Old 10-08-2006, 11:45 PM   #16306
Hey guy's by chance does any one have a decent set up for stock on carpet with rubber tires, with a BMI 2. any help would be appreciated.
cyrrus is offline   Reply With Quote
Old 10-09-2006, 07:29 AM   #16307
mattb's Avatar
Originally Posted by Skiddins
I can only think of 10 without the car in front of me.
Skiddins
lol i use the c/f brace thing on the rear lol
extra 2 screws
mattb is offline   Reply With Quote
Old 10-09-2006, 08:06 PM   #16308
P-DUB's Avatar
www.gearchart.com or www.racing-cars.com (under tech info)
Larry Pryor
P-DUB is offline   Reply With Quote
Old 10-10-2006, 04:37 AM   #16309
Skiddins's Avatar
extra 2 screws
Doh, so do I
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-10-2006, 05:05 AM   #16310
jo90's Avatar
to be honest you don't have to run that rear brace as the shock tower braces the diff halves anyway (that extra piece behind the tower actually helps to brace it).
Im looking into having a different top deck made that removes alot more of the flex (carpet use only) and one that allows more (carpet/tarmac). Won't cost to much to have done so worth testing them out.
I'll let you know once I have sorted them, likely be a few months yet.
Sponsored by SerpentUK, ModelTech & MTroniks
S400 / MTroniks IP6 / Team Brood / KO Propo = Loads of fun
jo90 is offline   Reply With Quote
Old 10-10-2006, 09:58 AM   #16311
mattb's Avatar
sweet joe sounds good just got my carpet spec shocktowers though today and fitted them
wow the rear is low compaired to the orig asphalt ones
Old 10-10-2006, 10:39 AM   #16312
Skiddins's Avatar
Of course, you could just buy the Foam edition top deck P/N U2979
It's thicker and has a 'squarer' appeareance when viewed from above.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-10-2006, 10:48 AM   #16313
Skiddins's Avatar
Roll Bars.......
I can understand that fitting a roll bar means that some of the grip is passed to the other end of the car.
But as this is the case, why run a roll bar at the other end at all, why not just fit a softer bar.
I have thought this before, but I was reminded of it when looking at Weylins carpet setup, black roll bar at the back, silver at the front.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-10-2006, 11:12 AM   #16314
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Swaybars will control the amount of roll on their end of the car. Not really transferring any grip to the opposite end of the car. I'll use a different bar on the front than the rear to try and balance the amount of roll the car has. The only way I can see it effecting the opposite end of the car is if your front end is rolling over way too much and allowing the inside rear tire to lift and diff out. Then going to a heavier front bar will feel like it's giving the rear more grip.
Jon Kerr is offline   Reply With Quote
Old 10-10-2006, 11:32 AM   #16315
Skiddins's Avatar
I was going by what the Hudy setup book said, and with regard to increasing the grip at the opposite end, it does appear to be true.
I thought roll centre was used to increase/decrease roll?
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-10-2006, 12:00 PM   #16316
mattb's Avatar
Skiddins
i thought the roll centre was to make the stering more/less agressive?
Old 10-10-2006, 12:25 PM   #16317
rayhuang's Avatar
I thought the roll center was the chocolatey goodness in the middle of a tootsie pop.
Old 10-10-2006, 01:00 PM   #16318
Jon Kerr's Avatar
A lot of things effect roll. Swaybars, springs, roll centers, shock angles, etc... It's just how it effects the roll. I could try to explain everything but I'd more than likely mess something up or confuse you. Go to the link below. It's by far the best site I've found that explains suspension dynamics.
http://home.tiscali.be/be067749/58/
Old 10-10-2006, 01:48 PM   #16319
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
i thought the roll center was most important to the xray team.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-10-2006, 01:59 PM   #16320
Jon Kerr's Avatar
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
