Old 07-02-2006, 01:56 AM   #15346
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Thanks Donny.
The car is really coming along well at SoCal. The track rod mod is really nice. Gives the front end a totally different feeling. Still have some more things I want to try mainly to see what they'll do. If anyone wants the setup I finished with tonight, drop me an Email and I'll send it to you. I'm not sure how well this will work outdoors but it may be worth a shot. It would probably be pretty good rubber tire on the rug.
Competition in 19 turn is so tight there right now. The top 3 or 4 I think were separated by about a second, (Donny qualified 3rd I think and finished second) Charlie Albrecht (Corally) and Thad Gardner (Hot Bodies) were also up there. Then 2 seconds back was 5th then all the way back to 10th (me) there was less than a second gap. About 5 seconds between 10 cars.
Jon Kerr is offline   Reply With Quote
Old 07-02-2006, 02:03 AM   #15347
Jon Kerr's Avatar
Originally Posted by aus jd 2703
jon have u posted a how to make ur steering rack yet?
nd will it work on mi2 non ec? i see no reason why nt but always good to check.
cheers all
The rack is actually a carbon fiber center track plate from a Tamiya 414MII I had laying around. Then I put 2 holes 10mm apart in the center for the inner steering links. I used some flanged 6mm bearings and shims to allow it to pivot. I posted a pic of it a few pages back. If you can make one, it should work on the Mi2. It may not work as well because the steering knuckle is different on the Mi2. You'd have to shim the inner ball stud up 1.5mm higher to get the bump steer right.
Old 07-03-2006, 12:08 PM   #15348
Snatched this from the novak brushless thread:
This is the car of user Marcos.J and notice the wear on the front belt. I have the exact same problem. Anyone have an idea to what could be wrong? Tried everything; checked if anything hit the belt, replaced all pulleys, but it's still comming back.
bester is offline   Reply With Quote
Old 07-03-2006, 12:20 PM   #15349
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
mine was caused from the belt bouncing up and hitting the pinion
Old 07-03-2006, 05:52 PM   #15350
Super Moderator
Makes sense, I think I have the same problem. when you tightened the belt tension did it get better?
Tekno | JConcepts | RRP | LutzRC | BOOM RC
Bob Barry is offline   Reply With Quote
Old 07-03-2006, 08:08 PM   #15351
AdrianM's Avatar
The pinion set screw can hit the belt with certain pinion gears and belt tension settings.
Adrian Martinez
Old 07-03-2006, 09:14 PM   #15352
Super Moderator
Marcos.J's Avatar
i grinded down the set screw ( Adrian told me how )
Old 07-04-2006, 10:39 PM   #15353
AdrianM's Avatar
Teemu, our team manger Phill Booth and the British contingent arrived in Italy today.
They have met up with PW who hopefully got some luggage in today (its been 2 days since he arrived)
Adrian Martinez
Old 07-05-2006, 12:10 AM   #15354
King-G's Avatar
Send a message via ICQ to King-G
Good luck to the guys in italy.
I hope teemu gets the result he deserves a the worlds
King-G is offline   Reply With Quote
Old 07-05-2006, 12:23 AM   #15355
go teemu go lol
korny i know
be good for both teemu and schumacher if he won the worlds
btw does any one have a good baseline for medium bite aphsalt?
please and thank you
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 07-05-2006, 06:54 AM   #15356
Super Moderator
I use Paul's speedline setup with a heavier front sway bar and the front diff lowered. That is a good starting point.
Old 07-05-2006, 07:21 AM   #15357
jo90's Avatar
use short grub screws in your pinions, that will stop that wear !!
Have a feeling we will see some development parts on the Mi2 for the worlds, perhaps he might run carpet towers like some of the UK team have been doing of late, have to wait and see
Sponsored by SerpentUK, ModelTech & MTroniks
S400 / MTroniks IP6 / Team Brood / KO Propo = Loads of fun
jo90 is offline   Reply With Quote
Old 07-05-2006, 08:32 AM   #15358
I have used some heat shrink tubing over the pinion to save the belt, works good It makes removing the pinion a bit annoying, but with brushless I don't have to do it too often.
olev is offline   Reply With Quote
Old 07-05-2006, 08:38 AM   #15359
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default big progress
hey carpet guys,
i have the freakiest setup on the ec car ever for the rug (stock). i tested it all weekend against my custom car, and it's better than my custom car has ever been. more forgiving in the switchbacks without any loss of rotation in the 180's. it's simply disgusting. i have to tweak it just a bit to make it more driveable up front when the sauce is fresh and the voltage is big.
i'll be testing it in two weeks at scotty's place (trackside) to see if it holds up away from the gate. if it does, this will be an awesome base to start from for this winter, as it's also easy to drive. keep your fingers crossed. i have never had a car this good before.
i'll post the setup after the sizzler if it's still working.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 07-05-2006, 08:49 AM   #15360
Jon Kerr's Avatar
Originally Posted by seaball
hey carpet guys,
Starting point for Vegas?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
