Old 09-07-2006, 01:19 PM   #15961
Korey Harbke's Avatar
No I have to say that wasnt me. That was when he was in europe with his ski team I guess. All I can say is I'm glad I dont ski anymore LMAO.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-07-2006, 02:23 PM   #15962
hey jon can i just have a pick of your camber link? did u slot it all the way till it was 2m high or just a new hole at 2mm?
cheers, just cannnt afford new towers if i stuff it up
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 09-07-2006, 03:33 PM   #15963
mini-dub's Avatar
Trader Rating: 16 (100%+)
Yeah.... ski team... what can I say .
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 09-07-2006, 03:41 PM   #15964
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I don't have a pic of it here but yes, I slotted it up. Just measure from the highest point on the top hole up 2mm. Then use a dremel and slot it up so the top of the slot is at your 2mm mark. Make sure you go straight up. Be careful because it is easy to mess it up. You could try and drill the hole out. Just make sure both holes are drilled in the exact same position. One higher than the other would be a bad thing.
Jon Kerr is offline   Reply With Quote
Old 09-09-2006, 08:18 PM   #15965
hey do u guys use chassis protecors?
looking at puting two layers of book covering contact to protect my chassis. opinions any one??
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 09-10-2006, 06:51 AM   #15966
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
wat does this do
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 09-10-2006, 04:01 PM   #15967
P-DUB's Avatar
Originally Posted by teammidget lilB
wat does this do
Gives more steering middle/exit for more cornerspeed. It will also reduce the wear ring on the front tires.
A good needle file works well to slot the hole, less chance to screw up
Larry Pryor
P-DUB is offline   Reply With Quote
Old 09-10-2006, 04:03 PM   #15968
P-DUB's Avatar
No one that I know of...It will also reduce clearance causing you to run the car slightly higher
Larry Pryor
Old 09-10-2006, 05:55 PM   #15969
does schumacher make a tower already drilled??????
Bryan "Lil B" Ford
Old 09-10-2006, 05:59 PM   #15970
AdrianM's Avatar
No. We didn't think we would need that hole but we do when we remove the diff risers.
Its not hard to do and most sedans today need simlar work done to them. The T2 guys are cutting apart their rear bulkheads for more rear flex and traction. The RDX guys redrill their shock towers to lower them. The Cyclone guys have to grind the top of their chassis and front suspension mount for belt clearance.
Adrian Martinez
Old 09-10-2006, 06:05 PM   #15971
Chesty v wants to know where the slotting of the t2 bulkheads are
Bryan "Lil B" Ford
Old 09-10-2006, 07:55 PM   #15972
AdrianM's Avatar
They are cutting the rear bulkheads so they end up with seperate layshaft mounts and rear diff housings. I guess its supposed to give them more rear traction.
Adrian Martinez
Old 09-10-2006, 08:28 PM   #15973
Jon Kerr's Avatar
Just got home from a couple of days up at Tamiya for the KO GP. Overall a pretty good weekend. After a handful of adjustments on the car yesterday, it was really good. Fast laps around 13.4 to 13.5. (Unfortunately I couldn't hang with Barry and Jun running 12.6-12.8 laps consistently ) I ran the Novak 4.5 brushless for the first time ever for this race since I ran the expert mod class. That's going to take some serious getting used to. There's just such a difference in the way you have to drive the car. I qualified 10th in the B main and finished 8th (I think. I forgot to check the official results before we took off.) Respectable for the first time running that motor/speedo combo and considering the competition level in that class. My setup was really good. It was a little different than Reedy. Anthony, I'll send you a copy of it for the Pitspace tomorrow along with some pics. I'll try and do a little write up too for you.
Old 09-10-2006, 08:33 PM   #15974
hey jon,
thats pretty sweet i dont even live in usa but have heard of the ko gp, good result, didnt think you were a mod man, obviously u can hold ur own and then some.
congrats man.
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 09-10-2006, 08:47 PM   #15975
Jon Kerr's Avatar
Thanks. I usually run modified anytime we club race outdoors. I really only ran mod at this race because the spec class was a 23 turn class like they run in Japan. Not knowing those motors at all, I preferred to run mod and try and make myself better.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
