Old 03-08-2002, 01:52 PM   #1531
Thanks for the replies, guys...think I'm set..
markg is offline   Reply With Quote
Old 03-08-2002, 06:38 PM   #1532
hey fellers, is there any way to set my droop without using a droop gauge and blocks? I just havent gotten all my Hudy stuff ordered yet. I do have a digital caliper for measuring if that will aid me any. Thanx in advance.
IKE
FoamDonuts is offline   Reply With Quote
Old 03-08-2002, 08:05 PM   #1533
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Ike.....If you have a ride hight gauge set your car at the ride hight that you want. Then lift up on one end of the car (only high enough to max out the ridehight) and slid the ride hight gauge under the end that is lifted. What ever number you have on the gauge over your static ride hight is your droop. Then repeat for the other end of the car. You can adjust your droop screws to get how much droop you want. I use this method over the droop gauge and seems to work just as good.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 03-08-2002, 08:22 PM   #1534
kevin,
COOL thank you very much, I think you are following me around from the 12 forum to this one HEHHEHEHEHE. Just another question for ya KEV, what is the length of your shocks? Also, could you tell me what method you use for measuring them I want to see if the way that I did it in 1/8 on-road is the same method that most guys on here are using. When I built my shocks the other and was measuring them they came out at 62.15mm
IKE
Old 03-08-2002, 09:14 PM   #1535
Mopar: I agree, the 20 tooth wasn't any good in stock.
_neas_ is offline   Reply With Quote
Old 03-08-2002, 11:32 PM   #1536
Kevin K's Avatar
Ike....honnest im not following you.....it just happens that these are the 2 boards that I check in on. I measure the over all max length or full extension of the shock. From shock top(very top) to bottom of the ball cup. I run my shocks 66mm long...might be longer then most but thats where I like them. I also use RPM ball cups.......... they are longer then the ball grippas that come in the kit......on the shock ends so the spring sits up higher, this is helpful if you use Associated springs.
Old 03-08-2002, 11:34 PM   #1537
Kevin,
I had a be@tch of a time getting the Schuie ball ends to bottom out on the shock shaft. Wich RPM ball cuppers are you using(part numbers?) I measure mine from inside the ball cup and inside the shock eyelet at the top and I get 62.15mm i will try the other way as well.
IKE
Old 03-08-2002, 11:38 PM   #1538
Kevin K's Avatar
I use the standard RPM cups in purple.....not the long ones. I know that I dont thread the RPM cups all the way onto the shaft. When I get them to the length that I want there is still a little threads showing on the shaft. Hope this helps....when I did use the ball grippas I did not thread them all the way onto the shaft aswell.....so you might have them too short maybe
Old 03-09-2002, 12:11 AM   #1539
Oasis2001's Avatar
Send a message via ICQ to Oasis2001
Hi guys,
Just wondering what inserts you guys use with Take Off tyres? Everyone is using the 27 tyre on asphalt and its excellent expect you always get a groove on the inner edge of the tyre. Everyone in mod gets it and its obvious the stock insert 'squirms'. I was looking at HPI but the Echo inserts seem quite good and light which is excellent.
Chris
Oasis2001 is offline   Reply With Quote
Old 03-09-2002, 02:48 AM   #1540
Send a message via ICQ to MattW
I think squirming is generally caused by too much air gap. For this reason i usually use Schumacher foam inserts in Take off tyres. The greys if it is cold (haven't used them in the hot yet!!). I would guess maybe black or even blue.
MattW is offline   Reply With Quote
Old 03-09-2002, 05:32 AM   #1541
Oasis2001's Avatar
Ive never been a big fan of foam inserts. i did get some however with some Pit wet weather tyres. Unfortuently only the rims and inserts came in the order! Still waiting upon tyres!
Old 03-09-2002, 05:35 AM   #1542
Oasis. actually I found the oppsoite true thus far. I run on aspahlyt and run 27's in the front and 22's in the rear and I ran the stock MED insert in the 22's and they look great but ran an HPI med/firm (blue) insert in the 27's and it bunched and gave me that nice little line on the inside of the tire as you are talking about I wasn't sure why it did it either, its a pretty firm insert and usually the soft ones are the only ones to do it. My buddy has rant he SAME thing only on an Xray and has no problem, wonder if it is b/c the mission has so much steering and front end grip?? I am curious though!!! I would like to know what to do also! Also might add these are the only CS tires I have tested but have some more I just received (32's and 27's) so now I am afraid to mount them LOL
wilson10 is offline   Reply With Quote
Old 03-09-2002, 05:39 AM   #1543
Oasis2001's Avatar
Thanks for the input Wilson. It certainly is a probl;em and you maybe correct. I have tried running the upper hub hole(less camber change) and 0 degrees camber! Still the tyres 'groove' on the inside. its a pain because when you cut them off they are almost brand new in the centre but down to the belt on the inside edge. Booger!
I just thought a hard insert like the HPI red or green would be cool with it. I do think HPI Blue is a little too hard. i tend to match inserts with track temps and blue is for hot tracks where you would be using 22 or 27s.
Old 03-09-2002, 05:50 AM   #1544
I agree about the temp thing and MAYBE it was too cool for the insert???? I live in a hot humid place but it is just begining to warm up. It has never been hotter than 65-70 degrees ambient when i have ran. I think the greens may work I am going to try blues's again and HOPE it works!
Old 03-09-2002, 05:52 AM   #1545
maybe JB inserts will work, Check em out on Orions website. They look sweet!
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
