Old 01-22-2007, 04:50 PM   #17176
Send a message via ICQ to piorc
Heys guys! which aluminium wheel hexes do u use on your old Mi2?
the HPI pro 4 fits?
tks
piorc is offline   Reply With Quote
Old 01-22-2007, 05:17 PM   #17177
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Originally Posted by AdrianM
The tamiya plastic one will fit . I dont know about the xray ones.
FYI, I have been racing the Mi2EC with the stock shock collars for over a year. I have NEVER had the collars move during a run. This is a case of fixing something no one has a problem with. Yes they are a little loose on the bodies but they will not move unless you move them.
Me too i never had had a promblem either. I seen guys used 2 of them together one up-side down to lock the bottem in place. Hope this helps
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 01-22-2007, 05:23 PM   #17178
Super Moderator
Tony Rivas's Avatar
Default mi2 hubs
the HPI pro 4 fits?
tks
try this http://www.racing-cars.com/usa/produ...ecnumber=42748
Call the schumacher they should have the part in
Old 01-22-2007, 05:26 PM   #17179
yeah! but im from brazil! and here my hobby shop have the pro 4 hexes! and is cheaper than schumachers
Old 01-22-2007, 05:49 PM   #17180
Super Moderator
Tony Rivas's Avatar
piorc-I'am not sure if the pro-4 hubs fit. You might have to try them out!I just saw the pics on the pro-4 they might fit there bolt on. You better hurry the pro-4 kit is an Discontinued Kits.
Old 01-22-2007, 05:51 PM   #17181
Super Moderator
Tony Rivas's Avatar
Originally Posted by wyd
Pic of my new Speed 6 body on my MI2 EC.
nice body (paint job) of course!
Old 01-22-2007, 07:21 PM   #17182
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Thankyou. I know my buddy is trying hard to improve and do more wild paint jobs for me all the time.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-23-2007, 10:26 AM   #17183
mattb's Avatar
ive personally never got on with the alu hexes from Schumacher ive been using some old associate alu hexes with the Allen screw to tighten it up never been a prob
even with weight oh and btw Schumacher is the new mi3 gonna be heavier than the mi2ec?
my ec has 80 grammes of weight strapped to it and i have loads of heavy stuff in it lol
mattb is offline   Reply With Quote
Old 01-23-2007, 10:59 AM   #17184
mattb's Avatar
hay guys is there someone out there that could give me some strarter tips or good set up for indoor carpet open with med grip i have the caret spec towers
lol
i need help asap if possible im rubbish on the set up and would like to beat my m8 lol
Old 01-23-2007, 01:37 PM   #17185
Default New MI2 EC Driver Need Help!
Hi,
I just picked up a used, but looks to be in pretty good shape MI2EC Carpet Spec. I was going to tear it down and rebuild but it looks like it's got most of the mods everyone spoke of on the form. I've been trying to wade thru some ~500 pages of info. but for those of you that know what are the significant mods I need to be aware of?
i.e.
1) the car already has the HPI spring retainer mod.
2) plastic spacer for bump steer to save the front cvds.
anything else?
3) I've seen the centerpoint steering mod, is this necessary?
4) Do I need to buy different toe in blocks for the rear? How do you change it?
5) Also with the front/rear suspension blocks, can you do squat and dive adjustments with shimms? just looks like the tolerances on the hinge pins are really tight (nice) don't want to bend anything.
I need a good set-up for tight indoor carpet stock foam track. please help, i want to start spanking the xray guys at my local track up here in MI.
Also I noticed Weylin's 19t IIC set-up was basically an EC foam-spec on Rubber tires. Is this correc? will my car be good in the 19t Carpet Rubber car? or is there too much to change?
Electro-MAX RC is offline   Reply With Quote
Old 01-23-2007, 01:40 PM   #17186
PW
PW's Avatar
Send a message via AIM to PW
lol
Best to start here: http://www.racing-cars.com/images/Te...am_cw_2006.pdf
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 01-23-2007, 01:47 PM   #17187
PW
PW's Avatar
Originally Posted by Electro-MAX RC
Hi,
Maybe seaball can repost his Cleveland or Novak race setup for you.....
Paul Wynn
Old 01-23-2007, 01:55 PM   #17188
Thanks, but how about any mods to the kit? and toe-in adjustments?
Old 01-23-2007, 03:49 PM   #17189
nemisis's Avatar
personally i wouldnt change the toe blocks as they are set to 2.5 degrees this is a mid setting and is a good place to keep it. personally i wouldnt try adjusting the car two much i found it can be sensitve to wat you change on it when i got mine i had a tough time trying to get it set rite.
nemisis is offline   Reply With Quote
Old 01-23-2007, 05:30 PM   #17190
Skiddins's Avatar
Hi,
i.e.
anything else?
I believe Weylins setup was an asphalt car but with a carpet chassis.
1) Not absolutely necessary but good anyway.
2) Again, good
3) No idea what you mean, must be a foam thing
4) The only way to add some rear toe is to fit the Mission/Mi2 rear pivot blocks for in front of the rear wishbones, takes it to 3deg, you can't reduce it at all.
5) Yes you can, I've definitely had 0.5mm difference between the front and rear of a wishbone, can't remember having tried 1mm or not.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
