Old 09-27-2006, 11:32 AM   #16156
Skiddins's Avatar
Originally Posted by mattb
hi ive got a carpet seris coming up and i was wondering if anyone can help me out
its rubber cs-22
my mi2ec and the tracks indoor hi grip carpet
thanks in adv it will be very much appresiated
mattb
Looks like the setup above would be a good start, or Kevin Brunsdens Carpet wars setup.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-27-2006, 11:36 AM   #16157
mattb's Avatar
i know waylin likes his rubber to foam lol
what circuit was that done on?
thanks in adv
mattb is offline   Reply With Quote
Old 09-27-2006, 11:39 AM   #16158
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Great job to Weylin and all other Schumacher drivers at the IIC race.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 09-27-2006, 12:17 PM   #16159
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Skiddins
Of everything on thatcar what would you suggest changing if we wanted to get rid of some of the steering?
Skiddins
First thing I'd do is either go to a silver sway bar or raise the front roll center .5mm. Depends on if the car is loose or has too much steering.
Jon Kerr is offline   Reply With Quote
Old 09-27-2006, 02:16 PM   #16160
mini-dub's Avatar
Trader Rating: 16 (100%+)
At the IIC (med bite) the car had more of an oversteer than loose feeling. By that I mean the car was super locked in unless you turned the wheel hard, then it would break free pretty hard (not a very controllable slide), which is why I could pivot it around the 180 or something if I needed. Which is why I said the setup is dialed if you like lots of steering, it allows you to put it where ever you want it. Here are some things I would try though to tighten up the rear end or make any slide more controllable.
-first, just sauce less front tire (I did 1/2, try 1/4)
-stand rear shocks up one hole
-change rear WB to med/long instead of med/short or longer even
-raise rear hinge pin .5 or 1mm and go to silver rear bar so the suspension pressures the rear tire more instead of rolling as much, and then the silver bar will allow the rear end to roll more. Do these 2 changes at the same time.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 09-28-2006, 10:11 AM   #16161
Racer X's Avatar
I think that this is right. Weylin, let me know if it isn't and a big congrats!
File Type: pdf Weylin Rose Vegas 19t Winner Mi2EC Carpet Setup.pdf (205.2 KB, 301 views)
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 09-30-2006, 01:21 AM   #16162
mini-dub's Avatar
Yep, that's all correct except for one thing. That setup sheet is on the EC foam spec car, where I was running the asphalt towers. So on the carpet towers pictured on that setup sheet the rear shocks would be 2 holes farther in. Or on the asphalt towers that I ran, the shocks would be in the 3rd hole in from the outside.
Old 09-30-2006, 04:13 AM   #16163
Skiddins's Avatar
I understand the reason for running the asphalt top deck (more flexibility as you were not on foams?) but why the asphalts towers, especially as a lot of people are now running the carpet towers on the asphalt chassis.
Stop trying to confuse me
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-30-2006, 07:51 AM   #16164
IslandBwoy's Avatar
Question for the masses:
When you remove the raiser plate from under the diffs; I'm assuming this means that you are also removing the raiser plates that sit directly under the top deck to accomodate, is that correct? If that is the case what happens to the washer under the servo assembly that comes up through the top deck? I'm not sure that there is enough space there to run this spacer and hafe a lower top deck.
If you guys have anything i should look out for when making this conversion please let me know. I'll like to try this setup for tomorrows club race.
JEDI
IslandBwoy is offline   Reply With Quote
Old 09-30-2006, 07:56 AM   #16165
Skiddins's Avatar
JEDI
You have to remove that plastic washer so that the head of that long screw still sits in line with the top deck.
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-30-2006, 08:03 AM   #16166
IslandBwoy's Avatar
Thats what i thought. I was just trying to vision the change so i dont run into anything I'm not expecting. Have you tried this setup by the way? Did you have much success with it? And how are you guys acheiving 2.75 roll center as mentioned [HERE].
Old 09-30-2006, 08:03 AM   #16167
Jon Kerr's Avatar
Skiddins
Basically, he's running a rubber tire car with the foam car chassis.
Old 09-30-2006, 08:51 AM   #16168
Jon Kerr's Avatar
I haven't tried that exact setup. To get the 2.75mm roll center I'd use the riser plates for the pivot blocks plus a .75mm shim under each block.
Old 09-30-2006, 09:03 AM   #16169
IslandBwoy's Avatar
Ok. Thanks.
Old 09-30-2006, 09:33 AM   #16170
mini-dub's Avatar
Yep .
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
