Old 06-28-2006, 10:25 AM   #15316
I use the JR 8450 in my Mi2EC. I also think WYD uses the 8450 also.
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 06-28-2006, 11:01 AM   #15317
Send a message via ICQ to Jan Larsen
Here's a tip:
If you take the alu drive shaft wheelhex and the to spacers from the old Mi2 and put it on the EC, you increase the track width by 2mm in each side. Or said in another way. You go from 190mm to 194mm.
Jan Larsen is offline   Reply With Quote
Old 06-28-2006, 11:03 AM   #15318
Super Moderator
Trader Rating: 17 (100%+)
KO Digital in my car.
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 06-28-2006, 11:11 AM   #15319
AdrianM's Avatar
Originally Posted by Jan Larsen
Here's a tip:
A standard Mi2EC is 186mm wide with no spacers. The old Mi2 hexes are 1.5mm wider than the EC hexes. If you run the old axles and hexes you will have a 189mm wide car.
The only way I see your car being 194mm is if you used old Mi2 rear hubs on the EC. That would put you over 190mm in the rear.
Adrian Martinez
Old 06-28-2006, 11:14 AM   #15320
Ok, I admit, didn't check the current track width, the 190 was just as a reference. But i'm using the standard EC axles with the old hexes. Works very well and widens the car 3-4mm.
Old 06-28-2006, 01:15 PM   #15321
STLNLST's Avatar
Trader Rating: 19 (100%+)
I'm running the old axles and steel drive shafts with the EC alum hexes and my car isn't wider than 190mm. Had no problems going thru tech at the Reedy or the asphalt nats.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-28-2006, 01:51 PM   #15322
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I also use the JR 8450 in my car.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-28-2006, 05:17 PM   #15323
kyle "hitawall"'s Avatar
I just Finised putting my MI2EC togather. It went together really well. So far I am really impressed with the car. i can't wait to run it.
RCAmerica|Xray|Hudy|Jaco|EPIC
kyle "hitawall" is offline   Reply With Quote
Old 06-28-2006, 05:25 PM   #15324
It is an awesome car. You will love it.
Steve Walter
Old 06-28-2006, 07:23 PM   #15325
wyd
Tech Legend
wyd's Avatar
Very nice car. Minereally works well for me and overall pretty easy to work on. Another nice feature is this forum. Lots of guys on here that can help you out. PW and Adrian at Schumacher are very helpful.
Old 06-29-2006, 06:52 AM   #15326
Sanabria's Avatar
You'll like it a lot Kyle. How the tides change...Lil B, Dave and now you all in less than a week. There will be a Schumacher Battalion at the remaining FSEARA races.
Sanabria is offline   Reply With Quote
Old 06-29-2006, 07:26 AM   #15327
IslandBwoy's Avatar
Great now i'm going to have to get a new car
IslandBwoy is offline   Reply With Quote
Old 06-29-2006, 04:39 PM   #15328
IslandBwoy's Avatar
Question: How do you build a shock with 0 rebound versus building on with full rebound?
Old 06-29-2006, 05:26 PM   #15329
0 rebound mean the shock should flow back full rebound i guess it does move back? i mean the shaft when u push it in
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 06-29-2006, 07:57 PM   #15330
IslandBwoy's Avatar
how? I've noticed that if i build my shock and screw the cap on tightly while fully pressing the shaft into the housing that the shock has less rebound; and similarly if i screw the cap on with the shock fully extended, the shock finishes with more rebound, but how do i get 0 rebound?
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
