Schumacher Corner
WYD loves his one way. I'm not a fan. until this car I drove dual diffs. I will be running a spool setup though. Heres the track
http://www.jacksonrcracing.com/images/done_l.jpg
Originally Posted by HarshGuy
Quit whining ...I've got 4 weeks of "ball and chain duty" I gotta pull ...something about "you've been unavailable ever since the carpet nationals"
That track is sweet. I could never run stock on something like that though
Originally Posted by STLNLST
Sack up and lay the law down. I did three races to your two. Wimp
..I would have gladly traded places with your 3 races and what I did with my two
I wouldn't want the task of dealing with spoiled factory guys. You have my highest respect.
Originally Posted by PW
Watch it buddy! We are not all like Barry
The track is in Jackson NJ. It is Team Trinity's test track and pretty much used to be Express's as well. I know what you are saying about not being able to run stock there, BUT I have to establish myself somehow and if you can compete against the competition around here in stock and 19T, you can compete anywhere. I will probably end up signing up for 19 as well at the track just for some more track time and so that Im not bored all day LOL
Been thinking about removing the spacers and lowering the transmission from my EC so its like the US carpet spec for racing carpet with rubber tyres. Anyone had any exparience doing this? Are there any avantages?disadvantages? Thinking also about using the carpet towers and may be the 2.5 mm top deck just to try to get that little more corner speed.
All thoughts gratefully recieved
Cheers
Paul
Cheers
Paul
Mine is currently lowered, using std towers that have had the link holes slotted to compensate.
I would think that the stiff top deck would be too stiff for rubbers. However std is probably a bit soft. I will probably try a 2.5 with quite a bit of material removed.
hey guys is there mod to do away with the centre tie rod? the one thats between the servo saver and wheels pretty much is about 30 to 40mm long tip to tip its not a turnbuckle just threaded rod?
just seems to be a source of slop in the steering?
Trader Rating: 32 (100%+)
