Old 03-11-2007, 03:16 AM   #17701
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Good job Mr. Cockswell!
Jon Kerr is offline   Reply With Quote
Old 03-11-2007, 05:06 AM   #17702
matt_h's Avatar
I have been running the same Schumacher ceramic bearings since I built the car (10 months) and they are still as smooth as when I built the car. Just put them in and run them. Don't spray them out at all, just run them and they will keep getting better.
Thanks wyd
Thats brilliant, when they are are like that, it seems money well spent.
What do i do if they get wet, i race on asphalt in England - its going to get wet!
Matt
matt_h is offline   Reply With Quote
Old 03-11-2007, 06:16 AM   #17703
stephen hilton's Avatar
Arrow
Originally Posted by matt_h
Thanks wyd
Matt
i wouldn't run ceramics in the wet! but if you have to (after you have finished) take em out and flush them out with bearing blaster and then use a good oil to lube em. they should be ok then!
stephen hilton is offline   Reply With Quote
Old 03-11-2007, 07:30 AM   #17704
IslandBwoy's Avatar
IslandBwoy is offline   Reply With Quote
Old 03-11-2007, 07:32 AM   #17705
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Originally Posted by IslandBwoy
you forgot to type Rashad
Old 03-11-2007, 09:25 AM   #17706
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Thanks wyd
Matt
Well that I have never had happen but if it was me I would more than likely take them all out of my car and wipe the outside off with a rag. Then I would after I cleaned the outside of them off let them soak in some WD 40 or something similiar. I still hate to do that but water may make them rust or loose the factory grease.
I never spray bearings and blow them out. We then finally get crunchy I just replace the bad ones.
I had a huge motor builder from the 80's and early 90's never to spray out motor bearings and for the most part they will never go bad to often. Well he was right as it never happened to me.
I find that when you spray them out they get dirt inside the bearing and get rough feeling. I leave the factory grease in them as it will loosen up in a few runs.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 03-11-2007, 10:37 AM   #17707
oh right my bad so how do you clean them?
when you run on carpet?
Old 03-11-2007, 10:48 AM   #17708
wyd
Tech Legend
wyd's Avatar
I'm lucky as I have asphalt year round.
If I had to clean bearings from running on carpet and I have in the past I would take off the dust shield and then spray them out. I would relube with a little thicker oil and run them.
Another thing is to take the dust shiled off one side of the bearing only and leave that the shiled on the other side. I would then put my nearings in the hibs so that the shield side it out and the open part in in so it is protected more.
WHen I ran carpet alot I bought some cheap bearings instead of running really high end ceramics.
Old 03-11-2007, 01:23 PM   #17709
Skiddins's Avatar
Originally Posted by aus jd 2703
hey guys,
i clipped a wall lol and destroyed an out drive of my one way, can i buy just the out drives? or do i need to buy a new oneway? cheers guys its all perfect except for one out drive being jewed but buy the drive shaft (wich all it did was eat the blade luckily)
thanks guys was just a bad day at a new track for me lol
You can get them seperately, but I can't remember the P/N offhand.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-11-2007, 03:20 PM   #17710
rcshark's Avatar
Send a message via Yahoo to rcshark
hay I want to use sand paper or a drimal on my chassis to finish it. How do I do this right with what grit to do it right or can i use a hasp?lol
rcshark is offline   Reply With Quote
Old 03-11-2007, 03:52 PM   #17711
mini-dub's Avatar
Trader Rating: 16 (100%+)
If I want to make CF edges look nice I use 100 grit sandpaper first to round the edges first (how much you round them is up to you), then use medium CA and spread it on the edge with a toothpick. Some people use thin CA and run it down the edge while holding the chassis vertical, but I always screw that up if I try it that way. Also, Losi CA seems to dry the shiniest. Then I use 400-600 grit sandpaper to smooth out the CA.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 03-11-2007, 04:24 PM   #17712
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
your already done talking about the halloween classic with me ?
Nice run for seaball.
wallstreet is offline   Reply With Quote
Old 03-11-2007, 05:30 PM   #17713
mini-dub's Avatar
lol I ran out of things to say about the race
Old 03-11-2007, 08:20 PM   #17714
PW
PW's Avatar
Send a message via AIM to PW
Nice run for Seaball finishing 3rd in the A-main Stock at the ROAR Carpet nats!
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 03-11-2007, 08:22 PM   #17715
chubbspeterson's Avatar
NICE WORK SEABALL! and the rest of the guys from the GATE!
Mike Demone
7-Eleven, National Accounts Manager
Ridgemont, CA, 90026
"I vowed to never let this happen.."
chubbspeterson is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
