Old 03-23-2002, 04:09 PM   #1666
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
neas-
Check to make sure the spur gear adaptor is not hitting the upper deck. There was a run of adaptors that were slightly thicker..you may have one...I know I did.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 03-24-2002, 04:49 PM   #1667
Default Re: ...before I give up on the whole thing...
Well, it seems to be the alloy pulley???
I put the stock one back in and it the sound went away...
Anyone have any trouble with the alloy pulley (20t)? You need to CA the sides onto the pulley correct?
-s
Originally posted by _neas_
I posted awhile back about a problem I was having with a clicking noise when I let up on the throttle, or when going in reverse.
While not a solution, I got an ESC that doesn't have reverse...which is better for racing..but the problem still exists. I didn't mess with it too much the past week, because I was waiting on the grey belts, when I got them in I took apart essentially the entire car and put it back together with the new belts...I thought doing that might allow the problem to work itself out.
It didnt
Basically it goes like this: when I give it throttle it accelrates fine but as I let up it makes this horrible clicking sound till the motor stops. It has made this sound through two motors and two speed controls, so I will rule them out.
Any ideas?
its not the batteries rubbing, or the mesh of the pinion spur, all the bearings involved are smooth, the diffs run smooth, the belts are new, no teeth are missing on the pulleys/diffs/spur/pinion...nothing seems to bind.
I have the alloy pulley on there, and I am going to dig up the stock one and see if that helps...
Also, how do I get 64p ratios from the stock numbers (84,24, I think)? I have the adapter, and want to rule out the stock spur and the pinion I am using...
_neas_ is offline   Reply With Quote
Old 03-26-2002, 05:44 PM   #1668
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
ttt
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 03-26-2002, 07:15 PM   #1669
STLNLST's Avatar
Trader Rating: 19 (100%+)
racer X- See ya back at home sometime soon. Time to get ready for some outdoor racing.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-27-2002, 07:49 AM   #1670
AZ_Ron's Avatar
Trader Rating: 16 (100%+)
Default Ok, more questions
Hey guys...A few more questions for you Axis 2 setup Gurus...
What is the best/easiest way to set droop on these cars, and what is a good starting point, and what affect does droop have on the handling?
Also, what affect does Anti-Squat have on handling?? What do you recommend for Anti-Squat on a medium grip asphalt surface?
Thanks!!! Sooner or later, we'll get these suckers dialed in!!
Ron
AZ_Ron is offline   Reply With Quote
Old 03-27-2002, 12:20 PM   #1671
AZ_RON--
droop has a few effects on the handling, first droop can effect how much the car will lean in a turn allowingthe car to transition from left to right quicker and vice-versa.
Second droop also effects the amount of traction your car has during specific points while running.
--- Too little front droop (less up travel) takes away on-power steering.
---- Too little rear droop reduces rear traction while braking.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 03-27-2002, 12:27 PM   #1672
AZ_Ron's Avatar
Default Setting droop
So what is the best way to set the droop on an Axis2?
I thought I'd seen someone post on this forum to take the wheels off, and lay it on a flat table, and adjust the droop to where the arms just touched the table...we seem to be unable to get them this low, as the inside of the arm starts to touch the chassis. When someone say ##mm of droop, where are you measuring that from? Is that will the car on a flat surface, and then measured from the bottom outside of the arm to the table, or ????
Thanks!!!!
Ron
Old 03-27-2002, 01:36 PM   #1673
Pick up an associated droop guage, they only cost $2 and work perfectly.
Old 03-27-2002, 02:02 PM   #1674
AZ_Ron's Avatar
Default Droop
What is a good setting for droop to start with for a medium bite asphalt track, running rubber tires...??
Thanks!
Ron
Old 03-27-2002, 02:04 PM   #1675
big al's Avatar
Hey AZ!!
Hopefully this will end your droop dillema.
Place the car on a flat even surface (full electronics) after you've set ride height,camber and tweak. With an exacto knife find the midpoint of the upper susp. mount and lift very slowly. The wheel that leaves the surface first is out of whack. Adjust and repeat 'til both wheels leave the surface at the same time. You need to set your up-travel first before doing this.
Now setting the droop(most A2 guys keep it between 1-2mm,3-4mm if you're outdoors on uneven pavement) is just as easy.
Again place the car on even surface blah blah blah. Now slowly raise the car until all "up-travel" is used. Measure that height with your ride height guage. The difference between your ride height and your full up-travel is the droop. Joila!! I like to keep about 2mm up front and 1.5 in the rear. If I need to take off just a hair ttraction or add a hair off traction , I will adjust the droop first. My next steps would be to change lower shock locations,upper locations then spring rate.Not at the same time,but in that order until I get a good setup.
I've played with anti squat, but never really could feel a difference. So, after a few months of worrying about it, I just went to 0 and haven't touched it since. Take care--Al
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 03-27-2002, 08:10 PM   #1676
Great info Big Al!!! What do you mean by Travel up? How do you adjust Travel up? What does Travel up effect? Anyone???
Doggs_03 is offline   Reply With Quote
Old 03-27-2002, 08:36 PM   #1677
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Doggs.....He is talking about a way to measure your Droop by measuring your UP-Travel. If you read what he says its a good description on what it does and how to do it.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 03-27-2002, 08:43 PM   #1678
big al's Avatar
You can increase up-travel by lenghtening the shocks and adjusting for more droop. The car will get very sluggish and have a lot of body roll. Not good!!
Old 03-27-2002, 09:18 PM   #1679
Thanks Fellas!! I assume that you use the threads on the threaded shocks to get both wheels to lift off the ground at the same time??? If one tire is out of whack(you know it lifts up 1st)do you adjust the threaded shock on the same side that is lifting up 1st, if so which way???
Old 03-27-2002, 09:21 PM   #1680
Also i'm still a little confused about this up travel thing!!! Hey Caramba!!!
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
