Motor Glitch (Different Thread)
I just ran my Yokomo SD today and whenever I go full throttle, it glitches. Nothing too bad. The steering's got a mind of its own and the motor stutters.
Also, if I just drive it around at a low speed (mid end-low end) its fine.
I think this could be because I haven't cut my comm in a while. What do you think?
Yep, cut your comm and install new brushes. Break it in till the brushes are fully seated(wear on all four corners of the brushes) and your good to go.
Thanks.
So these are the common symptons of this problem?
Originally posted by rc-zombies
Randman on the SD thread had the same problem with his CGM chassis... he was able to eliminate the glitching problem by replacing the CGM SD with a XXX-S
Originally posted by DOMOisCOOL
Thanks.
Thanks.
Originally posted by AzNDRAGster
Everyone is going for another car now, the yokomo is going to be old news. Darn, and I haven't even broken that many parts yet either.
