Old 11-25-2006, 05:18 PM   #16606
Skiddins's Avatar
Originally Posted by jo90
Off to carpet wars tomorrow. Using LRP Vtec 24's and a large (LARGE) track (36m straight).
Any tips on gearing the new CO27 ?? And have any of you used tyre warmers prior to your heat ?
At Rug Racers which is a bit smaller, the Monsters run at around 7 FDR.
I would go a couple of teeth bigger as the CO27's are supposed to have more torque.
You'll have to try it along side a Monster to see the difference.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-26-2006, 10:30 AM   #16607
Hello All.,
I have a bit of a dilemma, i recently was running a mission, which was fully hoped-up. I have recently changed to an mi2 which is also fully hoped-up with the temu chassis, riser plates, low shock towers etc.
I am however 0.5 seconds a lap off the times i used to get with the mission, using same electronics and such. Why is the mi2 slower ?
MoonTrap is offline   Reply With Quote
Old 11-26-2006, 11:43 AM   #16608
AdrianM's Avatar
Originally Posted by MoonTrap
Hello All.,
Its a very diffrent car from the Mission. None of the Mission setups work on the Mi2 or Mi2EC.
We need some more info from you to determine what you need to do. Can you post your setup in detail?
Adrian Martinez
Old 11-26-2006, 11:28 PM   #16609
Hello,
I have tried different setups to no avail, I have spoken to a few people that have the mi2EC now, and they say that they too noticed the same going from the mission to the mi2. Yet when they went to the EC their speed came back.
Below is the current setup on the car, Iíll try give as much detail as I can,.
Car is running a co27 , with a gtx speedo, and ib4200 cells.
Front:
Schumacher blue spring
Trf shocks, 40wt, 2 hole
1.5 deg camber
middle lower camber link
second inner hole on shock mount
outer hole on arm
5mm ride height, 1mm droop
Rear
Schumacher white spring
1.5 deg camber
second outer hole on arm
5.5mm ride height, 3mm droop
This is on foam tires, on asphalt, using temu chassis, riser plates, and lower shock towers, track is bumpy.
Old 11-27-2006, 04:37 AM   #16610
jo90's Avatar
Default Carpet Wars Round 1
Adam Rogers totally dominated modified in the finals of the CW4 round 1. Top job and well done to him.
I managed to qualify 9th overall in stock and took 7th overall at the end of the finals
Sponsored by SerpentUK, ModelTech & MTroniks
S400 / MTroniks IP6 / Team Brood / KO Propo = Loads of fun
jo90 is offline   Reply With Quote
Old 11-27-2006, 06:40 AM   #16611
Skiddins's Avatar
Adam's been at Rug Racers getting ready for CW, and dominated there as well, I believe he's only had one final where second place was on the same lap
Come on then John, what was your setup?
I was pitting next to Adam at the first RR and asked a lot of questions and watched them experiment with settings etc.
Skiddins
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 11-27-2006, 08:02 AM   #16612
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Props to Seaball for the good finish at Cleveland this weekend. Let get the report on the race when you get some time.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 11-27-2006, 10:19 AM   #16613
Trader Rating: 36 (100%+)
nice job seab....if you have pics and stuff you need hosting space you can email me and I'll launch them on Pitspace
congrats.
Nexus is offline   Reply With Quote
Old 11-27-2006, 01:37 PM   #16614
STLNLST's Avatar
Trader Rating: 17 (100%+)
Just stopping by to show some love to my Schuie peeps.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-27-2006, 03:58 PM   #16615
nemisis's Avatar
can anyone help me i am runnin a mission and i am in need of a better servo one with quicker response and more speed can anyone help i am not looking to spend a ridiculos amount on one thanks
nemisis is offline   Reply With Quote
Old 11-27-2006, 04:40 PM   #16616
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
Hey Nemisis,
I run a Futaba S9402. It's a reasonably priced, and quite fast metal geared servo. I've been running it for two full years racing now (in mod class) and haven't had to replace gears in that period - so durability is also excellent.
Cheers
Scott
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 11-27-2006, 05:37 PM   #16617
nemisis's Avatar
does any wone know wat shell will handle well on the mission i currently run a nemisis on my ec but as the ec is broke i am back to old school
cheers
Old 11-28-2006, 06:46 AM   #16618
Skiddins's Avatar
cheers
PF Mazda 6
I used to run an HPI Lotus Elise shell on my Mission as the wheel arches were almost perfect.
Mission-Elise
Mission-Elise#2
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 11-28-2006, 06:55 AM   #16619
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
I use both the Protoform Mazda 6 and the Parma Type M on my MI2. Both are great handling bodies on asphalt.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 11-28-2006, 10:56 AM   #16620
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default 06 us indoor champs
thanks guys. the weekend was solid. i ran it similar to my novak setup, and it was super. i felt that i had a tq car for the first day. but missing the first round, by loosing a pin in the layshaft, meant that i had to drive safely for the resort in the second. the car actually tightened up the next day, for q3 and q4, before i really had a chance to catch it. i drove tighter in those rounds, but it was my q2 that held up for an 8th place qualifier. almost all of the top ten runs were done in on the first day, which is odd for an indoor race.
in the main, i tried using a little more sidewall to get some steering back, but it wasn't the right answer. the good part was that it was really easy to drive with, which i was able to do for five minutes, while alot of others got ugly.
i think this setup will be great at trackside, in just over a month, for the novak race. you listenin' out there jimnew? the results, pics, and some video will be posted soon on rc50.com. go on over and check it out.
- ray dinklehoff -
(setup attached)
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
