Old 09-19-2001, 07:10 AM   #166
HarshGuy's Avatar
Yep STLNLST is right front oneway as well!
Well that makes it all different, I wouldn't takes less than 2 pounds of liver and a really big plushy beach towel.
HarshGuy is offline   Reply With Quote
Old 09-19-2001, 01:05 PM   #167
Racer X's Avatar
RTO: Thicker oil will slow down weight transfer but speed up the reactions in the car. If traction isn't a problem, by all means, go to thicker oil (say 60 with 2 holes) and it will liven the car up.
Racer X is offline   Reply With Quote
Old 09-19-2001, 07:30 PM   #168
rto997's Avatar
RacerX- thanks!! the car is quite awesome!! Traction is not a prob, so I will go up to 60!! Should be able to get me around the track even quicker!!
rto997 is offline   Reply With Quote
Old 09-20-2001, 10:37 AM   #169
Default chassis layout
Anyone notice the lack of electronics mounting room on the new mission chassis? Also, is it going to be a major pain to change spur gears as it appears there is a support on both sides of the spur? Will it allow for aftermarket spurs or will only Schumacher spurs work?
Mission Man
Mission Man is offline   Reply With Quote
Old 09-20-2001, 12:35 PM   #170
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Mission man I dont think that there will not be enough room for the electronics on the new car. As far as changing the spurs it looks like it might take a little longer now but not as bad as some other cars on the market, we will have to see once we get the car.
Kevin K is offline   Reply With Quote
Old 09-20-2001, 12:40 PM   #171
Send a message via ICQ to MattW
There isn't masses of room, but i think there should be enough.
I was talking about the spur gear issue last night. You shoudn't really need to change it that often, it shouldn't be any harder than anything else. I would think that aftermarket parts should still fit.
MattW is offline   Reply With Quote
Old 09-20-2001, 03:25 PM   #172
cornerspeed's Avatar
Should be plenty of room. Look at the 99 pro car and other makes of cars that have batteries on one side. With the Mission car, I think the electronics lay out will be cleener and easier also. The spur gear issue I don't know. Looks like a little work, but like others say, easir than other cars.
I don't see any part of the car that has a down side, as far as the pictures tell, just up sides.
cornerspeed is offline   Reply With Quote
Old 09-20-2001, 05:52 PM   #173
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
the 64pitch gear adapter will work. If anyone was wandering! lol I know thats the first thing I am putting on it.
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 09-20-2001, 06:45 PM   #174
AdrianM's Avatar
Spur Gear and Electronics Mounting on the SST Mission:
Yes the spur gear will be more difficult to get to but the decision was made to go this route in order to reduce layshaft bearing loading and improve gear mesh. The distance from the inner layshaft bearing to the center of the spur gear is almost 1" on all of the existing SST sedans. As the motor turns and the pinion meshes with the spur it is forced away from the pinion. The unsupported layshaft span multiplies the load against the layshaft bearings. The Mission put the spur between the bearings. This supports and locates the spur very well, reduces load on the bearings, reduces friction and maintains gear mesh more precisely. The benifits outweigh the drawbacks. This is an example of the Schumacher engineers sweating the details.
If you mount a big honkin LRP 7.1 in front of the motor and a stump puller servo you will have enough room to mount any commonly available non micro reciever on its side between the servo and the speedo. An Airtonics, Futaba, LRP, KO, JR or Novak micro reciever will fit flat on the chassis if you use a smaller LRP Quantum, Novak, Keyence or GM speedo.
Adrian Martinez
Old 09-20-2001, 07:00 PM   #175
Kevin K's Avatar
How soon till we see some real pic's of the car?? whats the release date of the kit? I cant wait much longer....hehehe. Hey Adrian are you going to come with Paul to the Novak Touring race in Wisconsin this january? Let me tell you the new place is awsome raced there 2 times already and its very nice well worth the trip.
Old 09-20-2001, 08:34 PM   #176
HarshGuy's Avatar
Originally posted by AdrianM
If you mount a big honkin LRP 7.1 in front of the motor and a stump puller servo ...
That very descriptive sentence is cracking me up
Old 09-20-2001, 11:10 PM   #177
STLNLST's Avatar
Trader Rating: 17 (100%+)
Is the Tekin G-10 bigger than the 7,1? If so what's the word for that....LOL
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 09-21-2001, 05:33 AM   #178
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Adrian, did you mention an estimated release date in good ole U.S of A ?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 09-21-2001, 09:10 AM   #179
Racer X's Avatar
Its my understanding that it will be the end of October...just in time for my Christmas list (I've been a very good boy)
Old 09-21-2001, 12:00 PM   #180
AE_Racer's Avatar
Send a message via AIM to AE_Racer
I beleive Adrian said about mid November a few posts back
AE_Racer is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
