Old 11-19-2006, 09:00 AM   #16561
AdrianM's Avatar
Originally Posted by wyd
Any results from the Region 4 race? Not sure if the race was Sat or Sun to just checking.
PW TQ'd. He's getting ready for the main now.
Adrian Martinez
Old 11-19-2006, 09:08 AM   #16562
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Great thanks for the info.
I have a question on your setup I'm using. I tried some of the suggestions you mentioned and each did exatly what you said. If you where getting too much body roll what you look at changing first on your setup?
My thoughts where in no certain order
less overall droop
raise the roll centers front and rear 1mm
stiffer springs
The setup is really fast for me and my lap times where again better this weekend that last. Running 1mm shorter in the arms did make the car rotate the best for me so I left that. RIght now the main differance between my car and my buddy who won is the amount of body roll in the corners. His car is driving alot flatter than mine. Lap times are ever so close but his is easier to drive fast conssistantly vs mine.
Thanks again
Brian
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 11-19-2006, 09:20 AM   #16563
AdrianM's Avatar
less overall droop
stiffer springs
Thanks again
Brian
Yeah, we have been trying to get our car to roll even more. It seems to go faster the more it rolls. We use stiffer sway bars to allow for fast transitions even though it is rolling.
All this rolling creates more grip and corner speed with less stress on the tires.
Body roll is not a bad thing if it is fast but if your car is hard to drive I would try a stiffer front sway bar first. You could stand up the front shocks. This will make the car stay flatter but it will react faster.
Just keep an eye in your average lap times. Fast laps mean nothing...its your average lap times that mean you are getting faster or slower.
I suspect that you will lose corner speed if you take out too much body roll. We have been testing softer than 14lb springs (Schu White) and the car gets even faster
FYI, I bet you buddy would be faster if he could get his car to roll more but don't tell him that...lol!
Adrian Martinez
Old 11-19-2006, 09:38 AM   #16564
wyd
Tech Legend
wyd's Avatar
I will try that and keep an eye on my average times. I did bump up my a lap this weekend. Ended up going a few seconds faster. When my buddy runs I work alot more and in return normally push hard and get faster.
Will see what happens next week with these little changes.
Old 11-19-2006, 09:39 AM   #16565
protc3's Avatar
yeah adrian,i have been running 12.5 lbs springs and the car keeps getting better.it does require lighter shock oil the lighter i go but hell,fast is fast.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-19-2006, 09:42 AM   #16566
wyd
Tech Legend
wyd's Avatar
Very intersting. Guess I will be trying some new stuff and see how it goes. I have a great base setting thans to Adrian and it does suit my driving style pretty well so it has really picked up the pace of my car the last 3 weeks.
Old 11-19-2006, 10:51 AM   #16567
protc3's Avatar
the car works great.adrian and paul are very meticulous when it comes to setup. they will be a big help to you.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-19-2006, 11:11 AM   #16568
Brian's chassis sure had plenty of roll yesterday. rear wheel was lifting 1/4 to 3/8 ever corner.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 11-19-2006, 11:15 AM   #16569
AdrianM's Avatar
Now, thats not normal. The wheels should not be lifting at all.
If you are hiking up wheels the opposite corner from the lifting wheel needs to be stiffer in sway bar, shock position, spring or oil.
Adrian Martinez
Old 11-19-2006, 12:24 PM   #16570
Alex_kipper's Avatar
hey guys, just wondering. How long do you guys break in your diffs?
thanks in advance
Alex_kipper is offline   Reply With Quote
Old 11-19-2006, 01:27 PM   #16571
Super Moderator
Marcos.J's Avatar
Trader Rating: 150 (100%+)
Paul Wynn TQ and finished 2nd (because of me ) Paul easily had the win but due to a dumb mistake on my part I cost him the win!! Paul Im sorry and next time Ill keep my eyes a little more open and Ill try to move a little quicker!! Is just that your new car was moving SOOO fast! but again sorry for the mistake!
Old 11-19-2006, 03:02 PM   #16572
AdrianM's Avatar
thanks in advance
We don't at all...just run them. If they feel rough when new its the thrust bearing...call us and we will send you a new (U1954) one n/c. If the diff has the U1954 thrust and it feels rough then its the rings. Sand them with 600 grit wet/dry sand paper on both sides until you see an even pattern across the rings on both sides. The diff balls last a long time.
Adrian Martinez
Old 11-19-2006, 04:07 PM   #16573
protc3's Avatar
HACK!!!!!!!!
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-19-2006, 04:46 PM   #16574
wyd
Tech Legend
wyd's Avatar
Its hard for me to see that but he wasn't the only person to tell me that. I will start with a stiffer sway and work on the other stuff. Maybe stiffer springs. Funny thing is the car was fast but if the wheels stay down more it will be easier to drive fast..........and that is good.
Old 11-19-2006, 04:49 PM   #16575
wyd
Tech Legend
wyd's Avatar
True. I will say that is why I really like running for Schumacher because those guys are so willing to help you with your setups. I call them and they always make time to help me out and if I can't call them I post on the computer and they are online they help as well as some of the other team drivers. Really enjoy that about Schumacher is the more personalized service.
Paul and Adrian do a great job for Schumacher.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
