Originally posted by AzNDRAGster
I have NEVER had any glitching problems with my car.
Thats becuase glitching has absolutly nothing to do with the car. I get a kick out of post that start out like "My Brand X touring car is glitching" Glitches have nothing to do with the car.
Glitching is always gonna be from one of the following:
-motor
-esc
-receiver
-servo
-crystals
Motor:
brushes toast,comm burnt,capacitors damaged,bearing noise
ESC:
A damaged esc can cause irratic operation(they dont last for ever)
Receiver:
Antena wires damaged?, bad receiver?
SERVO:
damaged servo can cause glitching even when it its self is working
Cyrstaks:
Delicate little items that will crack internally and give glitches
No graphite chassis are normally the cars that guys cry foul about when it comes to glitching so make sure your screws are tight in your alloy parts and going though your graphite chassis. Also dont run your antena wires along the chassis surface, with the tight area on a SD make sure your motor leads are not too close to the antena either. make sure the shaft is not rubbing against any wires and that your motor is not too close to the esc.
