Schumacher Corner
Originally Posted by AdrianM
Its that kind of talk that will get you wearing a dress again
But this time it really wont be fair, an Mi3 on asphalt vs an xray... ha. Did you want to be more handicapped than vegas? LOL
Aww man A-lo you're running mod? Does that mean I have to run 19t again and get launched off the track every main? Damn.
Originally Posted by AARON YOUNG
Dont forget me guys!
...you guys need to be nice to STLNLST this month.
Originally Posted by mini-dub
Does this mean I get to race against Clint??? ANOTHER DRESS CHALLENGE!! WOOO HOOO!!
Hi All
Is their any alternative than running the normal 1-way in the mission 1.
The 1's in the mission 1 use those small 1-way bearings and die quickly.
Can run one the heavy duty 1-way's in a mission 1, or what other 1-way alternative could i use ?.
Also with regards to servo speed.
Futaba 9650 , 62.5 oz , 0.11 sec @ 6v
Futaba 9402 , 111 oz, 0.10 sec @ 6v
Futaba 3305 , 123.4 oz , 0.20 sec @ 6v
What differences would you see on the track in a touring car ?, one is quicker with less torque, and 1 is slower with more torque, would you see the 0.1 sec ?
Also is the 9650 a good servo, its small and light as well. is quick but less torque.
Thanks guys
Thanks guys
Originally Posted by MoonTrap
Hi All
Thanks guys
Thanks guys
Kevin
Originally Posted by Kave
The 9650 is a 12th scale servo, if you are looking for a servo for your sedan get a 9550, and out of the ones listed there the 9402 is the only solid option.
Kevin
Kevin
HAHAHA!!! I rememeber that. You should run mod if your up to it, but if you do, we need to find a wheeler to run 19t.
Tech Legend
Trader Rating: 51 (100%+)
Alex do you have a setup from the series race you just ran? Your car was very consistant by looking at your times for each race. At that race was your setup and PW's pretty close?
I know the new car is coming out soon but unitl then I like to try many different setups to see what they offer me vs. some other setups I have tried.
Brian
Brian
Brian
Brian
Tech Legend
Team Schumacher was able to supply me with a standard asphalt set-up that they use almost everywhere as a starting point for asphalt racing. I only made a few minor changes that seemed to have had drastic effects on the car's performance. I changed wheelbase(moved the rear arms all the way back), messed around with camber( -1front, -2 rear), spaced out the rear wheel 1mm, ran the carpet tower up front, and thats about it. I'll post the set-up if it will help.
Appreciate the help.
Originally Posted by STLNLST
are you gonna run some gieco stickers
HAHAHA!!! Ill be sporting Team Caveman decals on the ride at the Reedy race. I'd dial you in if you were still on the team. But since we're both minorities in the R/C scene, I might be able to dial you in.
would be great if you could IM me the standard setup of schumacher and your setup of the race.
thanks
are the suspention risers need to run foam, I am also looking for a good foam setup
