Old 11-13-2006, 04:05 AM   #16531
peded's Avatar
I was wondering if the Schumacher SST Pro 99 Is still competitive out there with the modern cars its racing againest?
peded is offline   Reply With Quote
Old 11-13-2006, 06:54 AM   #16532
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
It will have a little less adjustments of some of the newer cars out but to be honest I don't see why it can't be a pretty good car. I know my 99 and my 98 to this day where some of my best Schumacher cars to date and the MI2 EC. Those to me where the best cars IMO.
I think with up to date motors and batteries and with the newer tires out nowadays I would think you could still be pretty competitive but I'm sure what parts Schumacher still has in stock for that car. I would give it a try before buying a new car or run this one til you save enough for a MI2 EC.
ST Racing Concepts (STRC)
Old 11-13-2006, 07:21 AM   #16533
Originally Posted by aus jd 2703
ok i dont have full version of adobe so ill just right it down hear (sorry for the long post.)
front:
35wt oil
3 whole piston
blue springs
no sway bar
shocks layed down (outside whole on the bottom inside on the shock tower)
bout 1.5's camber
4's caster
one way diff
caber link in the upper position.
all riser plates in.
middle wholes on th bell crank with about 2.5mm of spacer under neath
all steering ball studs are on the tip of the arm except the noted bell crank and on the inner whole of the steering knuckle
2mm droop 5.5mm ride height
medium short wheel base
0.5's toe out
Rear
shock are second whole from the end of the tower and wheel side of the suspension arm
lower camber link
3 whole pistons
30wt oil
clossest to chassis camber link on the hub (is this making sense?)
long wheel base
no sway bar
white springs
3mm droop 6mm ride height
diff is medium to loose
sorex 36's on B medium inserts and revlite wheels
protoform mazda 6 body
like i said has less steering over all when compared to an assasin, please help.
thanks guys
How much rear camber, what's the rear roll center set at and what is the wheel base?
RCAmerica | Xray | Team Tekin | RC Paint By Sonny | P1 Brand
Monte Hess is offline   Reply With Quote
Old 11-13-2006, 10:57 AM   #16534
wyd
Tech Legend
wyd's Avatar
Just from what I see on that setup I would change a few things to start with.
30wt oil front with white springs, shocks mounted in the middle hole on the front tower, and remove the front riser plate under the bulkheads and silver sway with 5mm ride height and 2mm of droop. Front wheel base setup stock per the manual.
35wt oil for the rear with white springs, shocks ounted in 2nd hole from the outside of the tower, medium/short wheelbase, with 5mm ride height with 2mm droop and riser plate under the rear bulkhead with silver swaybar.
I would start with negative 1 degree camber for all four tires to start with.
I would think with this setup you should have plenty of steering when using a silver can 540.
Old 11-13-2006, 11:42 AM   #16535
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
What WYD said plus set your roll centers to 2mm (only the riser under the pivot blocks) in the front and 3mm (Riser + 1mm shims) in the rear.
Jon Kerr is offline   Reply With Quote
Old 11-13-2006, 02:58 PM   #16536
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
guys. wow, yeah.. like this is like the best thread so much. one question is whas't the best thing to do wth teh car?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 11-13-2006, 07:11 PM   #16537
what about a caster change?
what will that do and what way should i go im running 4's
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 11-13-2006, 07:19 PM   #16538
Super Moderator
opinions vary on castor. when I ran the car I always thought that if I ran anything other than 4 degrees, the car felt broken. 4 gives you the best balance. Running the silver clan class that you are running should allow you to have a larger "sweet spot" for your setup because you are not carrying the speeds into the corners that you would in 19T or Mod. WYD's setup is a great point to start at. I think my old setup is still on the Schumacher Pitspace, but it was close to WYD's. We run on some of the same tracks. After my 12th scale commitment is done I will get back to touring....Can't wait!
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 11-13-2006, 07:34 PM   #16539
wyd
Tech Legend
wyd's Avatar
When I run 6 degree of caster the car is easier to drive but does not yield as much overall steering as the 4 degree blocks do. I normally ran 6 degree but after running 4 degree the last 2 weeks the 4 degree where better and gave me more steering.
If you run the setup posted you should have alot more steering than you do now. Your running the 540 silver motor and they are not near as fast as a normal 27 turn stock motor and 19T turns we run with these setups. At your speed you should get tons more steering than you have now.
Old 11-14-2006, 06:46 AM   #16540
Skiddins's Avatar
Who are the top drivers at Schumacher now Teemu Leino has left for 'that lot'.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-14-2006, 06:54 AM   #16541
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Skiddins
Paul Wynn
Old 11-14-2006, 07:42 AM   #16542
PW
PW's Avatar
Send a message via AIM to PW
Skiddins
Congrats to Teemu on his new venture and best wishes.
Weylin Rose and Chris Goetz are the Top USA drivers.
Adam Rogers has been awesome in England over the last few months
Stay tuned.....
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 11-14-2006, 08:50 AM   #16543
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Jon Kerr is my hero as well!
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 11-14-2006, 08:58 AM   #16544
Jon Kerr's Avatar
What the?!?! What did I mis? I guess not being on here all the time now I'm a little behind. Where'd he go?
Old 11-14-2006, 08:59 AM   #16545
Jon Kerr's Avatar
Awwww Shucks.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
