Old 10-20-2006, 05:54 AM   #16411
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Originally Posted by aus jd 2703
bout the only problem is that the car has a higher centre of gravity which imo helps on aphsalt where grip is low and a bit of roll can increase grip.
but i reckon the mi3 if thats what they call it will kick ass.
ok im about to go from a track where i run 5.5mm and 6mm ride heights to a track that is bigger and slightly smoother, what can i expect to change to get the car handle similar? ill be lucky if i can put 2 pack in before we start qualifying so im trying to plan out what i might need to change.
cheers guys,
Josh
If the track is smoother you can more than likely change the ride height to 5mm front and 5.5 rear. Change your gearing and see what the car does. I find once I have a pretty good setup on one asphalt track it puts me pretty close at all the other asphalt tracks I go to.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 10-20-2006, 09:05 AM   #16412
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-20-2006, 10:23 AM   #16413
seaball's Avatar
Originally Posted by mini-dub
Just drivers testing new parts, we always get a lot of parts from the Team Dremel department .
and you shall see.
Old 10-20-2006, 11:11 AM   #16414
rayhuang's Avatar
I dont know, MI2 was alright, but MI3, now that was pretty awesome, though it sucks that felicity had to die so early on. How she dies was pretty whicked-in a dark kind of way.... but I dont know about any Dremels being used, though there were those cool explosives with electro magnets on them.
What are we talking about?? I'm easily confused.
Old 10-20-2006, 03:06 PM   #16415
wyd
Tech Legend
wyd's Avatar
Default Roll Center ?
Adrian I'm trying your suspension setup you posted awhile back and have a question on it. In the front you have 2.75mm roll center, does this include the riser plate under the suspension arm as part of you total roll center height?
If you leave the suspension riser and add 2.75mm roll center to that the suspension arm hits the bottom of the steering arm. I'm going to keep building but go with 2.75 overall counting the suspension riser plate.
OR if anyone else tried this setup and can help that would be cool as well.
Brian
Old 10-20-2006, 03:17 PM   #16416
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
2.75mm is overall. So the 2mm riser and .75mm shims.
Jon Kerr is offline   Reply With Quote
Old 10-20-2006, 05:38 PM   #16417
wyd
Tech Legend
wyd's Avatar
Thanks Jon appreciate the help.
Old 10-20-2006, 09:22 PM   #16418
Jon Kerr's Avatar
Anytime
Old 10-20-2006, 10:50 PM   #16419
acsubie's Avatar
hey guys, just had a quick question...i own a Mi2 with the original shocks, the collars on those shocks are prone to moving and not staying set, just wondering if the collars from the newer Mi2 EC shocks are a bit better in having an o-ring inside them keeping them set?
acsubie is offline   Reply With Quote
Old 10-20-2006, 11:34 PM   #16420
Jon Kerr's Avatar
Actually no. The collars on the EC shocks are very loose. I use JRXS collars since they match the shock body. You can also get TRF or HPI/Hot Bodies. All of them have o-rings and fit just fine.
Old 10-21-2006, 01:00 AM   #16421
HappyHippo's Avatar
HPI collars
HappyHippo is offline   Reply With Quote
Old 10-21-2006, 01:26 AM   #16422
mini-dub's Avatar
Trader Rating: 16 (100%+)
I just put a thin coating of medium CA on the inside of my stock EC collars and they've been great. On my other race car I have tamiya collars off a set of tamiya shocks that work just as well, but they're plastic so there's more friction in them without any CA. Lots of people run the HPI ones because they work great and are purple . But if you want to save a little bit of money you can use a small amount of CA to tighten the stock ones up. Remember... CA is the duct tape of RC .
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 10-21-2006, 01:31 AM   #16423
acsubie's Avatar
part # for the hpi...thanks for the help guys
Old 10-21-2006, 01:43 AM   #16424
HappyHippo's Avatar
430004
Old 10-21-2006, 02:15 AM   #16425
acsubie's Avatar
thanks once again for your speedy help...now the search begins for them collars
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
