Old 06-30-2006, 12:51 AM   #15331
King-G's Avatar
Send a message via ICQ to King-G
rebound is the amount / force / speed the shock shaft extends from the shock after being compressed.
(push the shock in, and if it rebounds quickly, and to full distance you have lots of rebound)...if it doesnt come out on its own force you have none
To adjust rebound, try more or less oil in the shock, and various foam bobbins or orings inside the top cap
King-G is offline   Reply With Quote
Old 06-30-2006, 09:13 AM   #15332
IslandBwoy's Avatar
Ok so you’re saying its pretty much trial and error? Try a couple different things until i achieve 0 rebound. And then repeat those steps for the remaining shocks?
IslandBwoy is offline   Reply With Quote
Old 06-30-2006, 09:33 AM   #15333
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
To get 0 rebound, you'll need to bleed the shock. I like to have about 1/2 a shaft length of rebound in my shocks. If you have more than that after building them with nothing inside the bladder, hold it sideways, push the shaft in about 1/2 way and loosen the cap until you feel the pressure on the shaft release, then tighten it up again. This should give you about the right rebound. Try and make sure both sides are as close to matched as you can get.
Jon Kerr is offline   Reply With Quote
Old 06-30-2006, 10:18 AM   #15334
IslandBwoy's Avatar
Thanks.
I just want to try a couple different configs. I've been been runing with about 1/2 rebound (i usually go on how quick it rebounds) but wanted to see if i could tell the difference when running 0 rebound.
Speaking of which. What is the difference in feel IYO?
Old 06-30-2006, 10:47 AM   #15335
Jon Kerr's Avatar
Never really played with it much.
Old 06-30-2006, 01:13 PM   #15336
Jon Kerr's Avatar
I'll be testing my new steering rack again tomorrow. Last week it worked really well. It seemed to make the front end really pull the car around the track. A little too much in fact. I got the car pretty good for the main but it wanted to rotate a little too much mid corner. But it really helped a lot with the turn in. I have a couple of things to try tomorrow.
Old 06-30-2006, 06:59 PM   #15337
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
any one play with shock length and what does it do
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 07-01-2006, 06:27 AM   #15338
Trader Rating: 36 (100%+)
Good luck to the Schumacher crew at the Worlds...
There some awesome things in the works online for Schumacher The few who have had a sneak peak have had nothing be compliments on it.
Stay tuned!
Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 07-01-2006, 09:12 AM   #15339
Jon Kerr's Avatar
Shock length really isn't going to affect handling at all al long as they're long enough to allow enough droop and they're even left to right.
Old 07-01-2006, 11:13 AM   #15340
Hey, guy's. just a quick question on the MI2.
What a good lenght for the steering rack. the connection rod between the two. And also what a good lenght for the connection rod between the servo to the rack. thanks
Any info would be greatly appreciated.
Oh by the way Happy Canada Day.
And best of luck to the team @ the worlds.
cyrrus is offline   Reply With Quote
Old 07-01-2006, 11:18 AM   #15341
Jon Kerr's Avatar
40.8mm from end to end.
Old 07-01-2006, 01:01 PM   #15342
20 SMOKE's Avatar
That's what I thought, thanks
Jamie W
Old 07-01-2006, 03:19 PM   #15343
Thanks again Jon.
Old 07-02-2006, 12:58 AM   #15344
cornerspeed's Avatar
Jon's car was really good tonight at SoCal. Made a lot of progress.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 07-02-2006, 01:53 AM   #15345
jon have u posted a how to make ur steering rack yet?
nd will it work on mi2 non ec? i see no reason why nt but always good to check.
cheers all
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
