Old 07-22-2006, 11:00 PM   #15511
hey can u raise the diffs of an old mi2?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 07-22-2006, 11:59 PM   #15512
just curious what would it do to run the org. mi2(or BMI2) without the riser plates? or is that something you would do for carpet. I'm an asphalt guy 95% of the time. cheers.
cyrrus is offline   Reply With Quote
Old 07-23-2006, 03:18 AM   #15513
Conrad's Avatar
Yes you can, to do this you would need to the teemu shock towers and teemu riser plates. This will give you a similar suspension setup to the carpet towers everyone ran on there Mi2 with TRF shocks.
The theory behind it is with the riser plates the driveshafts run closer to the level (think spirit level here) and will improve the efficieny of the drivetrain, they will also reduce grip at whatever end of the car they are fitted to making the car turn easier.
Personally i never noticed much of a difference between with and without on the Mi2 although i never got a chance to try them properly back to back. Since then i've always run my cars without the riser plates, i know alot of people do run with them though. Try it and see what suits you best.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 07-23-2006, 08:59 AM   #15514
Biz_Nessman's Avatar
just think of the riser plates (or shims like i run) as a roll center adjustment. one way will make it roll easier and the other will make it feel stiffer. i run mine without risers(shims)in the front and with about 1mm shims in the rear.
Biz_Nessman is offline   Reply With Quote
Old 07-24-2006, 09:50 AM   #15515
Cowboy Bob's Avatar
Well I finally switched to the MI2 EC TC which I plan on running in stock on pavement. I have seen where the Factory Team cars have the diffs lowered? Is that something that someone could explain please? I am also looking for any kind of setup help for running this car on an indoor asphalt track. So if any of you could help me out it would be greatly appreciated.
Does the Mazda 6 body work well with this car or is there a better choice. I am not new to racing but I am new to this car
Cowboy Bob is offline   Reply With Quote
Old 07-24-2006, 10:20 AM   #15516
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by Conrad
The standard EC comes with 2mm risers plates between the diff uprights and the chassis. The foam spec EC doesnt use the risers plates so the transmission sits lower in the car. You dont need to lower the diffs, some people like it some people dont. If you do choose to run without the diff riser plates you should really be running the foam spec EC shock towers as well, as the suspension geometry will be wrong running the std EC towers without riser plates.
are these two passages really six posts apart?
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 07-24-2006, 10:36 AM   #15517
Cowboy Bob's Avatar
What's your point seaball? I asked ligitimate questions and would appreciate legitimate answers
Old 07-24-2006, 10:44 AM   #15518
seaball's Avatar
the legitamate, and detailed, answer came before the question, thus making the question unnecessary.
general rule of thumb: read a day or two of posts before creating one. you'll leave a better impression.
Old 07-24-2006, 10:50 AM   #15519
Cowboy Bob's Avatar
The other rule of thumb is to read the entire post as I asked more than one question
Old 07-24-2006, 10:50 AM   #15520
Originally Posted by seaball
the answer came before the question, thus making the question unnecessary.
general rule of thumb: read a day or two of posts before creating one. you'll avoid appearing lazy and/or otherwise.
-C
I am lazy, that is why I just ask you all the questions that I have, with out trying anything myself.
In fact, the more I think of it, at the next race I'm at, you can just wrench AND drive on my car, while I sit in front of the big fans and cheer you on.
J/K
-J
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Old 07-24-2006, 10:53 AM   #15521
seaball's Avatar
enough. take my advice and i'll take yours, and this thread won't suck so bad.
Old 07-24-2006, 12:07 PM   #15522
Trader Rating: 37 (100%+)
The Mazda6 is probably the most popular body to run on any TC if you race rubber tires...indoors and out. I would also look at the Parma "M Type". Either way you can't go wrong.
As for the diffs...I think guys are just saying the either use or don't use the spacers that go under the diff/bulkheads.
For setups you can view Schumacher Pitspace. The link is in my sig.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 07-24-2006, 12:18 PM   #15523
chubbspeterson's Avatar
sounds so lovey to the ears......like urine splashing in a toilet.........
Mike Demone
7-Eleven, National Accounts Manager
Ridgemont, CA, 90026
"I vowed to never let this happen.."
chubbspeterson is offline   Reply With Quote
Old 07-24-2006, 01:41 PM   #15524
seaball's Avatar
hey chubbs, are you familiar with the term, "hotbagger"?
Old 07-24-2006, 01:44 PM   #15525
santinuchi's Avatar
Default ?????
play nice dudes!!!!!!! seaball c-ya friday!!!!!!! -T-
santinuchi is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
