Old 06-07-2006, 06:42 AM   #15061
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Guys Im sure this has been talked about I just couldnt find it.
Mi2 EC edition and anything higher than Stock racing im just killing front axles and cvd's.
The aluminum one's just arent working.
Pins breaking,pins sliding out even with locktite on it and so on.
Any tips?
Les
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 06-07-2006, 06:44 AM   #15062
Any tips?
Les
decrease steering dual rate
skamolly is offline   Reply With Quote
Old 06-07-2006, 06:58 AM   #15063
Skiddins's Avatar
Any tips?
Les
Make a 'flat spot' in the pins using a Dremel or similar.
Once the CVD is assembled, put a thin piece of heatshrink around the CVD, this will stop the pins from moving.
Skiddins
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 06-07-2006, 08:46 AM   #15064
Super Moderator
Trader Rating: 17 (100%+)
Glue a 1.6 mm shim to the back of the steering hub so that it acts as a stop.
Tekno | JConcepts | RRP | LutzRC | BOOM RC
Bob Barry is offline   Reply With Quote
Old 06-07-2006, 09:59 AM   #15065
mini-dub's Avatar
Trader Rating: 16 (100%+)
Any tips?
Les
Yeah, most likely this is happening because the CVD's will bind a full steering throw which just wears the crap out of them. I glue a 2mm shim to the back of the steering knuckle to limit steering throw and it's a huge improvement. I don't feel I ever need that much throw so I'm not worried about it. Be sure to check your steering endpoints after though.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 06-07-2006, 10:47 AM   #15066
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Any tips?
Les
I had a rear pin come out in my main this weekend and that even with it being thread locked. I put in a new pin and re-thread locked the set screw. Then I did the shrink wrap trick over the rear CVD's so I highly doubt this will happen ever again, at least in the rear.
Now in the front I have the Titanium axles with the alum cvd. The pins stay in but I have problems keeping the pins in that the blade fits over. They are so loose that I could push them out with my fingers!!!!!!!!!!! The worked loose when I ran the spool but with the one way in I did not have that problem. I'm going back to the spool so looks like I will be using a tiny amount of JB weld. Just enough to keep the pin in but if I need to change it I can still get it out if need be.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 06-07-2006, 10:54 AM   #15067
Super Moderator
Brian are you running the TiR CVDs? I put them in for this past week so far so good.
Old 06-07-2006, 11:10 AM   #15068
wyd
Tech Legend
wyd's Avatar
Yeah thats it. I have them in the front only and the stock Schumacher CVD's in the rear. The TiR ones I have problems with the pins that the blades go over. They push out with just my fingers so we know that isn't going to stay in during a run thats for sure. 3 times with the spool in they where 1/2 way out. Like I said I will fix that problem for this weekend thats for sure.
Old 06-07-2006, 11:13 AM   #15069
mini-dub's Avatar
TiR CVD's are my favorite, but just recently I had 2 pins move slightly in the end of the dogbone. First time that's ever happened to me. It's probably because of TiR going to cheaper materials and such to save on manufacturing costs, it wouldn't be the first time they've done that. I just pushed the pins back into position and put a drop of thin CA on it and wiped the excess glue off. So far no problems .
Old 06-07-2006, 03:47 PM   #15070
Send a message via ICQ to MattW
I doubt it's a material issue, more likely to be a dimensional issue - think you would only be looking at odd microns oversize and maybe teh pins could come loose. I don't know. All i can say is that the TIR ones that i have in my car are absolutely fine. Fitted them when i got them, and they are still there and no problems with any of the pins. I do have a brand new set sitting in my haouer as spares, must check them to see if the pins are loose at all. If so, then your bset bet is Loctite 603 retaining compound.
MattW is offline   Reply With Quote
Old 06-07-2006, 05:51 PM   #15071
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Sounds like Clint is running pretty good
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 06-07-2006, 11:49 PM   #15072
mini-dub's Avatar
Good thought on the locktite, if I ever have a problem again I'll try that. The only problem I had with the pins loosening was on a pair of new bones. The older ones I've had have been awesome, I can run them on the back of my car for like a year . Maybe there was a tiny size issue with the bone or something on the new ones. But your right red locktite would work the best for holding them still I think.
Old 06-08-2006, 03:14 AM   #15073
heavy's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Skiddins
Schumacher 'used' to do alloy and titanium versions of the shock mount posts, but they seemed to have dissappeared from their site
I have the alloy version myself and they are far better than the plastic and nut version that comes with the kit.
Maybe Tir make them, so it might be worth giving them a call.
Skiddins
part number TR7801
Honorary Life Member Logan RCCC -Mi6 and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6
Boondall. SuperShot, XX, XXT, SVR,Schumacher Storm
heavy is offline   Reply With Quote
Old 06-08-2006, 07:49 AM   #15074
STLNLST's Avatar
We are now team mates three times over.....LOL The oneway set up is pretty good but I have one area on the track that's costing me two tenths. I better get it right today. We have a low representation from the schuie camp at this race but we will pull something out of the hat.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-08-2006, 08:37 AM   #15075
Glad you found you a new deal. I'm sure you'll like it.
Now get out there and get to work.
Corner Dots anyone? RCGaryK Electric On-Road 19 07-04-2006 12:12 AM
On the Corner RC-HPI R/C Photography 0 08-02-2005 11:53 PM
Snowbirds Around the Corner scarecrow Florida Racing 20 01-27-2005 11:43 AM
1/12th Corner GT Racer Singapore R/C Racers 26 03-04-2004 07:59 AM
Shumacher Corner in Aus jamesbaxter_81 Australian Racing 6 01-08-2004 03:36 PM
SEO by vBSEO 3.5.0
