Old 04-07-2002, 10:21 AM   #1756
Default P2K2 - burning up
When I first had my mission I put it at 17, with a Spitfire stock motor...the car was embarrising it was so slow. Slow off the line, slow to spool up...etc
I switched to a 20t pulley and it was much better. I switched to a P2k2 and left it at 20, with the 24/86 gearing and it gets pretty hot (it is *new* still <5 runs).... I would say the track is shorter, with more hard turns then sweeps.
-s
_neas_ is offline   Reply With Quote
Old 04-07-2002, 12:04 PM   #1757
jonski's Avatar
Trader Rating: 230 (99%+)
Hey guys....rejoining the Schumacher guys after sometime away (off-road and running the Xpress sedan). But I have come to my senses and got an Axis 2 now. I have some questions.
If you run the Axis 1 top plate on the Axis 2, do you need to shim it up at the motor mount? It seems lower there.
Also, I am looking for a carpet set-up. The carpet is med traction, but bumpy.
Thanks guys and glad to be back with Schuie
Jon
jonski is offline   Reply With Quote
Old 04-07-2002, 07:55 PM   #1758
Default Gearing issues
When I first put my car together (Mission) I went with the 17tooth pulley, 24t pinion, stock 86t spur. I stuck in a stock motor and it was slowwwww....
Put in the 20t pulley and it was much better, keeping right up with the stock TC3's, XXXs's on the track at the time.
However, my stock motors are getting way too hot. I double checked the charts in the manual and I am about the 'middle' for the stock spur and the 20t pulley.
I went to a 23t pinion, and that didn't help much..and then a 22, not much help either.
What is everyone else running for stock, on a short, twisty track?
pulley/spur/pinion
-s
Old 04-07-2002, 11:59 PM   #1759
Sigearhead's Avatar
Trader Rating: 68 (100%+)
neas, if your laptimes are on par with the rest of the guys who drive other cars then I wouldn't really worry about the motor getting a little bit hot, if you went down and it didn't help and you went up and it didn't help the reason your motor might be getting hot might be your driving style but like I said if your keeping up or passing other cars on the track who cares if you motor runs a little hot, mine always do.
Sigearhead is offline   Reply With Quote
Old 04-08-2002, 01:27 AM   #1760
Send a message via ICQ to JesseT
jonski:
Yes you do have to, unless you do like I did and shave 2mm of the upper bulkheads on the front and rear. Thats better in my opinion. The upper deck is definately worth it especially on the carpet.
AZ_Ron:
The plastic drive shafts are not CVD.
Darkseid:
Have you considered getting some hex screws...
www.fastener-express.com
They have really good screws for the Mission. Like purple aluminum countersunked hex screws...
Everyone:
When posting and discussing setups, please state if they are for carpet or asphalt.
BR/ JesseT
JesseT is offline   Reply With Quote
Old 04-08-2002, 06:38 AM   #1761
Regional Moderator
Darkseid's Avatar
neas: It looks like your right about where you should be in your gearing for stock if your keeping up with everyone. I think we're all just going to have to get used to really hot stock motors. It looks like all modern day stockers are pushing the limits so much that they can't help but get a little toasty.
You might think about buying or building yourself a car stand with a fan under it, to get that motor cooled down quickly. Especially if you don't have to wait long for you next heat race comes up. You don't want to have to go back out with a already hot motor.
TLR 22...Tamiya F104...
Old 04-08-2002, 07:59 AM   #1762
Les! at MDI said he was at 92/23 for stock, I just emailed him back to confirm that...
I know they get hot, but this is really hot....the other guys at the track noticed it as well...we all though it was a bit much.
I used to have a MVP in my T3, and that thing would be blazing hot...this is hotter.....
Old 04-08-2002, 08:36 AM   #1763
Regional Moderator
Darkseid's Avatar
neas: I really don't understand then. By what you have said, at one point you made it to a final ratio of 8.21.(86/22 x 2.1=8.21 final) Yet you still say your stock motor was blazing hot? I would start checking my car for drag if I were you. Because thats just not normal.
Old 04-08-2002, 09:55 AM   #1764
Yah, I have been thinking about it...possibly my ESC?
But, the ESC doesn't get hot at all....and from my experience a screwed ESC just acts as a hot box and eventually fails, but doesnt always pass the problem onto the motor...
It seems fast, battery life is good, motor comm and brushes don't get worn quicker then normal or anything.....just really really hot.
Old 04-08-2002, 10:17 AM   #1765
Regional Moderator
Darkseid's Avatar
Well esc is cool and if the brushes aren't wearing prematurely and the comm isn't showing burn marks, I would say just make sure there is nothing dragging on the chassis. If not, then just keeping on rolling. I'm at a loss for what the problem could be.
Any of you guys have any picks of your Missions? I remember seeing some on here a while ago, but those are way back on the thread by now. If you still have the pics, can you guys show them again.
Old 04-08-2002, 10:59 AM   #1766
Send a message via ICQ to MattW
Dark, Here goes again
This was taken after i built it, hasn't changed much. The LRP's got a worlds kit on it and the top deck is bolted on with Titanium screws now.
MattW is offline   Reply With Quote
Old 04-08-2002, 11:45 AM   #1767
Ian S's Avatar
heres mine, not as neat looking as Matt W's cause i cant fit my HUGE receiver anywhere apart from the top deck
Ian S is offline   Reply With Quote
Old 04-08-2002, 02:28 PM   #1768
Regional Moderator
Darkseid's Avatar
Thanks for reposting them guys. I'm waiting for my Mission to arrive and I need to look at something to hold me over till SpeedtechR/C can get it to me around Wednesday!
I've already read the articles in R/C Car, Xtreme, and Car Action about a dozen times each. So I needed to see some other cars.
Old 04-08-2002, 04:05 PM   #1769
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Here is a pic of my car's electronic set-up
http://photos.yahoo.com/bc/trickstir...c=ph%26.view=t
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-08-2002, 04:34 PM   #1770
Regional Moderator
Darkseid's Avatar
Hey Kevin K you need to go to options and open your Yahoo photos up to the public. Everytime I tried to use your links, it said I had reached a restricted area.
You have to set the folder so that everyone can view it.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
