
I've thought about it, but seeing pretty much 50/50 good/bad opinions on the original system on the boards and locally, has kept me from making the leap. Maybe the Pro system is better, but its still a big investment when I already have a good crystaless setup.
TLR 22...Tamiya F104...
Old 04-11-2007, 03:47 PM   #18097
protc3's Avatar
if you dont mind i would like it broken down into total number of threads amongst all the screws
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-11-2007, 04:05 PM   #18098
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I was just as skeptical too. I had issues with the original system. But I tried the Pro system after a little while and if anything, the car feels more responsive. I run it in my TC's, 1/12 scale, and 1/8 scale buggy. Not one problem since I switched to it.
You're right, it is a big investment. Especially with the micro receivers running $100. But in my mind, it was worth every penny.
Jon Kerr is offline   Reply With Quote
Old 04-11-2007, 05:25 PM   #18099
protc3's Avatar
yeah man,spektrum is great.ive been running it for a while.i will never go back to crystals
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-11-2007, 10:05 PM   #18100
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm still weary of the Spectrum stuff personally, gonna stick to RC03 until I stop hearing any complaints about it whatsoever...
Old 04-11-2007, 10:12 PM   #18101
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
I had nothing but problems out of my spektrum pro system from day one. I used it for about 2 months and went to the Futaba system and all my problems went away AND the Futaba system is a LOT faster than the Spektrum Pro.
If you use a Futaba then spend in the Fasst system!!
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 04-11-2007, 10:48 PM   #18102
Mr. McGoo's Avatar
I guess I was one of the lucky one regarding spektrum. I had mine on order when they first came out and I have had zero problems. I switched over to the Pro system a while back, but to be honest, I can't tell a huge difference.
In my offroad equipment I still use some of my original 2 year old Rx's - and both my wife and i can't complain one bit.
I love my spektrum equipment, especially the new small pro receivers!
Just my worthless $0.02
Schumacher USA | SpeedMerchant | Team Tekin | eXpress | Parma/PSE | KOPROPO America | Team Tamale | Liposack.com
~Team McGoo - Not sure of next big race - A-Main or Bust!!!!
~~McGoo Creations - PM me for for a custom quote
Mr. McGoo is offline   Reply With Quote
Old 04-12-2007, 12:37 AM   #18103
stegger's Avatar
I heard at our local club on tuesday night the ROBIN SCHUMACHER was at the BTCC at Stafford over the weekend showing of the Mi3, i also here that a LHS that i go to could have a rep visit some time this week
stegger is offline   Reply With Quote
Old 04-12-2007, 04:36 AM   #18104
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
I had the orignal one for my JR R-1 and from day one it worked perfectly and never gave me any problems. I still the radio and all the receivers for it today and they still work great. I'm using the Nomadio setup now but the same crystaless setup which is great. Its fast and upgradeable from simple downloads. Not the coolest looking radios but hell I only care if it works or not and it does.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 04-12-2007, 04:51 AM   #18105
Mopar's Avatar
PW, what brand are those Ti screws? Thanks.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
