Old 07-13-2006, 02:57 PM   #15451
Super Moderator
Tony Rivas's Avatar
Trader Rating: 53 (100%+)
Originally Posted by bob33
hey mate
im runing a ea co27 im using the std springs that came with it think ther red or purple. then im using f-line brushes with the traling edge filed off. and the graring is 89/29 i think that is 5.52 i could gear it evan more and it wouldent bun the motor up but it does get a little warm
hope that gives u a starting point
bob.
WoW you must run on a big track. How big??
The "Dominican Assassin"
Sorry for the Spelling but you know what I mean.
Tony Rivas is offline   Reply With Quote
Old 07-14-2006, 06:02 PM   #15452
justin lessard's Avatar
Send a message via AIM to justin lessard
Originally Posted by Bob Barry
just wanted to let you guys know that Justin Lessard was on rails at the Express race yesterday. I was very happy with the way my car handled, I just couldn't wheel it quite the way I wanted.
ORL2 and Charity race this weekend mean road trip to MD!!
Im going to try post my setup, any feedback/comments/suggestions post away.
here's my setup
FRONT
ride hieght:5.5
anti roll bar:silver
castor:6 degree
kick up:0.6mm
toe out:1 degree
roll center:1.6mm shim under front block,and 1mm rear
camber:2 degree
wishbone:short
shock location(tower)middle
shock location(arm)outer
camber link:upper
shock oil:30
spring:white
piston:2(drilled to 1.2mm)
droop:1mm
REAR
ride hieght:5.5
anti roll bar:none
anti squat:.5mm
roll center:3mm front,2.5 rear
camber:2 degree
wishbone:long
shock location(tower)second from inner most hole
shock location(arm)second from outer most hole
camber link:lower
shock oil:35
piston:2(driled to 1.2mm)
droop:2.5mm
spring:white
rear camber link in outer hole on hub
body: parma M
tire rp30
let hybrid dip set on tires for 30 min
justin lessard is offline   Reply With Quote
Old 07-15-2006, 05:14 PM   #15453
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
newberg - check your pm's and email. my whole setup is different, but i got it worked out. get it on your car for tomorrow morning.
- chris -
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 07-16-2006, 09:13 AM   #15454
STLNLST's Avatar
Trader Rating: 19 (100%+)
As predicted Schumacher finished 1 & 2 at this years 7th annual Revo race. Mo won (congrats) and I finshed 2nd (brushless) Running Mo's set up from the nats was pretty good. The car was on point all night. It felt good to not have to cut a motor all day
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-16-2006, 09:33 AM   #15455
the track ant that big... but the motor goes like a rocket out the courners and down the str8 can get about 6 runs without cuting the comm. it dsent get burnt upor anything. its just the rite gearing for that track
i must have been lucky and got a good powerful motor
bob33 is offline   Reply With Quote
Old 07-16-2006, 11:38 AM   #15456
Sanabria's Avatar
Congrats to you and Mo. Good job!
Sanabria is offline   Reply With Quote
Old 07-16-2006, 03:13 PM   #15457
Super Moderator
Tony Rivas's Avatar
great job mo
Old 07-16-2006, 05:22 PM   #15458
ORL2 series hit our indoor asphalt track in Frederick, MD. WYD put his Mi2EC in the show again. He is still is in the number one in points. Bob Barry and myself was there also running the Mi2EC's. The car was working good, except when I would hit two of the corners. They where like magnets. I snapped off two of the pins on the cvd bone that goes into the spool. I broke 4 pins that connect the axle to the cvd bone. I also tore up the spool. I need to continue working on to much front traction. Tires over heat and I start breaking loose coming out of the turn. Just about had it worked out of the car by the mains. I did find that running 19T at our track is hard on the car. I will only race 19T at larger outdoor tracks. The was so much traction. They sprayed the track 2 weeks ago with WD40 and changed the layout.
Next up is some practice and then the Roar 2 Regionals.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 07-16-2006, 06:52 PM   #15459
ottoman's Avatar
Congrats to Chris G (seaball) for his TQ in stock foam at the Sizzler today... his car looked great
ottoman is offline   Reply With Quote
Old 07-16-2006, 07:43 PM   #15460
Trader Rating: 37 (100%+)
Sounds like there was some awesome racing this weekend from all the Schumacher guys...congrats.
At the Summer Sizzler...
Chris Goetz TQ'd stock foam vs. some tough competition. His car throughout qualifying was awesome.
Euge and I made the A in Stock Rubber at the Sizzler as well...some tough luck in the Main as we both had 2nd at one point. In the end a really great showing for the Mi2EC's.
Schumacher driver Kevin Kane concentrated on 1/12 Stock and finished a strong 2nd in the A Main.
Check back on the Pitspace site this week for pics from the Sizzler and some other races around the country.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 07-17-2006, 10:12 AM   #15461
Super Moderator
Trader Rating: 17 (100%+)
Like Steve said...19T was a little brutal at Frederick. Open Mod was worse and I did both. I snapped the pin that goes in the layshaft pulley twice. blew two TiR worlds axles apart broke a caster block when the screw came out of the bottom of the steering knuckle and the car started wandering, 2 spur gears (1 was from a rock in the charity race that was on Sunday).
On a lighter note...I finally was able to put Welyin's setup on the car and once I added 1mm of Kickup the car was awesome. I had a good shot at making the show at the charity race...We only got two qualifiers and my first one had the shock pop off twice, second one had the rock in the spur. I ended up winning the E Main with a time that would have had me qualify somewhere around 11-13th out of 61 guys.
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 07-17-2006, 11:09 AM   #15462
STLNLST's Avatar
Way to hang in there and not give up.
Old 07-17-2006, 11:53 AM   #15463
Super Moderator
Thanks. My car was an A main car. I just had bad luck all day and with a reshuffle where I am on a 24 or 25 lap pace and the guy in 6th in my heat is on a 16 lap pace......well you kind of get the idea what happens
Old 07-17-2006, 12:26 PM   #15464
seaball's Avatar
thanks otto and nexus.
i ran the bone stock ec carpet car and, with some tuning, it was awesome. it was about a tenth faster than the next fastest car of eli ezrow, but my bobbles, reduced the gap to only .5 sec for TQ. on my TQ run, i ran a 12.7 almost four minutes in! i think only three or four guys even ran a 12.7 all day.
for those of you waiting on a vegas setup, it may take a little more time. i made about a dozen changes on it versus the way i ran it two weeks ago at the gate. traction was completely different. i'm not sure how vegas will be, but i'll be working on the car until then.
- luke fontaine -
Old 07-17-2006, 01:01 PM   #15465
Super Moderator
Talking
- luke fontaine -
Hey Luke, Keep me updated because I will be heading inside soon
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
