Old 01-21-2007, 04:27 PM   #17146
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
congrats to Alex Lopez on his first win with the ec winning 4 out of the six races(reedy format)
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 01-21-2007, 04:47 PM   #17147
Skiddins's Avatar
Good job, any links to the results/photo's etc?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-21-2007, 06:03 PM   #17148
Jimmy Morris's Avatar
Alex Lopez 0 Points
Mike Bruce 1
PW 2
Troy 2 Tie goes to PW for Faster Overall Round
Dave Martin 5
Tim Potter 7
Greg 10
Tony P 11
Tim C 13
Carlos 15 Carlos Wins TB with a 20 5.06 over Adrians 20 5.07
Adrian 15
Mike Abraira 16 Mike wins TB with a 21 5.07 over Tims 20 5.12
Tim K 16
Sean 18
www.superiorhobbies.com
Jimmy Morris is offline   Reply With Quote
Old 01-21-2007, 07:20 PM   #17149
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
http://www.fseara.org/2007results/mdiresults.php
The results from the whole weekend....
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 01-21-2007, 07:34 PM   #17150
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Looks like PW had the two fastest runs of the day with 22 laps. Alex was super consistant with all his times being so close to each other. Great job to all you guys laying it down with the EC this weekend.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 01-21-2007, 09:42 PM   #17151
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by oldfartjohn
I need to go pick up an MI2..
Take a look.
Schumacher Mi2 EC
Jon Kerr is offline   Reply With Quote
Old 01-21-2007, 09:47 PM   #17152
Jon Kerr's Avatar
Originally Posted by roadrashracing
hey john, how did you do that steering mod on your car?
Everyone else, I am looking for some parts:
http://rctech.net/forum/showthread.php?t=145282
Take the Steering plate from a Tamiya 415 (not the new steering they have, the older one with the CF plate) and drill 2 holes, 10 mm apart. (5mm out from dead center on each side) Mount it using flanged bearings and a .5mm shim underneath in the center Ackerman hole on the bell cranks. You'll need to re adjust your link from the servo to the steering also as this will make the bell cranks point inward slightly instead of being parallel. I felt it gave the car more steering all around and smoothed the front end out.
Old 01-21-2007, 10:43 PM   #17153
Hi Guys
Does anyone know if the Tamiya shock collars would fit the EC shocks, as the ones on the EC shocks tend to loosen easily altering the ride height. I know Marcos posted above about using the HPI ones, but i am unable to get the HPI ones, only the tamiya ones.
MoonTrap is offline   Reply With Quote
Old 01-22-2007, 01:37 AM   #17154
rcshark's Avatar
Send a message via Yahoo to rcshark
hay my shock rings dont move much anymore I just let the grim build up and and they quit moving!
rcshark is offline   Reply With Quote
Old 01-22-2007, 02:00 AM   #17155
rcshark's Avatar
I wonder if you could but some silicone on the shocks and it would help keep the collors in place or use some lock tight or something on that ordor?
Old 01-22-2007, 02:13 AM   #17156
hey guys,
had a warm up meet as our season starts in 2 weeks.
i had a drive of a mates xray t2 and he drove my ec
and we both agreed they felt the same just my car lacks mid to exit corner steering.
id normally think its my driving but my mate is a pratty good racer so i would like to make some changes to get some more mid to exit corner steering.
so any suggestions for changes?
sorry i dont have a copy of my current set up to post.
thanks guys
btw i run a one way and have had bad luck with spools
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 01-22-2007, 03:47 AM   #17157
Jonny Aird's Avatar
Hello everyone,
MoonTrap - The Tamiya shock collars are a bit too small in diameter so they don't fit.
RCShark - Shock oil on them helps slightly but not much, when I first got my kit I tried using a tiny bit of threadlock to keep them where I wanted, although they were really hard to move afterwards. Your best just to go for the old Mi2 shock collars if you are having problems. The new car will come with o-rings in the collars, happy days!
aus jd - Its quite hard to tell without knowing your current set up, it could be a few different things. Too much front droop, too thin shock oil, too little castor, rear spring too soft, additive/tyre prep.
Hope this helps guys
Jonny
XRAY | Hudy | Spektrum | Moorespeed | MB Models | Serpent |APE
Jonny Aird is offline   Reply With Quote
Old 01-22-2007, 04:30 AM   #17158
wyd
Tech Legend
wyd's Avatar
Originally Posted by MoonTrap
Hi Guys
I use the collars for the JRXS. They are direct fit and have the rubber o ring in them.
Old 01-22-2007, 04:43 AM   #17159
Skiddins's Avatar
Originally Posted by aus jd 2703
hey guys,
thanks guys
Front Toe In or parallel.
Change front roll centre, can't remember whichh way off hand.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 01-22-2007, 04:47 AM   #17160
wyd
Tech Legend
wyd's Avatar
Skiddins
Well if he takes out a spacer under the front blocks the car will roll a little more and a little more steering overall.
Aus jd other than the graphite riser under the suspension blocks how much more spacers do you have added for your roll center?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
