Old 01-09-2010, 11:01 AM   #1
Default Speed Passion Motor Timing
I just purchaesed my first Speed Passion motor. I have read that it has infinite timing. I only see 10 degrees marked. What am I missing and how can I make the adjustments? There is no real instruction included with the motor.
rcracerb is offline   Reply With Quote
Old 01-09-2010, 11:49 AM   #2
skypilot's Avatar
Trader Rating: 14 (100%+)
where did you read that? must have been a mis-print or you didn't read it correctly.
as you now hold the motor in your hand you can see clearly that it does not.
assuming its a Version 3 motor, simply loosen the three end bell screws and slide the sensor to where you want it.
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 01-09-2010, 03:22 PM   #3
Send a message via MSN to Bigger Brother
I think you've mis-understood it - it means the motor has infinite adjustable timing within the range - ie you can set it to any setting between 0 and +10, unlike some motors which only have, say, 3 fixed settings or something.
As above, loosen the screws and move the sensor to your required setting.
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 01-09-2010, 06:16 PM   #4
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
The Speed Passion Thread
Mark Tilley
Got T-Bar ? ......... Oregons No ZigZag rule sucks
Bias the weight to the end you want to hit the wall with first!
Searchin fer answers in the Fog.......that's what I found
Drillit is offline   Reply With Quote
Old 01-10-2010, 07:36 AM   #5
What is the most common timing for the SP V3 17.5?
Old 07-12-2016, 07:29 PM   #6
Default plz help
Need to now how to adjust the timing on a 7.5t speed passion motor
jfatal09 is offline   Reply With Quote
The Speed Passion Thread memix Electric On-Road 13132 10-26-2016 08:00 AM
Speed Passion 1/8 scale brushless Applesauce Electric Off-Road 1000 02-28-2013 08:09 AM
speed passion,GTB,LRP TC SHAUN GRIDER Electric On-Road 47 03-21-2008 09:26 AM
SEO by vBSEO 3.5.0
