Old 09-26-2006, 03:12 PM   #16141
mini-dub's Avatar
Trader Rating: 16 (100%+)
Here's the setup I ran all of qualifying at the mains, I didn't need to make any changes to the car it was so good. The setup was nearly identical to the one I started with from home, which proves that two tracks with different carpet and traction can work with nearly the same setup and only minor changes. But I will warn you, nearly everyone that's tried this setup hasn't liked it because it has so much steering... but it is very fast if you can drive it.
Front end:
RIDE HEIGHT: 5.4mm
ANTI-ROLL BAR: silver 1.2mm
CASTOR: 4
KICK UP: none
ANTI DIVE: none
TOE: .5 out
ROLL CENTER: 1.5mm
CAMBER: -1.5
BELLCRANK: center hole + 3mm shims under ballstud
STEERING KNUCKLE: front hole
LOWER SHOCK LOCATION: outer hole
UPPER SHOCK LOCATION: middle hole
CENTER TRACK ROD LENGTH: stock
INNER CAMBER LINK LOCATION: upper hole
WHEELBASE: med/long
NOTES: no riser plate under bulkheads. No wheel spacer on outside of hex. Orange hybrid o-rings in shocks. Standard aluminum arm mounts.
Front shocks:
OIL: 35wt
SPRING: Schumacher blue 16lb
PISTON: 3 hole
LENGTH: 61.5mm
DROOP: 2.5mm uptravel
Rear end:
RIDE HEIGHT: 5.5mm
ANTI/PRO SQUAT: none
ANTI ROLL BAR: black 1.5mm
TOE IN: 1.5
ROLL CENTER: riser plate + .5mm
CAMBER: -1.5mm
WHEELBASE: med/short
REAR HUB LOCATION: center
OUTER CAMBER LINK LOCATION: inner hole
OUTER CAMBER LINK SHIMS: none
LOWER SHOCK LOCATION: 2nd hole in from outside
UPPER SHOCK LOCATION: 3rd hole in from outside
NOTES: no riser plate under bulkhead. Plastic spacer on outside of hex. Orange Hybrid o-rings in shocks. Diff wont slip.
REAR SHOCKS:
OIL: Schumacher 35wt
SPRING: Schumacher white
PISTON: 3 hole
LENGTH: 62.5mm
DROOP: 2mm uptravel
Other:
BODY: Protoform Mazda 6
CHASSIS: Carpet Spec 2.5mm
TOPDECK: Asphalt 2mm
FRONT DIFF: oneway
ESC: Novak GTX
CELLS: EA Motorsports IB4200 WE
MOTOR: EA Motorsports Komodo
TIRES: RP30GL handout
If someone could put this on a setup sheet on one of the sites like Gearchart or the Schue Pitspace that would be cool .
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 09-26-2006, 04:37 PM   #16142
mo
mo's Avatar
Good job Weylin! That's my special boy.
I put your setup on www.gearchart.com
http://www.gearchart.com/index.cfm?f...&showheader=No
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-26-2006, 06:43 PM   #16143
mini-dub's Avatar
Thanks Mo .
My mom always said I was special...
Old 09-26-2006, 06:54 PM   #16144
rayhuang's Avatar
Originally Posted by mini-dub
Thanks Mo .
Great job Weylin-if every rubber tire car looked as good as yours, I think youd convert a lot more foam drivers to rubber tires!!
But we all know, but most of us wont admit-its mostly in the wheel!!!
Old 09-26-2006, 09:36 PM   #16145
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by Solara
Nexus and I are trying to make up some excuse for the 4 days Halloween classic...it is a tough one, but we will try...
well, another racer and i just put in about 50 total hours this week to get some new paint on the boards, and some new things in there for this year. just for you and nexus. don't let me down.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 09-26-2006, 10:57 PM   #16146
rcshark's Avatar
Send a message via Yahoo to rcshark
momma saids "(Good job now you can have your pudding)!!!
rcshark is offline   Reply With Quote
Old 09-26-2006, 11:38 PM   #16147
HappyHippo's Avatar
Nice job Weylin
What kind of spur&pinion size did you use on the KD19
HappyHippo is offline   Reply With Quote
Old 09-26-2006, 11:39 PM   #16148
mini-dub's Avatar
It was a 30/118 combo, gave me a final drive of 7.08 .
Old 09-26-2006, 11:46 PM   #16149
HappyHippo's Avatar
What kind of brushes and spings did you use
Old 09-26-2006, 11:49 PM   #16150
mini-dub's Avatar
F-brushes, full face no cavity, and I believe purple +/red - springs.
Old 09-26-2006, 11:52 PM   #16151
HappyHippo's Avatar
Thanks Weylin
Old 09-27-2006, 04:43 AM   #16152
Skiddins's Avatar
Thanks Mo .
The kids at school always called me 'special'
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-27-2006, 08:51 AM   #16153
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
I fixed my lose front steering, I replaced all the ballcups with some rpm ones and there is hardly and slop. Nice purple ones to.
roadrashracing is offline   Reply With Quote
Old 09-27-2006, 10:26 AM   #16154
Skiddins's Avatar
Front end:
RIDE HEIGHT: 5.4mm
CASTOR: 4
KICK UP: none
ANTI DIVE: none
TOE: .5 out
ROLL CENTER: 1.5mm
CAMBER: -1.5
WHEELBASE: med/long
Front shocks:
OIL: 35wt
PISTON: 3 hole
LENGTH: 61.5mm
Rear end:
RIDE HEIGHT: 5.5mm
TOE IN: 1.5
CAMBER: -1.5mm
REAR SHOCKS:
PISTON: 3 hole
LENGTH: 62.5mm
DROOP: 2mm uptravel
Other:
FRONT DIFF: oneway
ESC: Novak GTX
Of everything on thatcar what would you suggest changing if we wanted to get rid of some of the steering?
Skiddins
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-27-2006, 11:16 AM   #16155
mattb's Avatar
hi ive got a carpet seris coming up and i was wondering if anyone can help me out
its rubber cs-22
my mi2ec and the tracks indoor hi grip carpet
thanks in adv it will be very much appresiated
mattb
mattb is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
