Old 02-28-2002, 03:27 PM   #1501
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Flounder.......I have never had that problem on the Axis 2....I did have the motor screws hit the belt if they were not the round head ones. Thats a strange one I ran alot of D4's in my old car and never had any problems with them hitting the belt
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 02-28-2002, 05:54 PM   #1502
cornerspeed's Avatar
Racer X- So what are you guys finding with set-up?
cornerspeed is offline   Reply With Quote
Old 02-28-2002, 06:29 PM   #1503
PW
PW's Avatar
Send a message via AIM to PW
Cornerspeed, give me a call tomorrow!!!!!!
PW is offline   Reply With Quote
Old 02-28-2002, 07:03 PM   #1504
tc3driver's Avatar
Send a message via AIM to tc3driver
Default thanks for the push
I appreciate the push in the right direction... and for all the replies
laters
tc3driver is offline   Reply With Quote
Old 03-01-2002, 03:06 PM   #1505
Default Re: Shredding Belt
Originally posted by flaunder
Well, I think I found the problem causing shredding of the rear belt on my Axis ll. I use a Trinity D-4 and the can has that black crinkle finish that is somewhat abrasive. The part of the motor housing the output bearing stuck out through the mounting plate far enough to actually rub the belt from vibrations under power. I shimmed the motor side to back the motor out further. Any one out there using a D-4 in an Axis ll? Nice sight! First one I've found with a Shumacher thread
I think it is the screw from your pinion. Check if it's sticking out a little bit. If so it can hit your belt.
Greetings from Holland
Sandor
Sandor is offline   Reply With Quote
Old 03-01-2002, 07:08 PM   #1506
AdrianM's Avatar
We are working with some fast guys all over the country to get a few really good setups to serve as starting points for drivers going to the Carpet Nats.
Ron Atomic has a setup that has him running lap times 1/10th faster with the CS27GLR's than with his best setup on Sorex tires. He thinks he can make the set up faster and even easier to drive so stay tuned!
Brian Jucha, Timmy Heiser, RacerX, Jeff Whitman, Pat McCarson and Dominic Favarito are also hot on the case.
We had a good run at the Snowbirds. There was excellent sharing of information among all of the Schumacher Drivers. Sponsored and non-sponsored. We hope to have the same occur before and during the Carpet Nats!
Adrian Martinez
Old 03-02-2002, 08:22 AM   #1507
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
chee thanks Adrian, for including me in the list of people on hot pursuit of finding a hot setup! LOL I am basically there.......... O yea I didnt tell YOU that, i think it was Paul! lol
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 03-03-2002, 01:09 PM   #1508
ADRIAN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!hehehhehe havent done that yet so I thought I would take advantage. Anywho, did you get Ron Atomic's setup for the CS27's yet? I am really dying to try it out, it sure would be nice to save a little money and not have to glue tires.
IKE
FoamDonuts is offline   Reply With Quote
Old 03-03-2002, 08:03 PM   #1509
Team EAM
EAMotorsports's Avatar
Trader Rating: 78 (100%+)
Send a message via AIM to EAMotorsports
Has anyone had problems with the 64 pitch spur gear adapter rubbing the top plate and the belt?
thanks
ea
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 03-03-2002, 08:10 PM   #1510
nope I havent
Old 03-03-2002, 08:38 PM   #1511
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
Eric-
My adaptor rubbed the upper deck.....at the edge of the opening for the spur. I beveled the edge around the spur opening slightly....seemed to fix it.
Where is the adaptor contacting the belt?
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 03-03-2002, 08:39 PM   #1512
Speaking of 64 pitch. I got the adapter coming...what gears are/is everyone running? I do stock only.
_neas_ is offline   Reply With Quote
Old 03-04-2002, 12:15 PM   #1513
Mopar's Avatar
With a green machine 3, start around 116/33 with the 17, depending on size of track. I run mostly at SoCal Raceway. Hope that helps.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 03-04-2002, 03:34 PM   #1514
Team EAM
SirSpeedy...its not rubbing very bad....but bad enough to feel in the drive train. I will bevel the top deck tonight.
Its rubbing the belt slightly on the side of the belt. Before I put the top deck on it rubed very bad and both front and rear pulleys wobbled. Not sure if the wobble in the pulley is what is causing it or not. But its not rubbing as bad with the top deck on...but the deck is.
ea
Contact Us
Old 03-04-2002, 10:36 PM   #1515
Thanks Mopar. I got the alloy 17 tooth coming. The 20 just didnt work for me...
I got a whole bunch of 64 pitch stuff...mostly higher up though I think...120+
Corner Dots anyone? RCGaryK Electric On-Road 19 07-03-2006 11:12 PM
On the Corner RC-HPI R/C Photography 0 08-02-2005 10:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 10:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 06:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 02:36 PM
