Old 10-06-2006, 06:09 PM   #16276
Kropy's Avatar
Send a message via AIM to Kropy
WOW!!!!!! You have issues.
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 10-06-2006, 06:49 PM   #16277
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by rayhuang
Nah-the cute guys never liked me anymore than the cute girls
I would comment on that but.....a few weeks ago I was in a dress so we'll let that slide...
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-06-2006, 07:00 PM   #16278
Trader Rating: 37 (100%+)
In stock trim the foam Mi2EC is still awesome. If you don't want to piece together Pro4 steering parts and/or do the T2 mod it's not needed.
I've been running a completely stock Mi2 EC USA Spec with no problems. Using a version of Seaballages' setup it works great. Maybe Seaball can comment but I believe he is running a stock car as well.
Rookie/Hippo.
Now that Schumacher Pitspace is back online I'll have pics of the Pro4 Mod posted. That is what I'm using on my rubber tire EC.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 10-06-2006, 07:40 PM   #16279
rayhuang's Avatar
I've been running a completely stock Mi2 EC USA Spec with no problems. Using a version of Seaballages' setup it works great. Maybe Seaball can comment but I believe he is running a stock car as well..
seaballs car is stock down to the last diff ball. I promise you that.
Heres Chris Goetz ROAR Nats Carpet/foam set-up . he TQ'd a round there!!
Old 10-07-2006, 12:23 PM   #16280
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
is there helpfull mods for the older mi2 other than a bmi chassis witch i have
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-07-2006, 01:15 PM   #16281
matt_h's Avatar
When building the rear diff on the ec, i can never get it really smooth. is there any tips to getting it better?
Its been suggested to me that the diff plates aren't up to scratch.
Any suggestions?
matt_h is offline   Reply With Quote
Old 10-07-2006, 01:30 PM   #16282
P-DUB's Avatar
First thing is to get the U1954 thrust bearing; this will last you all season (remember 1 washer is slightly larger).
Then use the female outdrive to sand both sides of the diff-rings on a hard, smooth surface. Clean everything very good and then apply rings to the outdrive with the squared edge of the ring towards the outdrive (grease the outdrive per manual). Apply a thin layer of grease on the whole ring and then build diff per the manual.
Make sure you use Schumacher diff grease and break-in the diff before running!
Larry Pryor
P-DUB is offline   Reply With Quote
Old 10-07-2006, 01:33 PM   #16283
P-DUB's Avatar
Schumacher EC shocks and towers. BMI towers would be great if you can get them Look for setups at www.racing-cars.com and www.gearchart.com
Larry Pryor
Old 10-07-2006, 01:36 PM   #16284
matt_h's Avatar
I've been using associated grease, what makes the schumacher stuff much better(apart from being schumacher obviously), also i have been using 600grit wet n dry on the diff rings
Matt
Old 10-07-2006, 01:48 PM   #16285
P-DUB's Avatar
Matt
The AE grease is thinner and feels better when first built, but it seems that the diff needs to be tighter when using the AE grease to keep it from slipping; that causes it to wear out faster. A little inside info...All the Tamiya guys used up my Schuy grease at the IIC
Larry Pryor
Old 10-07-2006, 01:54 PM   #16286
matt_h's Avatar
thats a nice bit of info
Do you recommend using 600grit wet n dry on the diff rings?
Old 10-07-2006, 01:56 PM   #16287
20 SMOKE's Avatar
got trf shocks and full bmi kit i should have worded it beter. other than durability what handeling advantage do you get with alloy hubs fr/rear
Jamie W
Old 10-07-2006, 02:02 PM   #16288
P-DUB's Avatar
I use 800 most of the time, but 600 is fine.
Sounds like you got the perfect setup then... Don't use the alloy front hubs as they bend way to easy. The rears are ok if you take out the extra slop; I would stick with the stock rear hubs.
Larry Pryor
Old 10-07-2006, 02:51 PM   #16289
protc3's Avatar
hey Pdub,you gonna come out tomorrow and run a heat with my 1/12th?i dont want to hear that you gotta brush the cat and vacuum the curtains!!
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-07-2006, 04:29 PM   #16290
P-DUB's Avatar
A 50 minute drive on my 6 year anniversary to say hi might not go over so well, but we will see what happens
Larry Pryor
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
