Old 01-22-2007, 05:54 AM   #17161
Hiya
The only 2 types of shock adjusters that i can get are Tamiya and Xray ones. As it was stated above that the tamiya ones are a bit small, will the xray ones from the T2 work on the schumacher EC shocks ?
MoonTrap is offline   Reply With Quote
Old 01-22-2007, 06:42 AM   #17162
AdrianM's Avatar
Originally Posted by MoonTrap
Hiya
The tamiya plastic one will fit . I dont know about the xray ones.
FYI, I have been racing the Mi2EC with the stock shock collars for over a year. I have NEVER had the collars move during a run. This is a case of fixing something no one has a problem with. Yes they are a little loose on the bodies but they will not move unless you move them.
Adrian Martinez
Old 01-22-2007, 06:55 AM   #17163
Default Form Help
Hi.
I'll be receiving an MI2EC any day now from an auction I won -I can't wait to start running this car. For those of you that know this thread well, can you send me a link back or tell me ~what page in the past the form starts focusing on the MI2EC. I don't have a lot of time to wade to over 500 pages of information. Thanks!
Electro-MAX RC is offline   Reply With Quote
Old 01-22-2007, 07:13 AM   #17164
I haven't had any problems with my stock collars either. Except if I hit them when making adjustments to the links or something. I've heard someone say to score the threads with a knife to keep them from turning freely.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 01-22-2007, 08:35 AM   #17165
Jonny Aird's Avatar
Yeah sorry Adrian I meant the Tamiya Alu ones won't fit, didn't know about the plastic ones.
XRAYs won't fit either.
XRAY | Hudy | Spektrum | Moorespeed | MB Models | Serpent |APE
Jonny Aird is offline   Reply With Quote
Old 01-22-2007, 11:17 AM   #17166
wyd
im running 1mm above the cf riser with no diff spacers.
white springs, 30wt oil all round,1 degreee camber, 4 degrees caster 1 degree tou out on front standard rear and all in links in top standard hole and an extra 1mm on the out rear camber link.
droop im unsure as ive had trouble getting consisten measure ments
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 01-22-2007, 12:20 PM   #17167
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally Posted by aus jd 2703
wyd
I would go to 35 oil in the front and rear and 1.5mm of rear droop and 3mm of droop in the rear. Silver swaybar in the front and black swaybar in the rear. Put the riser plate in under the rear diff only. Then take your car and try it out. This should get your car to rotate a little more. Shocks in the front in the middle hole on the tower and in two holes from outside on the rear towers. After you run and if you need more rotation you can try laying your rear shocks in one hole and or try shortening your rear wheelbase 1mm. If more if needed you can do 1mm shorter rear wheelbase and in on the rear shocks one hole. (I have done these and each one helps a little as this is what Adrian at Schumacher has helped me with)
To find your droop put a batter in your car and set you ride height to 5mm. Then keep you ride height gauge thier and slow raise the car like from the center of the chassis. When the wheels come off the groundcheck the ride height. The differance between the two is your droop. So lets say you have 5mm of ride height and your wheels come off the ground at 6.5mm you have 1.5mm of drrop.
I use the associated blue alum ride height gauge.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-22-2007, 03:42 PM   #17168
wyd
Tech Legend
wyd's Avatar
Pic of my new Speed 6 body on my MI2 EC.
Schumacher Corner-dk-air-desgin-mi2-ec.jpg   Schumacher Corner-dk-air-design.jpg
Old 01-22-2007, 03:56 PM   #17169
TVMRocket69's Avatar
Send a message via AIM to TVMRocket69 Send a message via Yahoo to TVMRocket69
The Rainbow Warrior.
BTW Brian I'll have my EC in 2 days.
Bob Walker Jr.-Sponsor's-
AnswerUSA-RC Team Driver, G's R/C Raceway Team Driver, RBMods Team Driver, Kosmic R/C Fuel Team Driver, MurfDogg Motorworks Team Driver, Serpent S811B, Serpent S811t, MurfDogg Powered V-Desizn Carpet Ripper 5
TVMRocket69 is offline   Reply With Quote
Old 01-22-2007, 03:58 PM   #17170
wyd
Tech Legend
wyd's Avatar
Nice. Glad your getting it so soon. Should go to Horshem with us for some rubber tires on the carpet.
Old 01-22-2007, 04:29 PM   #17171
Trader Rating: 240 (99%+)
SWEET! I need some new bodz!
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA, Race Ready Products, Garcia Graphix and Integy***
Fred Perkins is offline   Reply With Quote
Old 01-22-2007, 04:30 PM   #17172
Question. Do the CVD's for the MI2 fit the EC.
Old 01-22-2007, 04:34 PM   #17173
wyd
Tech Legend
wyd's Avatar
Old 01-22-2007, 04:36 PM   #17174
wyd
Tech Legend
wyd's Avatar
Not 100% sure on that but I think you can but need to shim a little. Like I said I'm not 100%on that.
Old 01-22-2007, 04:46 PM   #17175
pug 205 gti's Avatar
ive just seen those pictures of the mi3.it looks like one step for schumacher and one giant leap for the racing brigade. very nice
all the lastest touring cars are designed and built to such high standards and due to this rc racing at all levels are going to rep the benefits.
i think its going to bring much more exciting racing at world level as the all the manufactors have closed the gap on the brand that sort of broke the mould.
with the playing field levelling out i do look forward to seeing a british car rule the roost.
when is the car due to make its appearance ??
pug 205 gti is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
