Old 07-20-2006, 02:35 PM   #15496
Originally Posted by seaball
cyanoacrylate. i just did that last week when i rebuilt my ec car for the sizzler.
C-
You ARE my hero!!!!
Fantom, BL Racing, Retired
jimnew is offline   Reply With Quote
Old 07-20-2006, 11:13 PM   #15497
ottoman's Avatar
R/C Tech Charter Subscriber
No wonder you were so fast
ottoman is offline   Reply With Quote
Old 07-20-2006, 11:22 PM   #15498
AdrianM's Avatar
Originally Posted by tim fry
Hi all
Not sure if this has been noticed before but my EC centre pulleys move on the shaft forwards and back as if the pulleys are worn or the pin which holds them is. Any ideas?
Tim
Some play is fine but after a few months of hard running layshaft can wear where the pins do through. It might be time for a new layshaft.
Adrian Martinez
Old 07-21-2006, 12:07 AM   #15499
yeh thanks scott, wouldnt do it with out asking you and all the guys on here. just some fast guys said it is an option to save weight and right now im 50grams over so i was kinda interested, cheers though
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 07-21-2006, 05:10 AM   #15500
Default Diffs
I was reading where a bloke who is selling his new mission stated he lowered his diffs like the factory guys..............
A.) Is this necessary for the car to work properly?
b.) Does the car come like that or do you have to do it yourself by modifying existing parts?
Ginsu is offline   Reply With Quote
Old 07-21-2006, 09:12 AM   #15501
hey to the stock and 19 turn guys. do you guy's run any different in set up for either one, or just basicly the same. Oh yeah I also run a BMI-2 both cars.
cyrrus is offline   Reply With Quote
Old 07-21-2006, 01:09 PM   #15502
Trader Rating: 37 (100%+)
Not sure about everyone else but I've pretty much always run the same for 19T/Stock.
I'm sure more of the guys who run the car will chime in after the weekend of racing.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 07-21-2006, 01:11 PM   #15503
A few pics of Teemu are available on Schumacher Pitspace from the 2006 Worlds courtesy of PW.
http://www.pdubracing.com/schumacherpitspace/ - See "Events"
Old 07-21-2006, 02:13 PM   #15504
STLNLST's Avatar
Trader Rating: 19 (100%+)
Feom my experience I have always set my car up for mod and it's that much better in the lower classes. So in your case get a dialed 19 turn set up and the car should be killer in stock as well. Others may feel diferently depending on if they like a spool in on class and a oneway in the other. In stock I do like a oneway 99% of the time.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-22-2006, 05:57 AM   #15505
Skiddins's Avatar
The setup's from mod and stock tend to be similar with the EC, you can perhaps run the suspension slightly softer in stock without the risk of grip roll etc due to the lower speeds.
I think droop is less important in stock as well, as you don't use the brakes the weight transfer is more gradual.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-22-2006, 07:49 AM   #15506
Anyone?
Old 07-22-2006, 09:50 AM   #15507
Biz_Nessman's Avatar
I also run a bmi mi2 (not ec) and the setup is the same as the mod setup except for upper shock location and the car feels dialed i also run a spool for the asphalt in stock class.
heres my setup:
FRONT:
white schumacher springs (tamiya trf shocks) 35wt trinity oil 3 hole pistons
yellow sway bar
shocks in outer hole of tower and arm (bmi tower)
camber links in upper middle hole
droop is 2mm above ride height
ride height is 5mm
camber is -.5 deg
NO SHIMS UNDER PIVOT MOUNTS
REAR:
white schumacher springs(TRF SHOCKS) with 40wt trinity oil 3 hole pistons
no sway bar
shocks in 3rd hole from center on the tower and outer hole on arm (bmi tower)
aluminum rear hub carriers
camber links are in the middle hole on the tower and outer hole on hub carrier
droop is 1mm above ride height
ride height is 5mm
camber is -1 deg
1 purple take off shim under each pivot mount(forgot the thickness)
Hope that helps!
Biz_Nessman is offline   Reply With Quote
Old 07-22-2006, 10:50 AM   #15508
STLNLST's Avatar
Anyone?
I'm not too sure what you mean by lowering the diffs like the factory guys. The EC comes with the option of raising the diffs but we all run them without the riser plates thus the effects of lowering the diffs. Out here in Sac the car feels alot better with the diffs in the normal position.
Old 07-22-2006, 11:50 AM   #15509
Conrad's Avatar
The standard EC comes with 2mm risers plates between the diff uprights and the chassis. The foam spec EC doesnt use the risers plates so the transmission sits lower in the car. You dont need to lower the diffs, some people like it some people dont. If you do choose to run without the diff riser plates you should really be running the foam spec EC shock towers as well, as the suspension geometry will be wrong running the std EC towers without riser plates.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 07-22-2006, 12:44 PM   #15510
Thanks.................
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
