Schumacher Corner
Originally Posted by aus jd 2703
hey guys what u think of putting a little m3 grub/set screw into the hub so it hold the hinge pins instead of e clips?
any one dont it?
is it more effective?
cheers
any one dont it?
cheers
I think you'll find this is the reason that very few manufactures do it.
Ask the Losi JRXS owners about holes in hub carriers etc, they are always cracking etc due to the weakness that a hole creates.
Just 'squash' the circlips to make them tighter, or buy some new ones every now and again
Skiddins
Originally Posted by wyd
Hate when work cuts into fun time!!!!!!!!!!!!! But then again need to make moeny to have fun time.
Tech Legend
Trader Rating: 51 (100%+)
Originally Posted by Jon Kerr
Yeah, it's a pretty big promotion I got (company car, expense account, etc...) but once I get up to speed, I'll only have one day in the office a week and that'll be one very busy day.
Tech Legend
Anyone know of any shops that have the HPI purple threaded spring retainers in stock? I tried all the places around my area and the distributors don't have them in stock or show the part number anymore. Think it is HPI30004 for the spring retainers.
Or if any of you guys have some you would like to sell that would be cool as well. Like to have them on my MI2 EC. Gold is nice but purple is better.
Nice, hope it all works out for you. Company cars are nice as I have one for my job. Cool thing for me my company lets me use as my own car and I take it to where ever I go and that includes racing.
Super Moderator
Super Moderator
Tech Legend
Originally Posted by Marcos.J
Can anyone tell me do I need to install the riser plates underneath the F/R bulkhead, and above the motor block/spur gear block's riser plate for stock/19T rubber indoor carpet setup?
I know I need to mount the riser plate for the F/R pivot blocks and some shim (1 or 2mm spacer) just do I need those above the motor blocks and below the bulkheads...
Anyone has a good setup sheet to share for indoor rubber carpet (stock/19T)? Thanks a million..............
Need to setup 1 EC for rubber and 1 for foam, and I have plenty of setup for foams.
Super Moderator
Thanks. I will have to check with them to see if they are in stock. Supposedly they where discontinued.
Trader Rating: 32 (100%+)
Originally Posted by teammidget lilB
hey guys got some ?s
How come alot of carpet foam tire set ups use 4 degrees not 6
can someone post a basic set up for foam carpet to go off of thanx
Also on foam tires we generally use caster to help the car finsh off or wrap the corner better....so the more you use the better the car does this. The only down fall is with more caster when the bite is high the car will traction roll easier. So thats why most setups you see for carpet foams the drivers are usually at 4 deg blocks as the final setup.
double post
Thanks guys....thanks KK...
One more question, when the setup sheet say "Roll center is 3mm"...then on the side note, it said "Riser plate plus 1mm"....does that mean riser = 2mm plus 1mm spacer...?
Also, the rear toe....how to setup 2 degree or 1.5 degree or 1 degree toe? Is that by the length of the rear pivot mount..? Mi2 is a little bit different compare to the other brand....
