Old 06-17-2006, 07:21 PM   #15181
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Originally Posted by aus jd 2703
hey guys is there mod to do away with the centre tie rod? the one thats between the servo saver and wheels pretty much is about 30 to 40mm long tip to tip its not a turnbuckle just threaded rod?
just seems to be a source of slop in the steering?
Here's something I fabricated the other day. I'll be testing it next week.
Jon Kerr is offline   Reply With Quote
Old 06-17-2006, 08:35 PM   #15182
Trader Rating: 37 (100%+)
Originally Posted by Kevin K
I have been playing with the HPI pro-4 graphite steering plate on my car. Its a graphite plate that takes place of the center track rod and it piviots on bearings so its slop free. I didnt try it because of slop I did it more for ackerman adjustments and it makes the steering feel more linear. So far I have used it on carpet foams and rubber tire asphalt and I like the feel of the car more with it.
Kev.
You are now tasked with keeping me up to date on all Mi2EC modifications! :P
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 06-17-2006, 08:36 PM   #15183
Super Moderator
pretty trick stuff Jon!
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 06-17-2006, 09:21 PM   #15184
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
i am working on a few steering mods as well...
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 06-17-2006, 09:24 PM   #15185
Jon Kerr's Avatar
Thanks Bob. I've got a few things to try on my list. This is just #1.
Old 06-17-2006, 09:47 PM   #15186
Super Moderator
nice, can't wait to see what you guys come up with. I'm using the KISS method right now and it seems to be working for me for now.
Old 06-17-2006, 10:03 PM   #15187
cornerspeed's Avatar
Anxious to see your car run next weekend with that steering mod. Might give it a good liniar feel.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 06-17-2006, 10:05 PM   #15188
Jon Kerr's Avatar
That's what I'm hoping for. I've got a little list of things to try next week. Are you going to be able to go or are you working?
Old 06-18-2006, 07:57 AM   #15189
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
Wanted to check and see what has to be done to get the MI2 car (older version) to be able to use the current crop of batteries...3800, 4200, ect.
Any info would be great.
Jeff
Jeff Werner is offline   Reply With Quote
Old 06-18-2006, 08:06 AM   #15190
Jon Kerr's Avatar
You can get a BMi2 chassis from Jason. His are cut to fit the larger cells.
Old 06-18-2006, 09:18 AM   #15191
mini-dub's Avatar
Trader Rating: 16 (100%+)
Schumacher sells a different chassis for the Mi2 to fit the larger cells which is another option. If you have a chassis that still uses a battery tray Schumacher also makes just a battery tray that's designed to fit the larger cells. Or you could just use a file and enlarge the battery slots until the big cells fit right. That's the cheapest method .
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 06-18-2006, 01:35 PM   #15192
heavy's Avatar
Trader Rating: 20 (100%+)
Jeff
No need to buy anything. Just file the edges of teh battery slots a little bit and put a spacer under the battery posts (start with 1 mm ) and then file or dremel a little out of the inside of teh battery posts. All size cells will now fit fine.
cheers
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 06-18-2006, 04:12 PM   #15193
King-G's Avatar
Send a message via ICQ to King-G
That mod looks nice Jon, please post your impressions once youve track tested it, and if possible please do an A -B test with the regular ackerman (mid bellcrank with 40.8mm trackrod) and your new setup.
is it an off the shelf part from another manufacturer for the carbon plate with bearings?
King-G is offline   Reply With Quote
Old 06-18-2006, 05:43 PM   #15194
justin lessard's Avatar
Send a message via AIM to justin lessard
today I ran my steering mod...and it is DIALED!!! maybe I can post a pic.
justin lessard is offline   Reply With Quote
Old 06-18-2006, 06:39 PM   #15195
hey when u guys tighten the upper and lower decks to get tweak out do u leave the pack in?
i did thinking it would simulate the weight distrubution of the chassis is this right or should i take it out and re do it??
thanks all
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
