Old 01-03-2007, 09:52 PM   #16891
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Alex Lopez
YES!!!! You?
Oh yeah. I'll be there. See ya then.
Jon Kerr is offline   Reply With Quote
Old 01-03-2007, 10:06 PM   #16892
Jon Kerr's Avatar
Originally Posted by aus jd 2703
if we were to make our own sway bars what material is it? steel stainless or aluminium? im thinking steel cause it powder coated and stainless work hardens (sorry my dad is a sheet metal worker by trade so u pick these things up) just wouldnt mind trying a variety of bars.
also what and how did you guys dye your diff pulleys? and can i dye my rw spurs?
cheers
I'm pretty sure the sway bars are steel. Not 100% sure on that though. If you're going to make your own bars, be sure make them identical on both sides or it could tweak the car.
As far as the dyed pulleys, I used black Rit Dye. But in hind sight, I wouldn't do it again. You have to warm up the dye and put the plastic parts in it for it to take. I may have gotten them too hot while dying them, (I don't think I got it any hotter than you're supposed to ) but it seemed to warp the pulley a little. That diff always felt like it had a high spot. The same with any RW spur gears I did. Someone else may have a better way of doing it though.
Old 01-04-2007, 04:34 AM   #16893
Skiddins's Avatar
I wouldn't bother with the dye, without it it makes it easier to see any crud that is caught in the teeth etc, if it's black you could have something caught in it and not know.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-04-2007, 05:34 AM   #16894
CRASH's Avatar
Trader Rating: 26 (100%+)
This question is for the people who run the MI2EC Carpet Spec. Are you running the kit chassis and top deck or are you using a BMI or other chassis?
Thanks,
CRASH is offline   Reply With Quote
Old 01-04-2007, 06:53 AM   #16895
Speedie's Avatar
cheers
I made a set of sway bars I used piano wire from the local hobby shop.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 01-04-2007, 07:31 AM   #16896
mattb's Avatar
Originally Posted by AdrianM
Yup, run the stock kit setup. I would remove the diff risers and the plates between the motor/layshaft mounts though.
The bigger challenge for you will be to learn not to pull the trigger as hard and use full throttle less often. I learned this little trick to help get started in Mod.
Say the world "One" The amount of time it takes you to say this word is how long it should take you to go from neutral to full throttle with a mod motor. If you cannot complete saying the word "One" in the time it take your car to get from one corner to the next then you should not use full throttle there.
There are of course exceptions but this little mental aid helps to force you to apply throttle smoothly when you get started.
Another tip is to reduce you brake endpoint (brakes are your friend ) so full brake slows the car but does not get it out of shape.
Be sure to lift off the thorttle and brake earlier then your are used to. Then work you way up to later lifting and harder braking.
that helps alot thanks
is there any other tips for stock users?
mattb is offline   Reply With Quote
Old 01-04-2007, 09:36 AM   #16897
Solara's Avatar
Trader Rating: 16 (100%+)
Thanks,
I use the stock 2.5mm up and down....and credit to the "TUBE" design (instead of the super low CG Xray style).....even with 2.5mm carbon, the chassis is STIFF enough for carpet.
Unless you have the BMI one for cheap or even free...I think the stock one are more then stiff enough for foam carpet. BTW....I was referring to carpet FOAM spec. If you are talking about rubber carpet, you can try the stock 2mm up and down, but I think @ IIC, mini-dub used the 2.5mm lower with 2mm upper and won the 19T race.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 01-04-2007, 11:22 AM   #16898
Suspended
McSmooth's Avatar
Anyone running the new car at the Novak?
McSmooth is offline   Reply With Quote
Old 01-04-2007, 11:33 AM   #16899
hey guys,
i have just built the EC and it looks great but i have a quick question do the hinge pins that go through the wishbones to the toe in blocks front and rear sit parallel to the chassis, or do they slope down toward the chassis at the front of the pins?
Cheers
LEE UK is offline   Reply With Quote
Old 01-04-2007, 12:10 PM   #16900
Solara's Avatar
Originally Posted by LEE UK
hey guys,
Cheers
The thickness of the purple alum pivot block should all have the same thickness......if you are not using different thickness shim underneath the pivot blocks, they should all be parallel front to rear.
Old 01-04-2007, 12:22 PM   #16901
this is what i thought but the blocks are marked L and R and the only way you can get the two R`s nd L`s on the right side is to have the front of the pin sloping towards the chassis which i know from experience of other cars is wrong
i also have to have the front blocks with the R and L facing upwards
Old 01-04-2007, 01:09 PM   #16902
Skiddins's Avatar
Because the blocks are used on both sides and front and rear ignore the markings, I believe they are a throwback to previous cars.
Look at the exploded diagram in the manual, the rounded edge always faces out, now make sure that the hole for the pivot pin is towards to top of the pivot block. Does this make sense so far.
It should be the same all the way around the car, remember, hole to the top.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 01-04-2007, 01:18 PM   #16903
AdrianM's Avatar
No they are running EC's
Adrian Martinez
Old 01-04-2007, 01:43 PM   #16904
Colin Price's Avatar
Default Pivot block pictures
Hope these help a little on the pivot block question, just remember that the letters face down to the chassis.
Schumacher UK - GM - SOREX - PBM Racing
Colin Price is offline   Reply With Quote
Old 01-04-2007, 10:43 PM   #16905
AdrianM's Avatar
TTT
Adrian Martinez
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
