Old 02-19-2007, 12:38 PM   #17491
Originally Posted by Jon Kerr
Moving the front arms is always kind of a balancing act. Move them back to shorten the wheel base always seems give a more aggressive feeling on entry. But too far back and the car would just continue to turn coming out of the corners. It wouldn't square up at all and I'd have to counter steer coming out of the corner because there would be so much weight forward, it couldn't transfer it back quick enough. I like having the front arms at med/long position and the rear arms med/short. That always seems to be where I end up with the best balance. You may also want to try the longer pivot blocks on the front of the car. (I don't know what the part number was off the top of my head.) They're a slightly longer block you use for the forward, front pivot block. They'll give you forward arm sweep. I really liked that on the car a lot. It gave a good amount more usable steering through out the corner.
I think the 3 degree pivot blocks you are talking about is U1989
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 02-19-2007, 01:28 PM   #17492
qcrc's Avatar
Does anyone know of any place in the Omaha.NE area that stocks Mi2EC parts?
Schumacher Cars
Speed Passion Powered
qcrc is offline   Reply With Quote
Old 02-19-2007, 02:02 PM   #17493
CRASH's Avatar
Trader Rating: 26 (100%+)
I take it you are going to the race in Omaha this weekend? I will be running a MI2EC. As far as I know there are no places around here that stocks Schumacher parts. What a shame, hopefully this will all change with the release of the MI3.
Later,
CRASH is offline   Reply With Quote
Old 02-19-2007, 03:51 PM   #17494
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Thanks Jon. I will experiment next time I can race.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-19-2007, 04:13 PM   #17495
i honestly think it would be nice to have more rear toe options, just limits the mi2 ec imo.
what does the mi3 have in the way of rear toe adjustment?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 02-19-2007, 04:17 PM   #17496
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Unlimited rear toe adjustment on the Mi3. The EC you have a choice of 2 (Stock with alloy blocks) 1.5 with the plastic Mi2 blocks mounted with the ridge facing out, or 3 with the ridge facing in. Not too bad, but not as adjustable as the Mi3 is.
Jon Kerr is offline   Reply With Quote
Old 02-19-2007, 05:14 PM   #17497
Skiddins's Avatar
Can't you just order directly from Schumacher USA?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 02-19-2007, 07:55 PM   #17498
fast track's Avatar
we stock all parts plus Schumacher USA is in our backyard. I would be glad to ship them to you anytime you need them.
Fast Track Hobbies
fast track is offline   Reply With Quote
Old 02-20-2007, 06:41 AM   #17499
PW
PW's Avatar
Send a message via AIM to PW
Here is Tim's Snowbirds rubber tire setup This is for highbite carpet/CS27GL with Paragon.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 02-20-2007, 07:10 AM   #17500
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
PW....is that setup on the 2mm chassis or the 2.5mm chassis?
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 02-20-2007, 07:14 AM   #17501
PW
PW's Avatar
Stock EC (2mm)
Paul Wynn
Old 02-20-2007, 07:18 AM   #17502
Kevin K's Avatar
Thanks....I saw "Stock EC" on the sheet but I just wanted to make sure.
Old 02-20-2007, 07:30 AM   #17503
CRASH's Avatar
Question on toe-in vs toe-out? I have always ran 0, just curious as to what the benefits are of running toe-in vs toe-out vs 0*
I noticed on Tims rubber tires setup he is running 1* toe-out, just curious as to what this actually does for the car?
Thanks,
Old 02-20-2007, 07:43 AM   #17504
Kevin K's Avatar
Crash....Toe in at the front of the car will make the car more stable on the straight and help the car track straight....it will also help the car finish off the corner better...more exit steering. Toe out will do the opposite....make the car wonder on the straight and be less stable....but it will help the car get in the corner better....but steer less off the corner. I would think that he was running toe out because he was using the spool and he needed the car to get into the corner but then could use the spool to get out of the corner....thats just my guess.
Old 02-20-2007, 08:00 AM   #17505
PW
PW's Avatar
Perfect explaination Kevin
Actually Tim used Toe-in at the front. Tim would have to post his reason...Tim?
Paul Wynn
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
