Old 06-18-2006, 06:43 PM   #15196
justin lessard's Avatar
Send a message via AIM to justin lessard
check it on blocks,with the battery in,but make sure you dont set it on a screw.
justin lessard is offline   Reply With Quote
Old 06-18-2006, 06:44 PM   #15197
cornerspeed's Avatar
Originally Posted by aus jd 2703
hey when u guys tighten the upper and lower decks to get tweak out do u leave the pack in?
i did thinking it would simulate the weight distrubution of the chassis is this right or should i take it out and re do it??
thanks all
I would check it with the battery in, but not when loosening, then tightening the screws down. I always checked the chassis flatness with the car ready to run, up-side down on the shock towers. If it rocks on the towers, then loosen everything up to relax the chassis back to flat. Afterwards then check it again. Also you have to remove the rear body posts to do this. A little more work, but I believe it is the most acurate way of checking chassis flatness.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 06-18-2006, 06:46 PM   #15198
Originally Posted by Jon Kerr
That's what I'm hoping for. I've got a little list of things to try next week. Are you going to be able to go or are you working?
I'm gonna try to get off work early. I want to go so bad.
Donny Vinkemulder
TLR Driver
Old 06-18-2006, 08:36 PM   #15199
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by King-G
That mod looks nice Jon, please post your impressions once youve track tested it, and if possible please do an A -B test with the regular ackerman (mid bellcrank with 40.8mm trackrod) and your new setup.
is it an off the shelf part from another manufacturer for the carbon plate with bearings?
Thanks Gavin. It's actually a center track rod with 6mm flanged bearings that I modified to work from a Tamiya 414 that I still had laying on a shelf in my garage.
Jon Kerr is offline   Reply With Quote
Old 06-18-2006, 08:37 PM   #15200
Jon Kerr's Avatar
Let me know. I think Patrick is planning on coming too. We can all ride in the Vibrator up there.
Old 06-18-2006, 08:38 PM   #15201
Let me know. I think Patrick is planning on coming too. We can all ride the Vibrator up there.
You guys better head on up there yourselfs without me. I may not be able to leave around 2:30 or so. That's if we are slow at work.
Donny Vinkemulder
TLR Driver
Old 06-18-2006, 08:51 PM   #15202
Jon Kerr's Avatar
OK, cool.
Old 06-19-2006, 04:40 AM   #15203
Super Moderator
Tekno | JConcepts | ProTek RC | RaceReadyProducts | BOOMrc
Bob Barry is offline   Reply With Quote
Old 06-19-2006, 04:53 AM   #15204
Can't wait to get the Mi2 EC on the track this weekend. PORC race in Jackson, NJ. Bob Barry are you ready?
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 06-19-2006, 04:59 AM   #15205
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Yeah I need to get the car ready. Tuesday night and Wed will be get all the race stuff ready and then Thursday is pack up and Friday hit the road.
Have a few things to do to the car and it will be ready.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-19-2006, 06:01 AM   #15206
Super Moderator
Well lets see, I have the intercooler for the turbo on...yup I'm good to go.
Old 06-19-2006, 08:29 AM   #15207
Moderator
Trader Rating: 76 (100%+)
My car has the bmi carpet towers, what kind of result would you get if you use the stock mi2 towers?
roadrashracing is offline   Reply With Quote
Old 06-19-2006, 09:33 AM   #15208
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Default foam setup
mr. barry, i have what you want.
the nats setup is real easy to drive. the one i migrated to since then is a bit more aggressive, and better for high bite as the changes made help keep the front end up.
Schumacher Corner-mi2ec_foam_-goetz-nats.gif   Schumacher Corner-mi2ec_foam_-goetz-club.gif
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 06-19-2006, 10:34 AM   #15209
Super Moderator
Nice, Thanks Chris. Were you running the mod'd shock tower in the rear?
Old 06-19-2006, 11:05 AM   #15210
seaball's Avatar
no, sir. the car is box stock down to the screws. for some reason, i have never run alot of rear camber gain on any of my cars. i like the links long and level. i makes the car have a more equal amount of rotation through the turn. whenever i use gain, the car has a distinct entry and exit phase of the corner. the level links seem to smooth out the turn.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
